Squiddly
Charging the C-Lux via a power bank
I just got my first Leica camera, a C-Lux. It's also my first camera which has a battery that can be charged via USB. I've tweeted Leica-USA and emailed them but haven't gotten a reply to this question yet.
Can I use a portable phone battery/portable charger/power bank type thing to charge my battery? The specs state that it needs to be plugged into a computer or the Leica charger, ONLY. But since the USB cable is standard USB-A, I would think it's fine to use the above, like you would use to charge a cell phone on the go.
Examples of what I mean:
https://www.amazon.com/dp/B07FMXGLS7/?coliid=IHP1U39J62AXA&colid=145UH80VAZUF4&psc=0&ref_=lv_ov_lig_dp_it
https://www.amazon.com/dp/B00EETOTWS/?coliid=I1FGNSK8RKWLNY&colid=145UH80VAZUF4&psc=0&ref_=lv_ov_lig_dp_it
Does anyone know for sure? Thank you!
Share this post
Someone from Leica answered me - and the answer was yes.
I was also wondering if the USB charger could be plugged into a normal power strip/extension cord. Normally I don't ask these kinds of questions for electronics but the manual was very specific - plug directly into a USB port on a computer OR plug the charger into the wall. I don't want to void the warranty or wreck the battery on this expensive camera. Thank you in advance.
Share this post
Loading...
    No registered users viewing this page.
  • Similar Content
    • By boojum
      I work mostly in the Linux side of the house even though I have W10. I prefer Linux.  It works.  However when I  plug the M8.2 into the USB port I do not get access to the SD in the camera.  I get a folder called RAMDISK and while that is nice, I suppose, it is not at all useful.  Are there any Linux users on this forum who are transferring images over the USB connection?  And if so, what is the secret?  I will work in W10 but prefer Linux.
      Thanks.
    • By Amyl
      Hi,
      Seems that my V-Lux 114 is read-only when using the USB - PC connection, independent of the software used.
      E.g. in W7 picture viewer, the delete button is disabled.
      With the SDCard removed and directly connected to PC, all files are read-write.
      This is not about single/multi file protection enabled on the camera itself.
      My issue is that it is better to review and delete unwanted files on a larger screen than first importing them to PC and delete them there. Of course, using a direct connection with the SDCard removed from the camera is a solution too.
      Does anybody know if the USB read-only mode is defined by design?
      Is it similar on other Leica cameras?
      Is there is a tweak to overrule file protection in USB mode?
      br,
      Andre
    • By clam2033
      This problem occurs with M9 and Monochrom.  If USB is set to PTP (no problem with Mass Storage), I can download all pictures via Lightroom 6 on a Mac Pro.  Everything is fine except when the downloading is finished, and I disconnect the USB cable, the camera M9 and MM hangs completely.  It can only be started if the battery is removed and then re-inserted.  Was just wondering if anyone else has noticed this same problem?
      Thank you in advance for any comment although my current solution is to use only USB Mass Storage.
    • By veraikon
      "Neu ist ein Multifunktionshandgriff-M mit integriertem GPS-Modul. So können Anwender beispielsweise den Aufnahmeort in den EXIF-Bilddaten speichern (Geotagging), um die Bilder später entsprechend zu sortieren und anzuzeigen. Um an der Leica M gleichzeitig ein unabhängiges Blitzgerät und einen externen Sucher zu nutzen, verfügt der Multifunktionshandgriff-M über einen SCA-Anschluss, der mit der Kamera auf dieselbe Weise kommuniziert wie ihr Blitzschuh. Hierfür steht zusätzlich das Leica SCA-Adapter-Set zur Verfügung. Dieses besteht aus einer Blitzschiene und einem Spiralkabel mit Blitzschuh. Außerdem ist der Multifunktionshandgriff mit einem Anschluss für die externe Stromversorgung und einem DIN/ISO-X-Synchronisations-Anschluss für Studioblitze ausgestattet. Dazu ist ein optionales Netzteil erhältlich. Über den USB-Anschluss des Handgriffs lässt sich die Leica M direkt an einen Rechner anschließen. Mit der Software „Leica Image Shuttle“ ist dann die komplette Fernsteuerung der Kamera und die Übertragung der Bilddaten per USB-Kabel mit dem Rechner möglich. Zudem unterstützt der Multifunktionshandgriff-M den sicheren Halt der Kamera, insbesondere bei der Verwendung der schweren R-Objektive. Mit optionalen Fingerschlaufen in verschiedenen Größen (S, M, L) kann die sichere Anwendung der Kameraausrüstung zusätzlich noch verbessert werden. Diese lassen sich auch zusammen mit dem Handgriff-M ohne Zusatzfunktionen verwenden, der ebenfalls optional angeboten wird."
      Multifunktionshandgriff-M schwarz 14495
      Leica Camera AG - Fotografie - MULTIFUNKTIONSHANDGRIFF-M
      Für M-E Käufer eine Möglichkeit den USB Anschluss nachzurüsten
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By sketchguy
      It's been a few years since I created time-lapse Quicktimes with my D2, so I thought I'd check to see if there's been an update to the USB Remote Control software.
      Leica Camera AG... .../compact_cameras/digilux_2/index.html
      The latest version (1.2) found at the above link installs, but fails to actually startup under OS X 10.5.6
      It's a shame this hasn't been kept up-to-date for OS X. Are there any alternatives for controlling the D2 via USB on OS X?
      Thanks,
      -Steve
