My most used lens on my M10-P is the 50 APO Summicron which is 6 bit coded and always picked up by my previous M240-P.
I have my main menu lens detection set to Auto. It says, by detection that I have a 50mm f:/2 lens attached.
When I switch on the camera and look through the rangefinder it has frame lines for 135mm lens. This is rather confusing.
Luckily I still have reasonably good memory and can picture the scene fairly well. I have cleaned the 6 bit contacts on the lens and the camera.
Is this a known problem?
The lens is correctly clicked into place. The Menu says there is a 50mm attached, so the lens is being recognised by the 6 bit software. However, the frame lines are incorrect for a 50mm lens.
I doubt the camera's firmware but it has the latest level.
The frames are not activated by the code, but by the bayonet. It is a mechanical problem, not a software problem.
