justbananas #1 Posted September 1, 2019 Advertisement (gone after registration) On the cL, what’s your wireless flash trigger of choice? Quote Share this post Link to post Share on other sites
JayBird #2 Posted September 1, 2019 Fotos app. I have used it a few times on a trial basis with good success. I have yet to use it for anything I want to keep. We are off to Big Bend later this year, I want to be proficient with it prior to the trip. Quote Share this post Link to post Share on other sites
LocalHero1953 #3 Posted September 1, 2019 (edited) Godox Xpro (Canon interface). I mainly use it on the SL, but have used it with the CL. It's only defect that I can see is a sensitive on-off switch. Easily usable with a dial remote control of power on up to 5 flash groups. I trigger Godox AD200 and V850 strobes. Edited September 1, 2019 by LocalHero1953 Quote Share this post Link to post Share on other sites
LocalHero1953 #4 Posted September 1, 2019 1 minute ago, JayBird said: Fotos app. I have used it a few times on a trial basis with good success. I have yet to use it for anything I want to keep. We are off to Big Bend later this year, I want to be proficient with it prior to the trip. Flash trigger?? Quote Share this post Link to post Share on other sites
justbananas #5 Posted September 1, 2019 What if I want to trigger an sf-40 or just any no name off camera flash? Quote Share this post Link to post Share on other sites
justbananas #6 Posted September 2, 2019 And has anyone tried a Godox trigger with Godox strobes? And if so, which trigger? The Nikon version? Quote Share this post Link to post Share on other sites
LocalHero1953 #7 Posted September 2, 2019 Advertisement (gone after registration) 2 hours ago, justbananas said: And has anyone tried a Godox trigger with Godox strobes? And if so, which trigger? The Nikon version? See my first post above! Quote Share this post Link to post Share on other sites
justbananas #8 Posted September 2, 2019 5 hours ago, LocalHero1953 said: See my first post above! Duh, sorry for missing that. I also found another post where one used a Nikon version. I guess it's all done on the center pin anyway... I've been considering adding a Fujifilm for more professional lighted shoots, I wonder if the Fuji Godox trigger would work on both cameras. Or, I wonder if the Godox lights can be triggered optically... hmm Quote Share this post Link to post Share on other sites
LocalHero1953 #9 Posted September 2, 2019 1 hour ago, justbananas said: Duh, sorry for missing that. I also found another post where one used a Nikon version. I guess it's all done on the center pin anyway... I've been considering adding a Fujifilm for more professional lighted shoots, I wonder if the Fuji Godox trigger would work on both cameras. Or, I wonder if the Godox lights can be triggered optically... hmm I heard mixed stories on which version of the Xpro to get and checked the Canon version before buying it. Some of the uncertainty comes from other triggers (e.g. Pocketwizards) where you needed the right version: Pocketwizards in Canon shape didn't work - you needed the Nikon one. These mismatches may have been sorted now. Quote Share this post Link to post Share on other sites
ramarren #10 Posted September 2, 2019 21 hours ago, justbananas said: On the cL, what’s your wireless flash trigger of choice? I have an ancient Cactus V2 trigger pair and a slightly less ancient Cactus V5 trigger set. No dedicated anything, just simply RF triggers. They work fine on the CL (and have on every camera I've fitted them to since about 2008, but one: the V2 caused RF interference which somehow mucked with the sensor on one of my Panasonic bodies way back when). Quote Share this post Link to post Share on other sites
justbananas #11 Posted September 3, 2019 23 hours ago, ramarren said: I have an ancient Cactus V2 trigger pair and a slightly less ancient Cactus V5 trigger set. No dedicated anything, just simply RF triggers. They work fine on the CL (and have on every camera I've fitted them to since about 2008, but one: the V2 caused RF interference which somehow mucked with the sensor on one of my Panasonic bodies way back when). The cactus could work.. eventually I would like to be able to control the flash power manually from the unit on the camera. This would require a matched set I guess. Like Godox trigger to Godox flash/strobe... Quote Share this post Link to post Share on other sites
LocalHero1953 #12 Posted September 3, 2019 Check prices - buying a Godox controllable system was far cheaper than the simple Pocketwizard trigger/receivers I owned before. Remote control makes life easy: I switched systems when I wanted 2-3 strobes to illuminate a dance floor, with the lights on a balcony above the floor where I was with the camera. Quote Share this post Link to post Share on other sites
justbananas #13 Posted September 5, 2019 (edited) Ok here's what I've done. I ordered from Adorama this 2x Flashpoint (Godox) AD200 kit -. https://www.adorama.com/fplfev200bfa.html and a Xpro Canon controller ... I'll update how this works. Edited September 5, 2019 by justbananas 1 LocalHero1953 reacted to this Quote Share this post Link to post Share on other sites
justbananas #14 Posted September 15, 2019 I can double confirm this combo works perfectly on the cl. Godox 200ad and canon trigger. Quote Share this post Link to post Share on other sites
ramarren #15 Posted September 15, 2019 Good to hear it, thanks. That's more money than I suspect my flash needs justify, however. I'll probably stick with what I have and/or add the SF-40 to my kit eventually (so I can have one fully dedicated flash unit). I've only used flash with the CL on two occasions in the past year and some that I've owned the camera. Quote Share this post Link to post Share on other sites
justbananas #16 Posted September 15, 2019 Here's a test shot. I genuinely feel the off camera flash adds a lot of depth to shots that would other wise be rather flat in tone. Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 2 LocalHero1953 and LAHilltop reacted to this Quote Share this post Link to post Share on other sites
LocalHero1953 #17 Posted September 15, 2019 I would be surprised if it DIDN'T at depth compared to on camera flash! Quote Share this post Link to post Share on other sites
ramarren #18 Posted September 16, 2019 LOL! Of course it does ... There's little worse than 'on camera flash' to make a portrait look flat and banal. Quote Share this post Link to post Share on other sites
pico #19 Posted September 16, 2019 1 hour ago, ramarren said: LOL! Of course it does ... There's little worse than 'on camera flash' to make a portrait look flat and banal. An exception might be a well managed ring light. Google ring light portrait. Of the many examples we cam see a few where the photographer modulated the effect quite well. Quote Share this post Link to post Share on other sites
ramarren #20 Posted September 16, 2019 I tried using a ring light for portrait fill light some years ago. I found the effect somewhat unappealing to me; I don't pretend to be a master of the technique, but it didn't seem to me that light concentric with the lens axis was really the way to go after a few experiments. I'm sure others found a way to work it to their expectations/desires.... Quote Share this post Link to post Share on other sites
