OGWphoto Posted August 24, 2018 Share #1 Posted August 24, 2018 Advertisement (gone after registration) I just got a Leica M3, and while I am very impressed with the VF, it is a bit annoying that I can see the left vertical frameline appearing with a Zeiss 50mm planar attached. Is this normal, can it be adjusted? Thanks. Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 24, 2018 Posted August 24, 2018 Hi OGWphoto, Take a look here M3 90mm framelines visible with 50mm lens attached. I'm sure you'll find what you were looking for!
UliWer Posted August 24, 2018 Share #2 Posted August 24, 2018 Did you try moving the lever for framelines? Do you still see the left vertical line for 90mm when you use a 50mm lens when you move the lever? Can you try what happens with another 50mm lens? If the left vertical line sticks even if you move the lever and/or use another 50mm lens, someting is wrong with the rangefinder. If not, your Planar may not activate the frames exactly due to some mechanical inaccuracy. 1 Quote Link to post Share on other sites More sharing options...
OGWphoto Posted August 24, 2018 Author Share #3 Posted August 24, 2018 (edited) Did you try moving the lever for framelines? Do you still see the left vertical line for 90mm when you use a 50mm lens when you move the lever? Can you try what happens with another 50mm lens? If the left vertical line sticks even if you move the lever and/or use another 50mm lens, someting is wrong with the rangefinder. If not, your Planar may not activate the frames exactly due to some mechanical inaccuracy. If I move the lever just a hint, the framelines go away. I dont have another 50, but tried with a 75mm lens and the 90mm lines disappear. Seems like my Zeiss Planar does not push the knob far enough. Can I adjust it? Use a piece of paper or something? Glad the RF is ok Edit: It actually only appears when I have focus set at 0.7-1 meter. Should be fine then, as the RF closer than this is not accurate Edited August 24, 2018 by OGWphoto Quote Link to post Share on other sites More sharing options...
105012 Posted August 26, 2018 Share #4 Posted August 26, 2018 The height of the actuating lever (inside the bayonet mount) can be easily adjusted if the camera is dissembled. Quote Link to post Share on other sites More sharing options...
jmahto Posted September 9, 2018 Share #5 Posted September 9, 2018 Do you have any other 50mm lens to try? The framelines are selected by a level pushed by a notch in the lens flange. If the incorrect framelines is only for this 50mm lens then camera is ok and I won’t worry too much. Else get the camera adjusted. Personally, I won’t care too much as long as 50mm framelines are clearly visible. Quote Link to post Share on other sites More sharing options...
plaidshirts Posted September 10, 2018 Share #6 Posted September 10, 2018 I had an m4 that had partial lines appear when they weren’t supposed to. This happens when the camera hasn’t been exercised for a long time and may go away as the camera gets used more with different lenses. I had mine cla’d by Youxin Ye for peace of mind before I sold it. I would keep moving the frameline lever and see if it improves. Quote Link to post Share on other sites More sharing options...
