mickjazz Posted June 1, 2019 Share #1 Posted June 1, 2019 Advertisement (gone after registration) I have a black Leica standard with a chip in the viewfinder glass. As it is, it's usable but clearly visible. In the front glass. How are these repaired and who might do it? Quote Link to post Share on other sites More sharing options...
Advertisement Posted June 1, 2019 Posted June 1, 2019 Hi mickjazz, Take a look here Leica Standard Viewfinder Glass Repair. I'm sure you'll find what you were looking for!
willeica Posted June 1, 2019 Share #2 Posted June 1, 2019 1 hour ago, mickjazz said: I have a black Leica standard with a chip in the viewfinder glass. As it is, it's usable but clearly visible. In the front glass. How are these repaired and who might do it? I would leave it. If you want a clear view when using the camera an SBOOI or other relevant viewfinder would be my choice. William Quote Link to post Share on other sites More sharing options...
jerzy Posted June 1, 2019 Share #3 Posted June 1, 2019 I have done it once taking glass from old FED as a donor. Care shall be taken when removing replacement glas not to damage it, shall be carefully fitted and cemented in viewfinder. Quote Link to post Share on other sites More sharing options...
jerzy Posted June 1, 2019 Share #4 Posted June 1, 2019 Just to add , it was IA not Sandard which I repaired. But as far as I remember both have the same magnification, so it should work as well for Standart Quote Link to post Share on other sites More sharing options...
mickjazz Posted June 1, 2019 Author Share #5 Posted June 1, 2019 Thanks. The sbooi is a good finder but it adds size. Does anyone happen to know the characteristics of the front lens. Sometime back i had a iiif with missing oculars. I found a couple of lenses that were a reasonable match from a place called surplus shed that worked fine. I know surplus shed has square shape convex lenses. They are a few dollars. Quote Link to post Share on other sites More sharing options...
