epand56
Flat Field doesn't work with OSX Mojave
Anybody experience the same?
Before upgrading my Mac Book Air to OSX Mojave, Flat Field was working great.
This morning I updated to OSX Mojave 10.14.
After that, I had to clean some files with the Italian flag from my CV 15 V. II and (to my dismay) discovered that Flat Field wasn't working.
It does the cleaning process, but at the end doesn't deliver the "ff" file. So, no correction at all.
Anybody here experienced the same and has a solution?
Thank you for attention.
Best regards,
Enrico
Share this post
Mojave has turned out to be frustrating.  Have you contacted Ximea customer support?  (If you updated today, you should have 10.14.1, not 10.14.)  The only workable answer right now seems to be to reload High Sierra.
Share this post
Hi Enrico-
Just tried running FF on some old M9 + CV15 Mk.I files on my iMac with LR Classic CC 8.0 on Mojave 10.14.1, and it worked just fine (indeed rather a lot faster than it used to, in my experience: close to "blistering" speed I'd say).
Do you have the latest version of LR on your machine? I'm surprised if you downloaded Mojave this morning and got 10.14, as 10.14.1 came out a couple of days ago.
Hope this helps
Jim
Share this post
On 11/1/2018 at 4:00 PM, Jim-St said:
Hi Enrico-
Hope this helps
Jim
Hello Jim, yes I have the last downloadable version (6.14 maybe). I did some try and yes, it works, but while before the "ff" files would appear directly in the folder image directory, now you have to synchronize the folder. Thanks for your help.
Enrico
Share this post
Hi Enrico
I assume by now you must have restarted your computer without that solving the problem. Have you looked on the Adobe forum or Lightroomforum.net (now on Victoria Bampton's site here? If no-one else is reporting the problem, the next step would probably be to reset the Preferences for LR. You can read about how to do that, and the possible knock-on effects of doing so, here. It's a bit "last ditch" but all I can suggest
Jim
Share this post
Loading...
    No registered users viewing this page.
  • Similar Content
    • By nondas.gr
      I 'm using my dlux-6 with Apple Aperture and i 'm having an issue deleting my photos from the SD. After copying my photos to the program, Aperture asks me if i want to delete them and eject the disk. I confirm but nothing happens:confused:. The only way is to delete/format the SD from within the camera (annoying)...
      Today i noticed that i don't have permission rights on any SD i connect with the camera (read only) but from a card reader i have no problem
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! . I tried various solutions but nothing yet. Anybody with Dlux6 and OSX can confirm this? Thanks
    • By erg
      These are some of my impressions with the M9 from a bike tour through the Mojave Desert. I really love the landscape and lights of this region.
