I use a product called Unigel Turbo, which is a synthetic lightweight grease with micronised teflon. It is almost non-evaporating/has a very low vapour pressure, so does not evaporate and re-condense on glass surfaces. It has very high lubricity and is non-oxidising. I also use a cotton bud to put a wipe of it on lens mounts and filter threads. This is particularly important if you buy Heavy2Stars Leica filters/hoods/adapter rings, which seem very prone to binding in Leica filter threads. The Turbo Gel seems to eliminate this problem. The other place I have used it recently was on the very small screw in cap covering the remote electric shutter release port on my Motor-Winder R. This cap was very difficult to remove, where I had to use a Flexiclamp to unscrew it but after a tiny amount of gel on the thread, now unscrews with my fingers.
Wilson
I never lubricate the aperture ring.  And I definitely never take them apart because I don't have the patience to put them back together.  I just clean with lighter fluid (naptha).  I don't deal with automatic diaphragms, so I don't know how they would be lubricated.
Another good choice, often marketed as a bicycle lube, is by Finish Line. I do my own bike assembly so I always have a tube or two of this grease laying around. Works great.
