NEU: Leica V-Lux 5
Leica stellt heute die Leica V-Lux 5 vor.
Leica V-Lux 5 auf einen Blick
  • 20MP CMOS Sensor
  • Elmarit 24-400mm 1:2,8-4 ASPH Objektiv
  • Blendenbereich f/2.8-11
  • 2.36 MP OLED EVF
  • 0.74x Vergrößerung
  • 3" schwenkbarer Touchscreen, 1,24 MP
  • Touch Autofocus
  • 4k Video (24, 25, 30 B/s)
  • 4k Photo & Post Focus Modi
  • Akkukapazität ca. 440 Bilder
Leica V-Lux 5 Produktbilder
Technical Specifications Leica V-Lux 5
Camera name Leica V-LUX 5
Camera - effective pixels 20.1 megapixels
Image sensor 1″ MOS sensor, primary colour filter
Lens 16x optical zoom
Zoom range 9.1 mm to 146 mm
(equivalent to 25 to 400 mm in 35 mm film format)
Aperture range f/2.8 to f/11 (extreme wide-angle) - f/4 to f/11 (extreme telephoto)
Image stabilisation Optical
Focusing range AF: 30 cm (0.98 feet) (extreme wide-angle)/1 m (3.3 feet) (telephoto) to infinity
AF Macro/MF/Snapshot Modes/Video: 3 cm (0.098 feet) (extreme wide-angle)/1 m (3.3 feet) (extreme telephoto) to infinity
Shutter system Electronic shutter + mechanical shutter
Shutter speed Stills (with mechanical shutter): B (Bulb) (max. approx. 120 s), 60 - 1/4000 s
Stills (with electronic shutter): 1 - 1/16000 s
Video: 1/25 - 1/16000 s
1/2 - 1/16000 s (When [Exposure Mode] is set to [M] in Creative Video Mode and [MF] is selected)
Exposure Programme AE (P)/aperture priority AE (A)/shutter speed priority AE (S)/manual exposure setting (M)
Exposure compensation (1/3 EV steps, -5 EV to +5 EV)
Metering modes Multiple/centre-weighted/spot
Monitor 3.0″ TFT LCD (3:2) (Approx. 1,240,000 dots; field of view approx. 100%)
Touch screen
Viewfinder 0.39″ OLED Live Viewfinder (4:3) (Approx. 2,360,000 dots; field of view approx.100%)
Flash Built-in pop-up flash
AUTO, AUTO/Red-Eye Reduction, Forced ON, Forced ON/Red-Eye Reduction, Slow Sync., Slow Sync./Red-Eye Reduction, Forced OFF
Microphone Stereo (built-in)
Recording media SD Memory Card/SDHC Memory Card*/SDXC Memory Card*
* UHS-Ι UHS Speed Class 3
Recording file format Still: RAW/JPEG
Video: MP4
Audio compression format AAC (2 ch)
Interfaces Microphone (off-camera): 3.5 mm stereo jack
Remote: 2.5 mm jack
HDMI: Micro HDMI Type D
USB/charge: USB 2.0 (High Speed)/USB 2.0 Micro-B
Wireless IEEE 802.11b/g/n, Wi-Fi compliant WPA™/WPA2™, infrastructure mode
Bluetooth version 4.2
Hier die Pressemitteilung:
Leica V-Lux 5: So vielfältig wie das Leben selbst.
Wetzlar, 10. Juli 2019  Mit der Leica V-Lux 5 stellt die Leica Camera AG eine ihrer vielseitigsten Kameras vor. Ein besonders leistungsfähiges Zoomobjektiv und ein neu entwickelter, großer Sensor sorgen für eine ausgezeichnete Abbildungsleistung. Der brillante elektronische OLED-Sucher und das voll artikulierte Touch-Display auf der Rückseite gestalten die Komposition komfortabel und effizient. Durch den schnellen Autofokus und die hohe Serienbildgeschwindigkeit werden Details zuverlässig eingefangen. Innovative Aufnahme-Modi wie Focus-Stacking und Post-Focus bereichern den Funktionsumfang. Ergänzt um zeitgemäße und richtungsweisende Connectivity Features – in Verbindung mit der Leica FOTOS App – wird die Leica V-Lux 5 zu einer leistungsfähigen sowie universal einsetzbaren Kamera.
