Fedro Posted November 6, 2018 Share #1 Posted November 6, 2018 Advertisement (gone after registration) I have noticed that when I don't use the 50 Lux (ASPH) for a little while (say a couple of weeks) the focus ring gets stuck and I have to use a little force to get it to rotate again. This seems to happen when I leave the lens at infinity but will check if other positions also create this issue. The lens seems otherwise fine optically etc I have not noticed this with any other lens (including a 50 Lux I had years ago) so was wondering if this is just need for a CLA or something more serious Thank you Fedro Quote Link to post Share on other sites More sharing options...
Advertisement Posted November 6, 2018 Posted November 6, 2018 Hi Fedro, Take a look here 50 Lux focus ring gets stuck when not in use. I'm sure you'll find what you were looking for!
lct Posted November 6, 2018 Share #2 Posted November 6, 2018 Focus rings can feel stiff if they have not been used in a while. I would rotate the focus ring a few dozen times and check if this is enough to loosen it. Otherwise a CLA could be in order. Quote Link to post Share on other sites More sharing options...
Fedro Posted November 6, 2018 Author Share #3 Posted November 6, 2018 Thank you. It actually really gets stuck rather than stiff but then once it unlocks it is perfectly normal and smooth .. weird Quote Link to post Share on other sites More sharing options...
