Revisiting the light leak on the M cameras when taking a long exposure with the Naughtlux
Guys
Back in the day when I first got my first Noctilux and took some shots of a waterfall in Kashmir, I was horrified to see that there was a service light leek coming in from the bottom. After testing at home the outcome was that the Noctilux is too heavy for the M240 (at that time) bayonet connection causing a severe light leak...........I contacted Leica in Berlin and nothing more was said. What I did do after that was to use one of my wife black crunchy hair grip to put over the connection and that did the trick. I am now getting ready to head to Scotland and the Lake District and will hopefully see some nice long exposure opportunities. So my question to the gang is this Have any of you who own a M10 and Noctilux seen similar light leek when taking long exposures.
Neil
30 minutes ago, pedaes said:
If there is a problem it might be camera specific, so why not test before you leave. Why would you want to use the Noctilux for landscapes anyway?
Dreamy milky waterfall with a blurred background in broad day light that's why! 😂😂
All kidding aside, I could see it being used for shooting the stars maybe? Though I'm not sure if the softness at f/1 is worth the loss of 1 or 2 stops with say a Summilux or Summicron APO.
light leakage during long exposures is caused by the bayonet of the camera. Simply shield it of by using a rubber band or you're own hand. I use a tie-wrap around the lens and the bayonet and that solved the problem.
good luck
3 minutes ago, MarkP said:
Done to death Neil
min that thread years ago you started with M9 and No tilux
we all exoerinented and fixed it with black hair scrunchies around the bayonet
still never home without one
scrunchy it is then.........just wanted a chat really
Edited by Guest
4 hours ago, adan said:
You can jump off a cliff, I expect. Does that make it a good idea? ;)
No need to be jealous..................deep breaths deep breaths
2 hours ago, happymac said:
A picture would be worth a thousand words...
got to many
I don’t understand why Leica wouldn’t fix this problem though. I’ve sent an old 35CronIV for adjustments and CLA with my M10, they’ve found a crack on the lens code reading glass which i wasn’t aware of, and fixed it for free. So I’m surprised they don’t or reject to fix it.
I had my Noctilux snap off at the bayonet one time............sent back to Berlin from Kuala Lumpur and fixed for free within 2 weeks
Fabulous service
6 minutes ago, fatihayoglu said:
Why they don’t fix this light leak issue then?
I guess it can't be fixed.....saying that maybe my M10 has an upgraded light safe bayonet.......hence the new thread
Edited by Guest
Fabulous service
how did this happen? wouldn't have guess that possible. Curious to know!
I slipped while walking back from shooting a waterfall. The camera was around my neck but I am guessing that the jolt of me slipping was enough for it to detach itself from the bayonet that was still attached to the body.
