Does anyone know the size designation for an Allen wrench (if that is what is needed) to tighten the screws in the front part of the just-discontinued version of the Tri-Elmar 28-35-50?
Does anyone know a source for the tool?
Thanks!
--HC
HC, the screws holding on the accessory carrier on my lens are slotted, not hex, just like the screws on the aperture ring itself and around the lens barrel just in front of the bayonet mount.
It may be they changed to hex screws in later production.
I use Facom tools and their hex drivers go down to 0.9:
http://www.pro.facom.fr/CatalogueGeneral/Catalogue/PAG-CAT-05.aspx
[i see that link takes you to the French language site. If you back up to facom.fr, you can select English, then Electronic Tools and Screwdriver Sets]. Alternatively, you might try micro-tools].
Mark--
Thanks a lot; I'll check it out.
In a thread on how easy it is to lose them, a poster had said these screws were hex-head; that seemed a bit unusual to me as well.
I tried my smallest bladed screwdriver but was unable to get it to seat. The screws are so deeply recessed that I can only see that they're there (I think), but can't make out any details.
--HC
Update on this: I've just received a new coded second generation MATE (by an unusual route) and it has 3 hex screws holding the ring in front of the aperture adjustment. It looks as if the screws could be 1mm diameter or less, probably the 0.9mm Mark mentioned. The lens serial number is 39487xx. It's a replacement for an uncoded first generation lens, that one had slotted head retaining screws.
Bob.
  • 5 weeks later...
