Joe S Posted July 31, 2007 Share #1 Posted July 31, 2007 Advertisement (gone after registration) I understand that this lens is the same formula as the older screw mount version which has the reputation of being fairly soft in the corners. Sean's testing shows this very clearly. I recall someone posting that they have not found this to be true with this newer version. Can anyone report on their experiences with the new lens? Quote Link to post Share on other sites More sharing options...
Advertisement Posted July 31, 2007 Posted July 31, 2007 Hi Joe S, Take a look here Cosina 21/4 P Color Skopar M mount. I'm sure you'll find what you were looking for!
sdai Posted July 31, 2007 Share #2 Posted July 31, 2007 Joe, here're some new Skopar 21/4 samples shot with a R-D1 ... Color Skopar 21mm F4 P Samples with a R-D1 Quote Link to post Share on other sites More sharing options...
Shootist Posted July 31, 2007 Share #3 Posted July 31, 2007 I have one and I don't think it is soft anywhere across/top to bottom of the image. I don't have any to post right now but when I get home I will. Quote Link to post Share on other sites More sharing options...
ttriolo Posted July 31, 2007 Share #4 Posted July 31, 2007 Don't know about softness sdai but these show some major vignetting. Quote Link to post Share on other sites More sharing options...
sdai Posted July 31, 2007 Share #5 Posted July 31, 2007 ... but these show some major vignetting. Note these were shot with a R-D1 ... Quote Link to post Share on other sites More sharing options...
sean_reid Posted July 31, 2007 Share #6 Posted July 31, 2007 I have one for testing and will be able to do some comparisons when I get back to VT. Cheers, Sean Quote Link to post Share on other sites More sharing options...
carstenw Posted August 1, 2007 Share #7 Posted August 1, 2007 Advertisement (gone after registration) Those are on an R-D1 which is useless for comparing with the M8. The R-D1, being a 1.5 crop factor, doesn't use the corners which are supposedly soft on the M8. However, not having the offset microlenses that the M8 sensor has, it *adds* vignetting. We need some M8 shots here. Quote Link to post Share on other sites More sharing options...
Shootist Posted August 1, 2007 Share #8 Posted August 1, 2007 Here are 3. One I shot when I first got the lens and the other two are from last night doing some shots to test it. Shot on a very overcast day Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! f/11 f/5.6 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! f/11 f/5.6 ' data-webShareUrl='https://www.l-camera-forum.com/topic/30049-cosina-214-p-color-skopar-m-mount/?do=findComment&comment=318078'>More sharing options...
Mauribix Posted August 1, 2007 Share #9 Posted August 1, 2007 hi folks, just a question: is it coupled with RF? regards maurizio MAURIZIO BEUCCI.com - Official web site Quote Link to post Share on other sites More sharing options...
stunsworth Posted August 1, 2007 Share #10 Posted August 1, 2007 Yup, it's coupled. As was the previous screw mount version. Quote Link to post Share on other sites More sharing options...
Mauribix Posted August 1, 2007 Share #11 Posted August 1, 2007 Thanks a lot! i didn't know!.... now i'm waiting for some samples....let's see... Regards Maurizio MAURIZIO BEUCCI.com - Official web site Quote Link to post Share on other sites More sharing options...
prav66 Posted August 1, 2007 Share #12 Posted August 1, 2007 I compared it in the corners to my Zeiss 25/2.8 which is no slouch in corner resolution even wide open. I shot a flat surface & had to move forward to get comparable image captured of course, but I was astonished how sharp the lens was in the corners at f/4 Will post samples later, but the results are pretty obvious. On the other hand, the same test showed how weak my VC 28/1.9 lens was in the corners, expect I got a bad sample so sending it back for a replacement. Not sure how the new VC 21/4P is so good since it's the same optical formula from a lens with a reputation for blurry corners except to say I see no reason not to get the lens assuming it's a good sample unless one needs the extra stop of the Zeiss/Leica versions. Quote Link to post Share on other sites More sharing options...
sdai Posted August 1, 2007 Share #13 Posted August 1, 2007 Not sure how the new VC 21/4P is so good s Even when it keeps the old optical formula, Cosina could have done a lot of things with material, costing etc. all could contribute to a different end result. Quote Link to post Share on other sites More sharing options...
Guest V64 Posted November 11, 2009 Share #14 Posted November 11, 2009 Does this lens have a 'grooved' mount (like the latest Zeiss ZM lenses)? In several hours research I simply can't find the answer! Thank-you Quote Link to post Share on other sites More sharing options...
Shootist Posted November 11, 2009 Share #15 Posted November 11, 2009 Does this lens have a 'grooved' mount (like the latest Zeiss ZM lenses)? In several hours research I simply can't find the answer! Thank-you Supposedly the new ones, as all newer CV lenses, have the new style groved mount. The one I have deos not have it but then I bought it 2 years ago. Quote Link to post Share on other sites More sharing options...
