Sign in to follow this
Charadis
Saving a Visoflex 020
I recently found a super deal on a Visoflex 020 being sold by Adorama through auction listed as having major defects; the details described as "** Item Notes: Viewfinder does not switch back to LCD screen properly; Likely proximity sensor issue; May have other issues; Cosmetic condition is E **
However, the price was too good to pass up, less than half price of a brand new one. So I took a chance and bought it. When I received and tried it out, to my surprise, it worked, but there were green lines across the display. The lines went away when I angled the viewfinder to the max 90 degrees angle, but only temporarily. Issue returned when I adjusted the angle of the viewfinder again.
I spent the latter half of a Friday evening/night before I pinned the problem down to the LCD connection to the main board. I started disassembling the base module where the unit connects to the camera at the hot shoe. There are four screws at the bottom, then the top of that module can be lifted up and out. There is a swinging door with the tiniest spring that attaches to that top piece, very easy to lose. The door can fall off easily. The hot shoe connection can then be disconnected from the metal hinge assembly by removing two silver screws and pushing back the two plastic tabs securing the connector to the hinge plate.
To disassemble the main eyepiece module, the rubber eye "hood" or protector had to be removed; it is held in by double-sided adhesive at the top and bottom inside. Behind that, there are two screws left and right flanking the eyepiece that hold the upper and lower housing together. After I removed those, I spent a lot of time working the housing, trying to figure out if there were any other screws, or if adhesive or tabs were holding them together. Turns out, I took a chance and found out there is a tab on each of the three sides. The bottom comes off, and the main assembly is attached to the top housing.
The ribbon flex cable connecting the base module to the eyepiece main module had no signs of damage; connection was fine, and removing/reattaching it did not resolve the green-lines issue. There were no breaks on the flex. However, pushing the flex beneath made the green lines disappear temporarily. So I removed the mainboard from the top housing assembly, and found a misaligned connection between eyepiece LCD and the mainboard: see, the connection is crooked
It may have dislodged from the connector after a drop, or perhaps maybe it was never properly installed at the factory. Or maybe the continued adjusting/angling of the viewfinder furthered the loose connection? In any case, removing and reinstalling the connection made the green lines disappear and have not reappeared ever since I reassembled everything together.
I tested the eyepiece multiple times on my TL before reassembling everything back together.
Gotta say, I'm very happy with the viewfinder. Though it seems to pale in comparison to the viewfinder in my recently acquired CL, it is still a very welcome addition. And very fun to use. I'm not a serious photographer, but I'm slowly working my way into a new hobby..
Some background; I have repaired other people's smartphones in the not too distant past, and I collect and repair vintage Macintosh computers. After my experience with the TL, Leica cameras are working their way into becoming a new part of my collection.
Share this post
6 hours ago, nicci78 said:
Thanks for the insight.
Just make an iFixit tutorial next time 😉
Absolutely! I’ve never done a tutorial on their site before, but it is something I can definitely look into
Share this post
Hello all,
I left out one thing when making the original post because I was waiting for the seller's response before making a decision. Now, I'm just even more confused and paranoid, and not sure what to think at this point.
When I received the Visoflex, I didn't realize until later that the serial number had been intentionally rubbed out. Normally, this would raise a big red flag, but since I bought it from a renowned camera shop, I took things with a grain of salt and decided to shoot them a message hoping for a reasonable explanation.
After all, it had been marked as "for parts only," maybe they were voiding this from being serviced under warranty? In the auction listing, the serial number in shown in a photo, so why rub it out before sending? Here is the response I received:
Quote
Hi,
We are concerned about the missing serial # also. The pictures on the listing were taken of the actual finder in Dec.
The item was sold and returned as defective. Our procedure for returns obviously includes checking the serial #.
We now have doubts as to whether that procedure was followed and are looking in to it.
What is more mysterious is that we sent this to Leica for an estimate and they did not note a serial # on the paperwork but were more than willing to service it.
We'll provide more info as we get it but if you want to return it let us know.
Thanks
Best Regards,
This left me with more confusion than I thought I'd have. For one, what if the previous buyer replaced it with a stolen unit and rubbed out the serial so the company would not think it was swapped? But then the company could just report the sold unit as stolen (if they had actually caught it). Or maybe they just swapped it for a unit they legitimately bought just to get a working unit? The latter, I could probably live with, but if the former, that's where I'm wondering if it's just best to return it.
And how did they not catch this before shipping out? Didn't he just mention they keep track of serials on orders?
Is there any way to find the original serial on the unit, other than the label?
Edited by Charadis
Edited for clarity
Share this post
Maybe it was swapped under guaranty and they decided to sell it and not return it to Leica. In that case they needed to avoid to give you the opportunity to claim guaranty on the unit by the factory. In my experience, Leica Wetzlar will occasionally accept goods for guaranty in absence of a sales receipt, taking the date that  the gear was shipped (which needs a serial number) as warranty date.
Share this post
You mean the camera shop would swap a buyer’s purchase and resell the defective unit? You see, I was hoping it would be a similar circumstance where the shop had done that to void guaranty service, but their response left me confused because it seemed like they didn’t even know about it.
