Leica Summilux 50mm f/1.4 vs. Voigtlander 50mm f/1.2
Double_A
8 minutes ago, LarsHP said:
Interesting. What's the source of these spec's?
Review: Voigtlander 50mm 1.2 Nokton E - phillipreeve.net
May 8, 2019 — The actual (measured) focal length of the VM 50 is 49,2mm. Noticeably wider than, per say, a Summicron-M version 4 (52.2mm).
11 minutes ago, elmars said:
It gets obvious when You use the Nokton. There ist "more" on the photo than with Leica lenses of 50 mm.
Right.
1 minute ago, jaapv said:
Leica 50ies are often around 53.
Wow! That's new to me. I have seen Ken Rockwell saying that the little 00, 05 or 10 number next to the infinity symbol tells that the focal length of Leica M lenses are spot on, +0.5mm and +1mm respectively. If the actual focal length of Leica M fifties is around 52-54mm, then Ken Rockwell is sharing false facts.
Thanks. I have actually read that review, but forgot the info about focal length there.
49 minutes ago, LarsHP said:
Right.
The Summilux 50 asph is 51.6, older lenses can be longer, for instance the DR Summicron is 52.
  • 2 years later...
It's on film so nothing for the pixelpeepers, but in this shot the half stop made the difference between handheld or not handheld. I love the nokton 1.2 50 in every terms and the only thing that bothers me that the lux is a tiny little bit smaller, the nokton is really on the edge sizewise.
Edited by Sebastian S
