Hey I am having an new issue with the correction override on my R7. The override lever moves freely when the override lock is in both lock and unlock position, I cannot change the override value. Does anyone know a fix for this or anyone that works with this body I love this camera and would love to save it.
Good morning Radiah!
Sorry for the late answer.I'm on holiday at the moment and not that often online...
Well, first: I would only recommend to start this repair, if you have experience with fine mechanic and, of course, you need proper tools.
It`s not that difficult to remove the top cover. Remove the visible screws, take of the "Leica" cover, the wind and rewind lever.
The steps are more or less self explaining...
And then: the easiest repair is, just to replace the broken part. Might be a chance to find a part online, even on ebay...
A "real repair" is possible, but a bit more tricky...and you need a Dremel...
Anyway,
good luck,
regards,
Torsten.
