FlashGordonPhotography Posted October 11, 2018 Share #21 Posted October 11, 2018 Advertisement (gone after registration) 7 hours ago, PCPix said: Hi Gordon - the guy wants to change his batteries more quickly. Long and short straps are a different method that help achieve that. It's a valid alternative. It's this bit I have a problem with.... "Holster sling contraptions are for poseurs who think they are military heroes." Not all sling strap users are poseurs. I can assure you of that. Gordon 2 Quote Link to post Share on other sites More sharing options...
Advertisement Posted October 11, 2018 Posted October 11, 2018 Hi FlashGordonPhotography, Take a look here Dual Camera Harness for M10. I'm sure you'll find what you were looking for!
chris_tribble Posted October 11, 2018 Share #22 Posted October 11, 2018 Strongly recommend the longer strap + shorter strap combination - cross body for one and either over shoulder or round neck for the other. It's minimal and works. I've used this for long (all day documentary shoots) and for intensive theatre / performance work. This setup is usually combined with a 5D4 + 70-200 f2.8 L lens + monopod! Obviously I can't use all three at the same time and the Canon gets left in a safe place or handed to a friend / assistant when it's not needed. Works for me - and has done for years.. Quote Link to post Share on other sites More sharing options...
douglas fry Posted October 11, 2018 Share #23 Posted October 11, 2018 (edited) I use two rangefinders shooting weddings and social events, I prefer to have one on each shoulder, stuck there by 'upstraps' the thinnest version, the bobbled pad is incredible at sticking to your shoulder and no matter what you are wearing it stays there..(both the same length by the way) http://www.upstrap-pro.com/category/camera-straps-full-list.html Edited October 11, 2018 by douglas fry Quote Link to post Share on other sites More sharing options...
photophile Posted October 12, 2018 Share #24 Posted October 12, 2018 (edited) I have carried / still carry my M's ( M4-2, M6, M8 and M10) using only a single side ring - not the tripod thread. I just use some mountain climbing webbing ( 1" ) sown together at the ends to make a continuous loop (worn bandolier style) and a double sided slide to adjust the length as needed. I used to worry that the pin might break or come loose. 15 years later...never an issue and I am an active documentary shooter who uses the camera as a daily tool. The camera hangs , when not in use, from the ring which slides easily up when needed. The webbing does not need to slide as the ring slides on the webbing. This way, a second camera is easily hung from the other shoulder and there is enough play that they do not cross. Both are rapidly, securely and easily accessible. And...it remains comfortable for hours. ( My face transplant project was a 36 hour long shoot - yes, non-stop - and the strap(s) as described worked perfectly. I used multiple leica M's and a Nikon D3s for the project - two crossed loop leicas at all times and a standard neck strapped nikon). For what its worth... There are other solutions of course. www.thetwofacesofrichard.com Edited October 12, 2018 by photophile Quote Link to post Share on other sites More sharing options...
ru2far2c Posted October 12, 2018 Share #25 Posted October 12, 2018 On 10/10/2018 at 5:46 PM, SMAL said: Dude, that´s THE solution. Thanks. That Luigi Website cracks me up every time. http://www.reallyrightstuff.com/M10-Plates?quantity=1&custcol36=1 this may be another option for you as well..... Quote Link to post Share on other sites More sharing options...
pico Posted October 12, 2018 Share #26 Posted October 12, 2018 (edited) You might look into the Chest Packs used by photojournalists who carry gear forever. You can surf them out yourself. Here is only one. I prefer black. Edited October 12, 2018 by pico Quote Link to post Share on other sites More sharing options...