Egal ob Makro-, Weitwinkel-, Standard- oder Telezoomaufnahmen, das Leica DC Vario-Elmarit 1:2,8–4/9,1–146 mm ASPH. Objektiv (25 mm bis 400 mm KB äquiv.) der V-Lux 5 erreicht im Zusammenspiel mit dem 1 Zoll großen und mit 20 Megapixeln auflösenden Sensor eine herausragende Abbildungsleistung. Durch die maximalen Blendenöffnungen von f2.8 im Weitwinkel- und f4.0 im Telebereich, einer maximalen ISO-Empfindlichkeit von 12.800 und dem integrierten optischen Bildstabilisator lassen sich auch in Situationen mit wenig Umgebungslicht beste Bildergebnisse erzielen – selbst ohne Stativ.
Für die Bildkomposition und –kontrolle bietet die Leica V-Lux 5 optimale Werkzeuge: Der mit 2,36 Megapixeln auflösende elektronische Sucher wurde neu entwickelt und kann dank der verwendeten OLED-Technologie einen größeren Kontrastbereich und eine verbesserte Farbtiefe darstellen – bei gleichzeitig verringertem Energieverbrauch. Ergänzt wird der Sucher durch ein dreh- und schwenkbares 3“-Touch-Display. Mit ihm lassen sich Bildergebnisse nicht nur zuverlässig beurteilen, sondern auch Aufnahmen aus ungewöhnlichen Winkeln komfortabel umsetzen.
Damit der entscheidende Moment nicht verpasst wird, kann die Leica V-Lux 5 in ca. 0,1 Sekunden auf ein Objekt fokussieren. Bis zu 12 Serienbilder pro Sekunde sorgen dafür, dass Fotografen selbst bei dynamischen Motiven genug Aufnahmen erhalten, um die Besten für ihre Zwecke auszuwählen. Hilfreiche Funktionen wie Gesichtserkennung oder der 4K Burst Modus ergänzen zusammen mit innovativen Optionen wie Post-Focus und Focus-Stacking den Funktionsumfang der Leica V-Lux 5.
Doch nicht nur für Fotos bietet die Leica V-Lux 5 eine Vielzahl von leistungsfähigen Funktionen, auch Videoaufnahmen in höchster Qualität sind problemlos umsetzbar. Lebensecht wirkende Videos in 4K (3.840 x 2.160 Pixel) bei 24, 25 oder 30 Bildern pro Sekunde oder Aufnahmen in FullHD (1.920 x 1080 Pixel) bei bis zu 60 Bildern pro Sekunde bieten einen großen Spielraum für kreative Möglichkeiten in der Nachbearbeitung.
Die Leica V-Lux 5 unterstützt als erstes Modell ihrer Serie die Leica FOTOS App. Nachdem die Kamera per Bluetooth mit einem iOS- oder Android Smartphone verbunden wurde, kann die App dazu genutzt werden, die Einstellungen der Kamera vorzunehmen oder sie fernzusteuern – besonders praktisch, wenn sie nicht in Griffweite ist. Bilder können schnell sowie unkompliziert übertagen und dann bei Bedarf bearbeitet oder in sozialen Netzwerken geteilt werden. Zudem können GPS-Koordinaten vom Smartphone an die Kamera via Leica FOTOS aktiv übertragen werden. Auch eine Stromversorgung unterwegs ist kein Hindernis mehr, denn die Leica V-Lux 5 kann per USB geladen werden, zum Beispiel mittels einer Powerbank.
Die Leica V-Lux 5 ist ab sofort zu einer unverbindlichen Preisempfehlung von 1190,-- Euro erhältlich.
  • Replies 264
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Und welche Vorzüge gegenüber der Lumix rechtfertigen den (Mehr)Preis?
Komm mir keiner mit der europäischen Farbabstimmung. Bei RAW spielt das keine Rolle.
Ich hatte mir für eine Namibiareise die FZ1000 II gekauft und war sehr zufrieden.
Edited by gerd_heuser
vor 16 Minuten schrieb gerd_heuser:
bei RAW ...... aber bei JPEG :) es sei denn die Lumixer haben's endlich geschafft den Magentatouch rauszurechnen, zumindest für die EG-Version.
Leica zeigt auf der eigenen Website diesen Leistungsbeweis zur V-Lux 5:
und diesen hier:
Ist das ein Fehler oder meint Leica das ernst?
