Dopaco Posted February 25, 2019 Author Share #21 Posted February 25, 2019 Advertisement (gone after registration) 10 hours ago, lct said: Es posible que desee hacer lo que hice durante más de 10 años. Olvídese de las baterías Leica originales, compre 4 o 5 baterías baratas de terceros y reemplácelas solo cuando estén completamente descargadas en la cámara . Funcionó bien para mí, pero no hay ningún daño que intentar de todos modos . That's what I'm doing, before charging the battery, I hope it runs out completely. Sometimes I force the algotamiento having the screen turned on. a greeting Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 25, 2019 Posted February 25, 2019 Hi Dopaco, Take a look here Which battery works well in Leica M8?. I'm sure you'll find what you were looking for!
pico Posted February 25, 2019 Share #22 Posted February 25, 2019 1 minute ago, Dopaco said: That's what I'm doing, before charging the battery, I hope it runs out completely. There is no advantage to draining a battery before recharging today. 1 Quote Link to post Share on other sites More sharing options...
jaapv Posted February 26, 2019 Share #23 Posted February 26, 2019 In fact, it is a good way to shorten battery life. You may need to do so once or twice to maintain calibration, but that is all. 1 Quote Link to post Share on other sites More sharing options...
Ko.Fe. Posted February 26, 2019 Share #24 Posted February 26, 2019 Better to buy original one. But if you are not willing to spend money on most expensive and made in China battery... I have "Original OTB", 20$ batteries. In M-E and I used them in M8. The only issue with M8 was continuous shooting. Those batteries not supporting it. At the second or third frame it was locking M8. To unlock it, fresh battery has to be inserted. 1 Quote Link to post Share on other sites More sharing options...
Dopaco Posted February 26, 2019 Author Share #25 Posted February 26, 2019 (edited) Hace 8 horas, Ko.Fe. dijo: Mejor comprar el original. Pero si no está dispuesto a gastar dinero en la batería más cara y fabricada en China ... Tengo "Original OTB", 20 $ baterías. En Mí y los usé en M8. El único problema con M8 fue el disparo continuo. Esas baterías no lo soportan. En el segundo o tercer cuadro estaba bloqueando M8. Para desbloquearlo, hay que insertar una batería nueva. Al final me decidí por la batería original de Leica ... ¿Cuál de los 3 comprarías? ... (Los 3 son nuevos y dicen ser Leica 14464). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited February 26, 2019 by Dopaco imagen Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/294547-which-battery-works-well-in-leica-m8/?do=findComment&comment=3691359'>More sharing options...
jaapv Posted February 26, 2019 Share #26 Posted February 26, 2019 Please use English, this is an international forum. Quote Link to post Share on other sites More sharing options...
Ko.Fe. Posted February 26, 2019 Share #27 Posted February 26, 2019 Advertisement (gone after registration) I guess question was about made in China. Latest Leica M9 batteries were sold with made in China label. Made in China is written on the opposite site. Surprisingly here is no pictures of this side... Quote Link to post Share on other sites More sharing options...
pico Posted February 26, 2019 Share #28 Posted February 26, 2019 13 minutes ago, Ko.Fe. said: I guess question was about made in China. Latest Leica M9 batteries were sold with made in China label. And the language that said 'made in china' was Russian. Quote Link to post Share on other sites More sharing options...
andyturk Posted February 26, 2019 Share #29 Posted February 26, 2019 I had good luck using off-brand batteries in my M8. As mentioned by another poster, it was best to use the battery until the camera said it was empty. Trying to charge one of the knock-offs when it wasn't flat often didn't work in my original Leica charger. The main issue I ran into over time was that the knock-offs "puffed" as the cells outgassed. They didn't leak, but the gas pressure bowed the plastic battery enclosure to the point where it wouldn't slide in/out of the camera. Fortunately, my original Leica battery didn't see much use and is still working today. Quote Link to post Share on other sites More sharing options...
Dopaco Posted February 27, 2019 Author Share #30 Posted February 27, 2019 On 2/26/2019 at 2:43 PM, jaapv said: Please use English, this is an international forum. I am sorry, It has been a mistake. The translation I do is through Google Translator: Quote Link to post Share on other sites More sharing options...
boojum Posted September 29, 2020 Share #31 Posted September 29, 2020 OK, I have a new, to me, M8.2 with a Leica battery. I bought two third party batteries from Amazon. The Leica battery ran down this afternoon. Like it just plunged from all bars to blank. No problemo. I popped in a third party battery and all was well. At home I turned on the camera with the Leica battery in it and with the battery saver feature turned off and made sure the battery was fully drained. I have done the same with the two third party batteries. Now that all three are fully discharged I put the Leica battery in the Leica charger to charge fully and will charge the third party batteries similarly after the Leica is charged. Battery charging procedure can be contentious. One car I drive is a hybrid Honda, a 2001 Insight, and the procedures for battery maintenance on that are a topic of discussion. Its batteries are LiIon also. And about every three months I charge them full, drain them to ~30%, charge to full, drain to ~20%, charge to full, drain to ~10% and then charge to full and hold that for about four to six hours. I have the computerized charge and discharge devices. And this is the accepted procedure for the car within the Insight community. I am adding the M8.2 manual factory instruction for their battery. It is remarkably similar to the regimen for Insight LiIon batteries. Whether anyone follows these instructions or not is your business. But from my experience with my car and the Insight community which has a few battery tech propeller heads and suggests a course of action similar to what Leica says, I'm following the instructions. YMMV "A new battery only reaches its full capacity after it has been fully charged and – by use in the camera - discharged again 2 or 3 times. This discharge procedure should be repeated every 25 cycles. To ensure a maximum service life of the battery, it should not be exposed to constant extremes of temperature (e.g. in a parked car in the summer or winter)." Quote Link to post Share on other sites More sharing options...
