Where can one find the battery charge level?
What's the best way to extend the battery life?
If I shoot DNG/JPG, where do the JPGs end up? I don’t see them when I import the files into Lightroom. Are they the ones transferred over to the Leica Photos?
If one shoots A for aperture, shutter speed, and focus, is it the same as Full Auto in Scene Mode?
I notice the photos I take in Black and White turn to color when I import them into Lightroom. Importing the B&W photo into Leica Fotos shows it is B&W, which I assume is so that it can be shared. My question is: Are there specific Lightroom presets that show the Leica style?
I occasionally get the red box with spinning circle. Why does it do that? I assume it’s writing to disk but I’ve had occasions where I haven’t taken a photo at all, so there’s nothing to “write to disk.”
Can I use the Leica Q2 LCD panel to focus/shoot like my Canon 5D Mark IV? Maybe I’m wrong but I recall seeing a video of a Leica Q doing so.
Does changing the user profile also change what’s found on the favorites menu?
Is there any sort of logic for how to set up the FN versus the wheel button? I appreciate their usefulness but I find I can’t remember what’s where and I end up going back to the menu button. Any suggestions on how to set it up logically?
Share this post
Welcome :)
A long list. I would advise you to take some time to familiarize yourself with the camera, using the manual, first.
There are no LR settings for "Leica Look". Nobody really knows what it is supposed to be. My definition is that it (whatever it is) is created by the way that the photographer takes the image.
Share this post
Answers to virtually all your questions are in the Q forum threads, but I’ll tackle one.
When you take B&W images in camera those show in in LR as B&W if you are shooting jpgs and color if your shooting DNG’s. Sometimes it’s nice to shoot jpg + DNG. That way you can quickly upload the B&W images using the Fotos App to your smartphone to share. Later in LR on your computer the DNG has the full color image. You could covert that to B&W in LR if you want or process the full image anyway you choose.
Share this post
Some answers:
yes
You can (and should) invent your own logic. I assume, everyone has their own preferences here. Mine are:
  • FN button: I call it "camera control", and contains interval/bracketing/self-timer/focusing etc.
  • Wheel button: I call it "exposure control", and contains exposure metering, ISO, white balance etc.
Settings for FN button and wheel button are the same in every profile (otherwise I would get mad).
Edited by 4peterse
Share this post
28 minutes ago, 4peterse said:
Some answers:
yes
I set up the Fn button and the thumb wheel almost exactly like you. It just seemed logical to me and something I can remember.
Share this post
Lightroom imports either DNG (raw) files or both DNGs and jpegs – but I have forgotten how you set this! If you have opted for b/w jpegs  but Lightroom shows colour pics that's because it is importing the raw files.
Share this post
As I remember even the DNG’s show up with the in camera settings for instance crop and B&W. Whenever you try to read-crop you’ll see the full image (28mm). Whenever you try and develop, you’ll see the full RAW image and adjustment possibilities. I pretty much take all this for granted now and don’t even think about it anymore. Seamless in LR.
Share this post
The battery level is shown on the LCD, top right corner.  You've actually taken the camera out of the box and turned it on, yes? ☺️
Take a look at the Power Save Modes in the manual and menu for extending battery life.  You can also disable the rear LCD screen to varying degrees.
One cool trick with the FN button - a long press with show you all the items you have set it up to control, and then you can choose one for the moment (same is true for the Wheel button).  For example, you can switch it from controlling the drive mode, to controlling the self-timer, or to AF mode. I set FN to menu items that I want to find quickly that I change often: Drive Mode, Self Timer, Focusing, AF Mode, Exposure Metering, Scene Mode, EVF-LCD (useful for power savings), Leica FOTOS.  Once you get used to using the camera, you'll know what functions you want quick access to.  I almost never change the Wheel button from ISO.
Seriously, dig into the user manual; there's a lot going.
Share this post
On the matter of battery life, be aware that a new battery will not reach full performance until it has been charged two or three times.
As others have suggested, sit down for a couple of hours with the manual in front of you and the camera in your hand.
Share this post
Use the center button in the 4-way controller to change the view mode. Each press cycles through the next mode. One of the views shows the battery level at the top right corner.
You may use the LCD to compose and shoot. There is a menu command EVF-LCD that lets you cycle through several options. I prefer EVF Extended, which keeps the LCD off in normal use but shows menus etc., when needed.
Share this post
Great answers in this thread so far. A couple more things:
User profiles:
  • all settings currently applied except for Aperture/Shutter speed (physical dials) will be saved when you save a User Profile. For example, if I were shooting at 50 ISO when I decided to create a User Profile and decided in my mind "when I select Profile 1, I want my ISO to be in Auto with a limit set to 1600 and a Minimum Shutter Speed to be set to 1/60th," If I made those changes via the Auto ISO Settings from within the menu, but forgot that I was still at 50 ISO while making all these changes, I would automatically be reset to 50 ISO every time I selected User Profile 1.