Oder ist das neue "Rauschkunst" und ich verstehe das nicht?
  • Thanks 3
vor 7 Minuten schrieb jmschuh:
und diesen hier:
Gerade deshalb mache ich um sowas einen Bogen.  Es wäre zu schön, wenn ein solches Teil einwandfrei funktionieren würde.
Hier ein Bild mit der Lumix, out of the box.
Da ist kein übertriebenes Magenta zu sehen, der rote Kalahari Sand kommt sehr natürlich.
Übrigens war der Nashornbulle drauf und dran unseren LandCruiser umzuschmeißen.
Endlich scheint die Leica FOTOS App dahingehend aktualisiert, dass sie GPS-Daten schreiben kann:
EDIT: wäre da nicht zu optimistisch, an der D-Lux 7 klappts bei mir aktuell noch nicht.
Die Leica App bittet auf dem iPhone auch nicht um Freigabe der Ortungsdienste...
Mit der Panasonic App und der FZ1000 II klappte es übrigens bereits vor Wochen auf Anhieb ...
@Leica: es nervt!
EDIT II:
Die Abfrage auf Freigabe der Ortungsdienste erfolgt erst, wenn ich die Fernbedienungsfunktion in der App starte.
Dann klappt es endlich. :wub:
Sorry, Anwenderfehler... :unsure:
Edited by Konqi
vor 1 Stunde schrieb jmschuh:
und diesen hier:
alle Beispiele von Colin Lau. Für mich sehen die nach Bearbeitung oder irgendeinem der internen Filter aus. Die Effekte sehe ich als wenig verkaufsfördernd. Sollte ein interner Filter verwendet worden sein, hätte darauf zumindest hingewiesen werden sollen.
Bildbeispiele von zwei weiteren Fotografen zeigen obigen Effekt zwar nicht, aber das eine oder andere zeigt nicht unbedingt Ergebnisse die man von einer so hochgelobten Kamera erwartet, Pana-Leica hin oder her. Bin mir aber sicher daß die Homepage-Fotos noch lange nicht die optimalen Leistungsbeweise zeigen. Z.B. sind von der V-Lux 114 weitaus bessere Bildbeispiele, auch hier im Forum, gezeigt worden.
vor 1 Stunde schrieb gerd_heuser:
Eindrucksvolles Bild. 400mm oder mehr?
Am deutlichsten zu sehen bei Landschaftsmotiven mit relativ großem Himmel-Anteil, soweit meine bisherigen Erfahrung mit Lumix G. Bei der GX80 korrigierte ich die A/B Achse des WB auf plus 1 nach B bzw. B:1. Die erste ohne Magentatouch ist die C-Lux.
Edited by C Lei Lux
vor 14 Minuten schrieb C Lei Lux:
Sieht mir danach aus dass der die Belichtungskorrektur unnütz nach unten korrigiert hatte und dann in Lightroom die Regler hochziehen musste.
Also hat erst der Fotograf nicht aufgepasst und dann später niemand bei Leica...
vor 11 Minuten schrieb Konqi:
Ja so sehe ich das auch. Vielleicht kam alles auf den letzten Drücker und mußte raus. > In der Ruhe liegt die Kraft < oder auch passend > Für Eile fehlt mir die Zeit < Buchtitel von Autor: Horst Evers. Beides nichts für heiße und/oder hektische Zeiten.
Edited by C Lei Lux
Korrektur
vor 3 Stunden schrieb jmschuh:
und diesen hier:
"Alles ist Kunst" sagte schon Andy Warhol. Und da fühlte sich Leica halt angesprochen. :D
Aber zum Trost, die Dinger können auch anders und das sogar mit noch kleinerem Sensor und das bei ISO 800. Licht natürlich vorausgesetzt.
KLETTERMAXE
Edited by Bernd1959
vor 3 Stunden schrieb EUSe:
Diese Kameras funktionieren mehr als einwandfrei. Schade das man in dieser Größe keine APS-C Kamera bauen kann. Dann könnte man den Rest von seinem Gerödel getrost in die Vitrine stellen. Ein Griff und auf gehts zur Weltreise. Von 25-1200mm, von einem Zentimeter bis Unendlich. ;) Bei Tag und Nacht (mit Stativ :D)
Edited by Bernd1959
