I have the SL and 90-280.
Used it to try and capture my dog running towards me as well as some soccer matches.
Success rate is 20% only despite setting my SL to the following settings:
High Continuous Shutter
Continuous AF
AF Tracking
High ISO
Shutter priority
So, maybe your hit rate may be better for basketball games.
Try these setting for starters:
ISO = AUTO (recommend setting the ceiling to 6400)
Continuous AF
Shutter Priority
Drive Mode : High Speed
Turn Auto-Review off - it's a distraction when you shoot action.
Auto Focus:  try Dynamic, Zone, and Spot to see which one works best for you.
File format:  record jpg to both cards or...DNG to Card 1 and jpg to card 2.  Don't record DNG to Card 2; it's too slow.
Make sure that the image stabilization is enabled.
If you want to freeze the action, start with a shutter speed 1/500 or 1/320.  See how sharp the shots look and adjust accordingly.  If you want a little bit of motion blur, you can play with slightly slower speeds.
It's not perfect for action but it does a decent job if you set it up correctly.  I've shot lots of action with my Canon 1D series cameras and, while my SL doesn't track as well as the latest generation of those, it does okay.  Have fun with it.  The jpgs can look great straight out of the camera.
Continuous AF
AF Tracking
High ISO
Shutter priority
If you want higher AF success rate, drop to medium continuous mode. At high, the AF is locked on first frame. By the way, the buffer runs out fast when you stay on high. I find medium a much better balance.