If you’re right, I can live with that. Ive lost on stolen goods before, not an experience I want to live through again.
If if I can find the serial to the unit I have, I can compare to the unit in the auction listing and see if it is the same unit at least
Edited by Charadis
Grammar
Share this post
Loading...
    No registered users viewing this page.
  • Similar Content
    • By nihilisation
      Hello everyone,
      I just spotted some white particles on the far edge/periphery of one of the lens element of my summarit 75 2.5 .
      I bought this lens used two months ago and at the time I could not see anything. I cannot say 100% but I suspect those particles were not present.
      They are hard to perceived. I only spotted them while taking pictures of my first born this morning when I was about to fit the cap onto the lens and had a look at inside.
      The sun was very bright and I could perfectly see them, them were almost shining like crystals ??
      Pictures are not affected at all and I am only worried for the case of a fungus. I do not care about dust, but this is the first time I see something like this, hence me asking for your help/advises.
      Because they are on the far periphery of the lens element they are hard to picture. For the pictures below I had to flash the front element with a led light and it creates some ghosts/artefacts.
      For instance you can see that this "line" of particles appears twice, mirroring itself onto the next lens element. They only appear on one side of the lens and I also pictured the other "clean" side as a reference.
      Pictures are not great but this is what I have for now.
      I Thank you for input and wish you a pleasant week,
      Best,
      Fabien
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By leicand
      I owe to Leica the opportunity of this image. In fact, a couple of days ago, the Leica Store of Rome, Via dei Due Macelli, gave me a Leica S with a 30-90 lens, for me to have fun for an hour. It was about sunset. So, I climbed up the Spanish Steps, and also the stairs of the Church of "Trinità dei Monti". And then, I waited ... As I was pointing at the shadow of the balustrade of the stairs and of myself taking the photo, a couple climbing the stairs of the Church entered my viewfinder. It was easy, then, to seize the moment.
    • By robsonj
      - Leica M Typ 240
      - Screen protector (already on the camera, the protector has some surface scratches)
      - ThumbsUp grip
      - Leather case (unused)
      - Olympus EVF2 (logo removed, see pic)
      - RRS M240 L Bracket
      - Battery
      - Battery Charger
      - Neck strap (unused)
      - Original packaging and documents
      Everything is in fully working condition. As you can see there is some brassing on the body. The EVF2 I purchased used, the previous owner had removed the Olympus logo. The EVF works perfectly, though I didn't use it very much. The base plate is in excellent condition, it along with the leather case have been stored in the original packaging unused, I used the RRS baseplate on the camera.
      Price includes PayPal fees and insured shipping via FedEx to CONUS.
      Shutter count is hard to know, from the numbering of my dog files I'd say its in the 5000-10000 range.
      Happy to take additional photos and answer any questions.
      I have many sample shots taken with this camera on my Flickr feed for reference... https://www.flickr.com/search/?user_id=26449190%40N00&sort=date-taken-desc&view_all=1&text=Leica M 240
    • By Andrk
      Hi guys,
      I am sure this topic is covered over and over again, but I can't help starting a new thread to help me out in a very difficult decision. It feels like a very difficult decision anyway.
      Some background: I have been photographing for the past 15 years, and for a few of those professionally. I have been a strong Nikon fan throughout (sorry for swearing in the church), but have also owned and used a lot of film cameras, such as Mamiya, Hasselblad 2000FCW, Canon and Nikon 35mm film cameras. I would say i am a fairly decent photographer with, maybe, a bigger passion and lust than talent. :)
      Two years ago soon my son was born, and I just didn't bring the big cameras with me any longer, and I missed capturing those moments. I stopped all professional photography to make time for family and my day job. I sold all my other cameras, DSLRs and film alike to buy a new, smaller, more handy one. That I actually would bring with me everywhere and take photos. I never bought one, and now I miss I so much. So I started the hunt for the best camera for ME.
      I have been googling, foruming all across, and I just don't know how to drill it down any further and decide on the actual camera to buy. One thing I do know is that it is going to be a Leica. I just love Leicas philosophy, the picture quality, the "to the roots" thing, and I have decided once and for all that now is the time for me to finally own a Leica.
      I also know that I am on a budget. Coming in at a total of 2000 USD would be ideal - but if course, Leica is not cheap and there are many factors here. So anywhere between 1000-3000 USD is something I look at.
      For that money you could buy either a Leica CL kit brand new, Leica TL2 brand new, a used Leica Q, used Leica M9.
      I am not a rangefinder guy really, but I really like the concept. However, I will use the camera for many different scenarios such as travel photo, family photo, art works that I do, and just general hobby/art photography.
      I don't do any studio work any longer, so that I don't need, I don't do street photography in that sense, and I don't to long tele situation photography like concerts or sports. So basically, I do everyday photography and would like my photos to be nice to have, maybe frame them, and if I find time again start taking art work photos again. But let's focus on travel, everyday life typ photo.
      Now - what do you guys think? Where should I place my bets? I guess many of you have tried many of the cameras - which one do you believe I will be happier with?
      Thank you so much! I appreciate all and any input!
    • By Winfoto
      Leica Q, neuwertig, inclusive Original-Verpackung zu verkaufen.
