I am starting to carry a PowerBook G4 with me. It has both usb and firewire ports, but the usb ports are 1.1. This makes the file transfer slow as molasses.
I did a search on the web but no brilliant solution suggested itself to me.
Anyone recommend a firewire reader for SD (and other, but that doesn't matter) cards?
Bill, what about using a Sandisk 6-1 PC-slot card reader instead? I would think the PCMCIA card bus would be even faster or equal to the firewire-400 interface. I've been using the PC-slot for years for my CF cards and it seems faster than USB2.0; both of my recent notebooks have dedicated SD card slots built in. There doesn't seem to be many (I could only find 1) firewire card readers out there for SD...
best-John
John, the adapter looks reallyl nice (and inexpensive). Unfortunately, I have a 12" Powerbook and they don't have pc slots.
I'm not seeing a lot of the firewire adapters, either. Bummer.
The good news is that while the usb-1 port is (slowly) loading images (jpeg's only, of course) iPhoto allows me to start previewing them at the same time. I am just starting to play with this PB and it's pretty handy.
My G4 has a firewire 400 adapter and usb-1.1 adapters. I looked these guys up and usb 1.1. is 12 Mbps (Mega bits/sec) compared to f-400 at 400 Mbps.
If I got this right, I'll be getting a pickup of speed somewhere around 30 times? Of course, there's bound to be something that has to be taken into account going from 150x SD card thru the SD-to-CF convertor and whatever the G4 does with the firewire stuff going to the disk.
These things are in the $70-90 range.
Bill,
I have a 17" iMac of 2003 also with only USB 1,1 and Firewire and after a long search I managed to find here in Belgium the Addonics FireWire Mini DigiDrive. I'm very pleased with it and it should be no problem to find it in the USA I suppose. You can check the website http://www.addonics.com.
Limiting speed I guess is now the speed of my Sandisk Ultra II cards.
Best regards
Gerd
The Addonics Firewire Mini DigiDrive is discontinued i'm afraid.
http://www.addonics.com/products/flash_memory_reader/firewire_mini_digidrive.asp
Was a rebadged Amtron 1394 that i bought in 2004 and is discontinued as well.
http://www.amtron.com/reader/1394fisdmc.htm
Too expensive perhaps.
Great card reader anyway. I still use it daily for CF, SD and Memory Sticks. Doesn't work with Memory Stick Pro though.
