Sign in to follow this
Stefflaurent
M10 rangefinder suddenly wont work
Hello, actually on a trip in London , m’y m10 rangefinder suddenly stop coupling with my lenses.
in fact, the little wheel wich get contact with the lens stays blocked on the infini. If I put it in thé right direction I can feel itsabnormaly hard to move.
what happened ? CAN Ifix it by myself -? Is there a place in London where it could be fixed ?
thank you for your help
Share this post
Leica Mayfair will be able to help. They also have a shop in the City. There are others such as Red Dot Camera. You need to look their locations up online.
Share this post
I reported an issue with the M10 roller assembly failing that apparently Leica is aware of. My camera had to be sent to Wetzler for this repair.
Maybe your issue is something different but regardless, I wouldn't mess with it yourself or waste any more time before sending it in.
Share this post
I had the identical problem on a once in a lifetime trip to Japan. In the middle on engagement photo shoot for my niece 😡.  Had to send it back, took months.  It works well now.   Hopefully it’s a one off.  My m240 and m3 never conked our on me.
Share this post
Sorry to hear the faulty M10.
As decades old Leica (or other brands ) user, so many times I was happy to have "second chance" or back-up gear.
Murphy's (10 versions)
With M10, if that is the only RF coupling and no other solutions left , I'd use LV or with wide angle lens as expensive p&s (no RF).
Share this post
Loading...
  • Similar Content
    • By ashley12234
      Hey everyone,
      I just got my m2 off ebay and had a look through the viewfinder only to see 2 main very noticeable spots. I attached a picture and the one on the lower left looks much dimmer and looks like a dot and a hair almost? It's kind of light greyish and I think it's a particle or dust but I'm not quite sure. However, in the middle the speck seems much darker (basically black) and more prominent. Could this be separation or is it another speckle of dust (imo it doesn't seem like one). If this has happened to you or you know what it is, any input on how to fix or your thoughts would would be greatly appreciated!
      Also the shutter curtain on the front seems a little pushed forward and I can see the whole seam on it, is that normal? The curtain works 100% fine but I'm not sure if Im supposed to see the whole seam and overlap of the two curtains. On the back it stays slightly open by 1mm or so (didn't include a pic sorry)... should it cause a light leak? The camera was also recently CLA'd.
      Lastly, the viewfinder has some "gold specks" which I think is separation, but I hope i'm wrong.
      Please help if you can clarify, recommend a fix, or give any thoughts on ^^. Overall the camera seems amazing and none of the things I mentioned has really bothered me, but if I can learn more about them then it would be great.
      Thanks in advance,
      Ashley
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By Yeedah
      Hi!
      I recently purchased a used Leica Q manufactured early 2018.
      When I try shooting in night, both "low iso + long exposure", and "high iso + short exposure" captured in DNG file shows annoying banding, and even some unwanted color points, like the images shown below.
      Is this a native camera issue? Or this camera sensor is defected : (
    • By shoots
      SOS HELP!!!
      I dropped my Leica M4 and according to the NYC Camera Doctor repair team, the prism that creates the ghost image in the rangefinder is dislocated and needs to be replaced. They suggested that I send it directly into Leica for repairs, becuase the rangefinder is a complicated mechanism they wern't equipt to fix. They also let me know that Leica, located in New Jersey, dosen't do specific repairs and will want to do a full tune-up. Money is a concern, and I'm not prepared to pay $1000-ish if I can at all avoid it. I just want my range-finder to be functional.
      Has anyone had rangefinder work done, espeically on an M4? Would you advise having this work done by Leica or an outside repair person, such as DAG? Any experience or suggestions would be greatly appreciated.
      E
    • By j.haden165
      Hi everyone, I've encounter a strange "bug" with my M2
      I took a shot, then cocked the shutter so i would be ready for the next shot, but I didnt fire right away but let it be. When I took the next shot after some times, the shutter speed seems to be slower than the speed indicate in the shutter speed dial
      I make some test shots at 1/125 and 1/60, cocked the shutter, wait for couple of minute, then click the button. When the m2 fire, i believe it was fired at 1/15 or 1/8
      I took one more test at 1/8, wait 3 minutes then fire, the shutter speed then fired at 1/4. The more i'd wait, the slower the speed. For example, 1 minute then it was slowered by 1 speed, 3 minutes for 3 speed... (not exact numbers)
      I've also tested to change the speed before/after advance the level, and before/after waiting for the next frame. But it seemed that the problem still remained
      I didn't have any trouble with the machine when clicked the button right after I cocked the shutter, but i really want to be always ready for the next frame.
      Have anyone encountered the same problem? Is there anyway to fix it?
    • By mrs_apeak
      Hello everyone !
      I just noticed that I have traces of wear on the hot shoe connectors of my leica Q2. I have used it only very rarely and with leica flashes. Has anyone noticed the same thing? Do I have to worry about it? Everything works very well but I still find it weird ..
      Thanks for your help !
    No registered users viewing this page.
Important Information
