johnbuckley Posted October 29, 2018 Share #1 Posted October 29, 2018 Advertisement (gone after registration) I own the M lens Macro Adaptor, which is, in my experience, usable really only with a tripod. Can someone explain the difference between the new Elpro and the Macro Adaptor? Related: can you use the Elpro to take pictures of items close up without having to use a tripod? In advance, I appreciate the replies. Quote Link to post Share on other sites More sharing options...
Advertisement Posted October 29, 2018 Posted October 29, 2018 Hi johnbuckley, Take a look here Differences between the Elpro and the Macro Adaptor. I'm sure you'll find what you were looking for!
luigi bertolotti Posted October 29, 2018 Share #2 Posted October 29, 2018 (edited) It's a difference of principle : the M Macro adapter is an extender for (any, in theory) M lens, so mounting it the optical system does not change : only the minimum focus distance is reduced. The Elpro (a longtime Leitz brand name… ) is an additional lens (a couple of, indeed) to be mounted in front of a standard lens : so, the optical system does change, and the effect is the same : a shorter distances' range. The Macro adapter, being extensible, gives a wider range of focusing, suppose the same focal mounted : you have a longer focus throw (lens + extender helicoid) than with the Elpro (lens focus only). About the comparision of quality … an endless discussion can arise… .. there are several combinations (with both devices) to achieve the same image ratio… About the tripod need : imho is invariant from one device to the other : need for tripod is commanded by enlargement ratio : with any system, none can take a 1:1 macro with, say, 1/30s Handheld… but I have used the Macro Adapter at 1:2 around… at 1/125 - 1/250 with a decently unblurred image… Of course, other Macro Devices are even more tripod - tied (one CANNOT use a bellows Handheld… ) and those two Solutions are really light and transportable. Edited October 29, 2018 by luigi bertolotti 2 Quote Link to post Share on other sites More sharing options...
johnbuckley Posted October 29, 2018 Author Share #3 Posted October 29, 2018 Luigi - bless you. Just what I needed to know. Many thanks. Quote Link to post Share on other sites More sharing options...
lct Posted October 29, 2018 Share #4 Posted October 29, 2018 I have no experience with the new Elpro but i can say it is a additional lens with no focus ring contrary to your macro adapter which has no lens as you know. As for needing a tripod, i have never used one with my macro adpter i must say. But i use it mainly with 90mm lenses for handheld shots like this: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/290997-differences-between-the-elpro-and-the-macro-adaptor/?do=findComment&comment=3622025'>More sharing options...
johnbuckley Posted October 29, 2018 Author Share #5 Posted October 29, 2018 You must stand more steadily than I do 🙂 Quote Link to post Share on other sites More sharing options...
lct Posted October 29, 2018 Share #6 Posted October 29, 2018 14 minutes ago, johnbuckley said: You must stand more steadily than I do 🙂 Could be better and worse i guess but did you try with a 90mm lens actually? Quote Link to post Share on other sites More sharing options...
johnbuckley Posted October 29, 2018 Author Share #7 Posted October 29, 2018 Advertisement (gone after registration) No. I've been trying it with my 50. I'll try with the 90. Many thanks. Quote Link to post Share on other sites More sharing options...
albertknappmd Posted November 1, 2018 Share #8 Posted November 1, 2018 Elpro if used correctly will need a tripod unless you are a Vulcan... Albert 😂 Quote Link to post Share on other sites More sharing options...
