Guest Posted April 4, 2019 Share #1 Posted April 4, 2019 (edited) Advertisement (gone after registration) Leica Monovid 8x20 as Tele Conversion Lens for Elmar 2.8-50. How to fix the monovid in front of the Elmar-M.2.8-50mm? If I hold it with the eyepiece inserted in front of the UV / IR filter of Elmar-M, then some telephoto shots succeeded, which might be even sharper if the photos were not taken by hand. And in the case of this three photos, they were taken on a moving ship. What is possible on a large scale with Televid and attached Leica camera should also be possible on a small scale with the Monovid in front of matching M lenses. In this case, the scored focal length should be 50mm x 1.33 Crop Factor of M8 x 8x magnification of the televid = 532mm. Is there a lens hood that could safely hold the televid? Or a clamping ring with thread E39, in which one could fix the Televid? 1. Televid 8x20mm in front of Elmar 2,8-50mm on Leica M8.2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited April 4, 2019 by mnutzer Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/295900-leica-monovid-8x20-as-tele-conversion-lens-for-elmar-28-50/?do=findComment&comment=3715622'>More sharing options...
Advertisement Posted April 4, 2019 Posted April 4, 2019 Hi Guest, Take a look here Leica Monovid 8x20 as Tele Conversion Lens for Elmar 2.8-50. I'm sure you'll find what you were looking for!
Guest Posted April 4, 2019 Share #2 Posted April 4, 2019 2. Same scenery taken by Elmar 2,8-50mm on Leica M8.2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/295900-leica-monovid-8x20-as-tele-conversion-lens-for-elmar-28-50/?do=findComment&comment=3715629'>More sharing options...
Guest Posted April 4, 2019 Share #3 Posted April 4, 2019 3. Televid 8x20mm in front of Elmar 2,8-50mm on Leica M8.2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/295900-leica-monovid-8x20-as-tele-conversion-lens-for-elmar-28-50/?do=findComment&comment=3715632'>More sharing options...
Guest Posted April 4, 2019 Share #4 Posted April 4, 2019 4. Same scenery taken by Elmar 2,8-50mm on Leica M8.2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/295900-leica-monovid-8x20-as-tele-conversion-lens-for-elmar-28-50/?do=findComment&comment=3715633'>More sharing options...
Guest Posted April 4, 2019 Share #5 Posted April 4, 2019 5. Televid 8x20mm in front of Elmar 2,8-50mm on Leica M8.2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/295900-leica-monovid-8x20-as-tele-conversion-lens-for-elmar-28-50/?do=findComment&comment=3715635'>More sharing options...
Guest Posted April 4, 2019 Share #6 Posted April 4, 2019 6. Same scenery taken by Elmar 2,8-50mm on Leica M8.2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! As a backpacker - especially in the Alps - I like to take only a little luggage. Since it would be very helpful to use the Televid as an additional telephoto conversion lens. Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! As a backpacker - especially in the Alps - I like to take only a little luggage. Since it would be very helpful to use the Televid as an additional telephoto conversion lens. ' data-webShareUrl='https://www.l-camera-forum.com/topic/295900-leica-monovid-8x20-as-tele-conversion-lens-for-elmar-28-50/?do=findComment&comment=3715643'>More sharing options...
ph. Posted April 5, 2019 Share #7 Posted April 5, 2019 Advertisement (gone after registration) Most innovative. I would assume tha you could find a filter-thread - M42 reversal ring plus some M42 extension rings quite cheaply at a camera fair. A little padding ought to steady the monocular and the combo would both be steadier and less exposed to stray-light. Slight centering problem, but still bette than hand-holding. p. Quote Link to post Share on other sites More sharing options...
Guest Posted April 7, 2019 Share #8 Posted April 7, 2019 Am 5.4.2019 um 20:41 schrieb ph.: ... Thank you, then I'll look after appropriate adapter rings for M42 at the next secondhand photo exhibitions. Incidentally, I'm sorry to have written a few times "Televid", where "Monovid" should have been. Quote Link to post Share on other sites More sharing options...
