carbon_dragon
Is DNG format specific to a camera
I'm currently using Apple Aperture for my Leica M9 but as Apple no longer supports it, it's only a matter of time before I will have to convert (maybe to Capture One). In the meantime, should I buy an M10, will it's DNG files be readable by Aperture even if Apple no longer adds support for new cameras. Note I'm not positive Apple isn't doing this, but it would kind of be typical so I'm kind of assuming this is true.
In other words, will buying an M10 mean an IMMEDIATE conversion to another program?
Thanks.
Share this post
The DNG format specification is not specific to a camera. However, cameras that produce raw files in DNG format do include a specific set of metadata for the camera ... camera brand and model name, a camera color profile (CCP), etc. Earlier versions of Aperture would not open DNG files for which Apple did not have a supported CCP file; I'm not sure that this is true even to the last incarnations of Aperture but I would not be too surprised if it is.
Similarly, Apple's implementation of DNG is incomplete in that it never supported the DNG linear format, often used by scanner software and some DNG conversion utilities (for instance, the Iridient DNG converter designed for Fujifilm XTrans sensor data).
The good news is that there are several good choices in image processing software that can replace Aperture: of course there's Lightroom and Photoshop (particularly if you don't mind being a subscriber to Adobe's services), but there are also Luminar and Affinity Photo, Iridient Developer, Capture One, etc ... amongst others. All of these are very good raw converters and image processing tools, albeit all have their own strengths and weaknesses just as Aperture does.
On macOS, I've been using Lightroom 6.14 (the last perpetual license version) for a while now and learning Luminar 2018 as preparation for when Lightroom 6 can no longer run on macOS and needs an upgrade to Lightroom CC ... because I don't like to join yet another subscription service. Luminar performs quite well, better than LR in some ways and not quite up to the same level in others. I've also found that the latest revisions of SnapSeed and Affinity Photo on the iPad Pro do an amazingly good job with my M9, M240, M-D262, SL, and CL DNG files, never mind all my JPEG and TIFF files.
Ya just gotta keep moving forwards.
Share this post
My leica Q files are readable by Aperture even though the Q debuted long after aperture was retired.
Share this post
Aperture uses the system-based "Raw camera" conversion framework dynamically, so it's conceivable that the last versions of Aperture will get compatibility for free since that framework is regularly updated still for Photos, Preview, and other app utilizations. But you can't bet on it.
Probably the best thing to do to be sure is to just hunt up an M10 or M10-P DNG file from the net and then attempt to import it into Aperture. If it is imported, you're good and you don't need to worry about moving to new software yet.
Share this post
Loading...
    No registered users viewing this page.
  • Similar Content
    • By Holger1
      RESERVIERT   Verkaufe aus Sammlung eine Leica M 10 silber. Die silberne Version ist vom Werk her ausverkauft. Die Kamera ist sehr wenig benutzt worden und hat zwei minimale Gebrauchsspuren. Das Display und der Sucher sind frei von Kratzern. Der original Leica-Akku ist dabei, die Kameraschatulle, sowie ein unbenutzter Tragegurt, ein Ladegerät, Anleitung und mehrere Kabel. Mit dabei ist das 224 Seiten starke Buch "Leica M10" von Michel Birnbacher. PDF als Leseprobe: https://www.franzis.de/media/pdf/3c/b0/d5/60648-6_LP_Kamerabuch-Leica-M10.pdf?sPartner=1134 Dies ist ein Privatverkauf- I send only within EU.     FOTOS-- weiter unten! bitte runterscollen
    • By UltraDan
      I have posted this on the M240 forum but thought I'd ask the same question here as well as it's relevant to this forum :
      Question to those that have used or have both of the above cameras - is there much IQ difference between the two? I'm guessing that the M10 just has slightly better ISO performance?
      looking at both of these and struggling to find a reason to pay the extra for the M10 other than it's the latest and greatest.
      thanks
    • By UltraDan
      thanks
    • By scroy
      The camera is used, and was CLA'd by Leica NJ in June 2020 [PCB replaced, rangefinder adjustment, clean]
      Selling with all original accessories, box, papers.
      Selling to finance an M10-R.
      Paypal [Please add fees or send by "Friends and Family"], Venmo, Zelle payment.
      Price 4000 USD
      Selling from USA (Boston, MA), Shipping: 2 Day, Insured to US: $100.
    • By Johnclare369
      Hi all
      I've not used flash very much apart from as fill-in for portraits, but I have an upcoming project that may require a little more of it. I have a Leica SF40 flash which I know can work as a slave when combined with the right master unit.
      Any suggestions as to what the right master unit would be?
      Thanks.
