lawman
Soft release
Small convex soft release   I use these on my M10 & Fuji X-Pro1, Ive tried more expensive & exotic ones (different woods) and even the bop & beep ones but keep coming back to these little cheap ones as they just work really well. They also come with rubber grommets to stop the release coming off.
Share this post
7 hours ago, Knipsknecht said:
I am using the ones from Lensmate. Originally they‘re meant for Fuji Cameras, but they fit my M9 and M10 pretty well.
The Softies from my M9 and M240 will not seat properly in my Safari M10P at all - I had thought that the thread size in the camera was universal - perhaps there is something wrong with the camera?  I have been told that the thread on the M240 is a tapered and different size from the M9 and M10 - anyone can confirm this? Thanks
Share this post
I too have tried the expensive ones from LensMate. After losing a few of them before I realized that you have to use some removable Loctite on the threads, I purchased a few of the same less expensive ones in the link posted. These work great and of nice quality.
I have the red one on my M10P and LensMate ones on my M10 and Fuji XT3. I used the o-ring, but you still need to use a dab of removable Loctite to keep them from losing them.
Regards,
Bud James
Please check out my fine art and travel photography at www.budjames.photography or on Instagram at www.instagram.com/budjamesphoto.
Share this post
Regards,
Bud James
Pretty interesting, as I haven't lost a single one of them over the last two years (used on a Fuji X-T2 and on a Fuji X100F, still in use on a Leica M9 and a M10). By the way, I am using the same one as you on my M10😎
Share this post
I tried softies over years again and again and all they did for me were black shots from inside my camera bag – analog as well as digital.
But apart from this I love my Jay Tsujimura tiger shark soft release (concave though).
Share this post
Exactly what problem is solved with these things?  Seems more like problem creation. I’ve never had an M shutter release issue using digital or film M models since the 80’s.
Jeff
Share this post
Jeff
Profit margin for the suppliers?
Share this post
Jeff
Just a personal thing. I like how they look and for me it feels much better to press the shutter.
Share this post
That is fine, and the late Tom Abrahamsson knew the subtle and fatal flaws of soft releases for various models, and he made the best. Abandon generics.
Share this post
Jeff
I have large hands so I find the soft releases allow me to actuate the shutter with first joint closest to the tip of my index finger instead of the tip of my finger.
Other than that, it's all about camera "bling"!
Regards,
Bud James
Share this post
1 hour ago, james.liam said:
No comments on the Leica soft release?
I use one of those and it works fine for me.
Share this post
I gradually press the shutter release with the fleshy part of the middle part of my forefinger and I find I can use lower shutter speeds than if I use the end of my forefinger in the 'hole'.  YMMV.
Pete.
Share this post
Am 15.8.2019 um 15:40 schrieb albertknappmd:
Leica Store Miami had many different softies. Speak to David or Josh. They will guide you!
Yes, sure. For top-priority jobs, always speak to the store owners or managers. A menial minion won't be able to guide you through the finer points of soft-release buttons :rolleyes:
Share this post
As I said speak to Josh or David....
The other people are not MENIAL MINIONS.. That is frankly insulting... They are hard working honorable people with varying degrees of knowledge, acumen and insight. I know this as I have spoken to several of them over the years.
However, Josh and David are super knowledgeable and are very happy to take all calls and take great pride in advising the customer.
Albert
Share this post
Loading...
    No registered users viewing this page.
