quixotic Posted August 25, 2018 Share #1 Posted August 25, 2018 Advertisement (gone after registration) Does anyone know how easy or difficult -- or impossible -- this might be? (I see some examples on ebay which are significantly less expensive than their otherwise identical R brethren). Thanks in advance. Evan Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 25, 2018 Posted August 25, 2018 Hi quixotic, Take a look here Schneider lens with Nikon F mount to R body?. I'm sure you'll find what you were looking for!
dkCambridgeshire Posted August 26, 2018 Share #2 Posted August 26, 2018 (edited) Not possible because the Nikon F flange distance is less than the Leica R flange distance … all explained in Wiki https://en.wikipedia.org/wiki/Flange_focal_distance … Nikon F flange distance is 46.5mm; Leica R flange distance is 47mm; theoretical adapter to maintain infinity focus is thus 46.5mm minus 47mm = minus 0.5mm … which is impossible OTOH if you had a Hasselblad V series, Mamiya 645 or Pentax 67 medium format lens which all have relatively long flange distances i.e. in excess of 47mm, you'd be in luck because Leica R adapters are available. If you have a Leica R bellows it would be possible to adapt a Schneider enlarging lens to same and focus the lens using the bellows' rack and pinion … and which might be suitable for portraiture using Schneider 80mm or 75mm enlarging lenses … but sorting or making the adapter could be difficult. Which Schneider lens in non-R mount did you have in mind and for what specific type of imaging? dunk Edited August 26, 2018 by dkCambridgeshire Quote Link to post Share on other sites More sharing options...
masjah Posted August 26, 2018 Share #3 Posted August 26, 2018 Just one minor caveat to what Dunk says. Historically at least one Schneider lens was available with both Nikon and Leica mounts, but as Dunk implies, it's necessary to replace the whole mount itself.The best known example is the Leica R 28/2.8 PC Super Angulon, which was actually produced by Schneider for Leica. It was also available under the Schneider badge for Nikon, and I have seen examples on the second-hand market with Nikon and Leica mounts both bundled in. There was obviously enough scope in the design of the lens and the two mounts to accommodate the odd half millimetre. I understand that it was relatively straightforward to swap the mounts, as there was no automatic diaphragm and stop-down mechanism actually coupled through the mount. Quote Link to post Share on other sites More sharing options...
quixotic Posted August 26, 2018 Author Share #4 Posted August 26, 2018 Just one minor caveat to what Dunk says. Historically at least one Schneider lens was available with both Nikon and Leica mounts, but as Dunk implies, it's necessary to replace the whole mount itself.The best known example is the Leica R 28/2.8 PC Super Angulon, which was actually produced by Schneider for Leica. It was also available under the Schneider badge for Nikon, and I have seen examples on the second-hand market with Nikon and Leica mounts both bundled in. There was obviously enough scope in the design of the lens and the two mounts to accommodate the odd half millimetre. I understand that it was relatively straightforward to swap the mounts, as there was no automatic diaphragm and stop-down mechanism actually coupled through the mount. Hmm. That's precisely the lens I'm thinking of. The ones with the Nikon mounts always seem to go for several hundred dollars less than the R-mount variants. I suspect that trying to find a stray mount for the conversion might be difficult, though (?) Quote Link to post Share on other sites More sharing options...
masjah Posted August 26, 2018 Share #5 Posted August 26, 2018 Hmm. That's precisely the lens I'm thinking of. The ones with the Nikon mounts always seem to go for several hundred dollars less than the R-mount variants. I suspect that trying to find a stray mount for the conversion might be difficult, though (?) Very likely true! (Unless it turns out that one of the standard R lens mounts might fit, but I've no idea in that sort of detail.) Quote Link to post Share on other sites More sharing options...
wpo Posted August 29, 2018 Share #6 Posted August 29, 2018 Hmm. That's precisely the lens I'm thinking of. The ones with the Nikon mounts always seem to go for several hundred dollars less than the R-mount variants. I suspect that trying to find a stray mount for the conversion might be difficult, though (?) I think that it is not really a problem to find such a stray Leica R bayonet mount For example there is a PC-Super Angulon 2,8/28mm, switched from Leica "R" to Nikon F mount in my photo bag ... Quote Link to post Share on other sites More sharing options...
pgk Posted August 29, 2018 Share #7 Posted August 29, 2018 Advertisement (gone after registration) The Leica R mount version can be converted to Nikon F via a Leitax mount adapter ( it might be worth asking Leitax if they can provide a custom adapter because its just possible that the Nikon F mount and the Leica R mount bolt onto the Schneider lens in the same way and that the Schneider lens body sits in the same relative position (to the sensor plane) for both variants. Quote Link to post Share on other sites More sharing options...
thomasstellwag Posted August 29, 2018 Share #8 Posted August 29, 2018 have you asked Schneider for old stock? Quote Link to post Share on other sites More sharing options...
gvaliquette Posted August 29, 2018 Share #9 Posted August 29, 2018 (edited) Hmm. That's precisely the lens I'm thinking of. The ones with the Nikon mounts always seem to go for several hundred dollars less than the R-mount variants. I suspect that trying to find a stray mount for the conversion might be difficult, though (?) That was the case from the very beginning, even when the lenses were in production and sold brand-new. See: https://www.l-camera-forum.com/topic/57446-leica-markup/ Guy Edited August 29, 2018 by gvaliquette Quote Link to post Share on other sites More sharing options...
