Q After a few shots, it warm up a little bit and don't record images when shoot.
Have anyone exp this:
I don't shoot my Q much ( not daily ), many be 1 times/week, the rest is i put it in the humidity closet.
Then i take out and go shooting, after couples of shot, about 20 30 shot, camera start warm up, seem it freeze from record images, you push the shutter button but actually they don't work, and all the images is not record from that moment ( when you start feel the cam is warm up).
Turn off the cam don't work, have to take the battery out and push back, everything is back to normal.
I've read somewhere else this issue cause by battery, or long times you don't use Q, then it freeze when use. is it right? Normal to Q?
Sometimes your camera is ok.   I think it is possible that your sdcard is causing problems.   If the camera is attempting to write an image to a bad card, the symptoms would be similar.   So.... you should put a fresh sdcard in the camera and immediately format it in the camera.    Then shoot and watch to see if the fault is still there.  If the fault disappears, you’ll know it’s your original card.  If the fault remains then it isn’t the card.
solving problems is best done by eliminating possibilities one at a time! Always test for faults with a fully charged battery.
what SDcards do you have.   (Make, size and speed)
have you formatted the cards in your camera?
Edited by lucerne
4 hours ago, Stephen_C said:
What is the temperature in the humidity closet and in what sort of temperatures are you taking photos?
Stephen
around 28-30*C. Humidity 35-40
Yes, i think the SD card problem. I just bough a new 128gb (150mb/s, normal sd card) sandisk and not format it before use.
Do you met this issue before?
Edited by dusuacangmong
You must format in the camera. That avoids problems like this.
3 minutes ago, jwillyf said:
I had a similar problem with my new Q P,  with an SD card that had been formatted in camera. Someone on this forum recommended the use of downloaded software called SD Card Formatter by Tuxera Inc. Formatting the same SD card in this way solved the problem.
Formate in camera......... sorted
Loading...
    No registered users viewing this page.