    • I would have to make all the Auto ISO changes like in my example (and whatever other changes I felt like making like favorites menu, button/dial assignments, etc.) exactly in the way that I would want them to be if I were to select Profile 1 on a recently-reset camera. To see if I like my profile settings, I'll make all of them and then select the profile and see if there's anything I'd change. The ISO example is one I always forgot about at first, hence me using it here. I would make all these changes to ensure that if I switched to one of my profiles, I'd be ready to shoot ~roughly anything and make small changes from there (like a specific ISO value). I would always forget that I made all these changes and saved the profile without actually putting the camera into Auto ISO at the end.
  • No. In full auto scene mode, you have no control over how the camera auto focuses, what the ISO is, and you definitely can't touch the screen to do anything but swipe and pinch-to-zoom during playback when reviewing photos. Specifically about auto-focus, the camera will always default to multi-point, guessing if the particular contrasty thing it focuses on is what you want in focus with every half press of the shutter. Face detect autofocus will kick in automatically if a face is in the frame 5-6ft away and closer however, which is pretty cool and useful.
  • You also can't change metering modes, white balance, or shoot black and white Jpegs (or change the way the jpegs look at all, for that matter)
  • You'd have to be more specific about when you get this window. I've gotten it trying to connect to the app, or near the end of a long exposure... maybe other times as well. Can you remember the scenarios in which you've seen this screen? You should not be seeing this while the camera is writing to disk.
  • The original Q had a function of touch+release focus, where you could touch the screen to focus, and as soon as focus was achieved, the camera would also take a photo. So far, this is not possible on the Q2. Could come with a firmware update, so I'm sure you have seen a video of it happening on a Q. Just not on a Q2 (yet.. hopefully soon!)
  • The Jpegs are there, but Lightroom is not treating them as separate photos. Check out this article on Adobe's website about how to change your file import settings: https://helpx.adobe.com/lightroom-classic/help/file-import-formats-settings.html. Look for where it says Treat JPEG Files Next To Raw Files As Separate Photos
  • Them being transferred (or not) to Leica Fotos has no effect on how Lightroom treats them. They are totally independent of one another, and sharing photos via the App will neither change the location of the Jpegs on the SD card nor prevent Lightroom from importing them.
I hope this helps!
*Edit*  Just realized you didn't specify whether you're shooting a Q or a Q2. All of the above applies to both cameras except the touch+release focus, which is only available on the Q (Typ 116) at this time. If that's the case and that's what you were hoping you could do like on your Canon 5dM4, then yes, it's possible.. That's what you need to do!
Edited by leicameech
one more thing..!
Share this post
Loading...
  • Similar Content
    • By KALBAR
      Hello.
      I have a problem.
      I have Leica 60 type 240.
      I have a non-original charger (nitecore)
      I don't know how old the battery is. The charger is new. I bought it a week ago. While charging the battery the EE message appears after about 10 seconds. Yes, I know the manual says it is short circuit protection but what causes the short circuit? The battery? All in all, it doesn't make sense to me. Maybe there is someone from Poland who reads this and lives in Gdansk, Sopot or Gdynia and could help me? Or you know what could the reason be. Some people wrote that it was the charger and they had the same problem and they say we have to use only the original charger. Unfortunately, I do not have the original Leica charger and I don't think I can get it quickly. I don't want to buy it. I have had the camera for 2 weeks. I wanted to take some pictures but as I can see there is no chance. Do you have any solution? I can’t get the battery or the charger here. Can it be charged any other way? Do I have to go to Leica Store Poland in Warsaw?
    • By Basti Hansen
      Hey Guys! I’m new to this forum since I got my Q2 today :) I imported DNGs to Capture One 20 and the colors are completely off - way way over saturated and shifting towards magenta right after import with no adjustments applied.
      In Lightroom the colors I see represent what I see in camera. What’s the reason for that? I read that capture one 20 deals with native DNGs just fine. Is there a fix for it? A setting I’m not seeing etc?
    • By peterv
      Hi everyone, just a quick question.
      I am planning to buy the new MacBook Pro 2019, should I go for 32 or 64GB RAM?
      I have already made up my mind that I will choose the fastest processor and the biggest graphic card.
      I am using Lightroom and Photoshop and you know, there are always a few Safari and Mail windows open, iTunes in the background, that sort of thing. I am replacing my mid 2012 MacBook Pro and I am hoping this new machine will last me another eight years, so keeping in mind that the machine should still be quite usable in say, five years time, 32 or 64 GB?
      I am hoping this new machine will last me another eight years 😊
      Thanks in advance!
    • By Ron Naeve
      The first time I charged my Q2's battery it went to the green "charge" light. Yesterday the battery indicator was red. so I charged it overnight. this morning both the green charge and the orange 80% are lite. does this mean it's not fully charging? I pulled it out and re-inserted it. the charge was blinking but then stopped after 5 minutes. the orange 80% is still lite.? to me this means it's stuck between 80-100%? ? Anyone else experience this?
    • By vk2109
      Hi I have just came back from a trip where i used my Q2 for the first time massively and when i am importing the color are just
      becoming totally off. I tried the trial of Lightroom CC Classic and it definitely can show the right color.
      See below screenshots. There were no adjustment made at all in all case.
      Anyone having similar color issue with the perpetual version of Lightroom ?
      Many thanks
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    No registered users viewing this page.
Important Information
