schattenundlicht Posted July 31, 2018 Share #1 Posted July 31, 2018 Advertisement (gone after registration) Although the pro/ con discussion has been beaten to death in numerous forums, I feel obliged to urge my fellow Leicaists: 1. Use filters, use filters, use filters! 2. Better still: close hip bag properly 40 years of accident free photography passed by in an instant... M7 & Cron 50 V with Leica UV filter after full drop on asphalt. Body and lens elements seem to be miraculously undamaged (besides minor mark on retractable hood). Focusing is butter smooth and aperture clicks softly (lens and camera visited Wetzlar half a year ago for a full CLA). I still have to find a way to remove the filter, though, which seems cold-welded to the lens thread... Kind regards Mathias Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/287125-ouch/?do=findComment&comment=3564658'>More sharing options...
Advertisement Posted July 31, 2018 Posted July 31, 2018 Hi schattenundlicht, Take a look here Ouch!. I'm sure you'll find what you were looking for!
Reini Posted July 31, 2018 Share #2 Posted July 31, 2018 I'm sorry! 1 Quote Link to post Share on other sites More sharing options...
prk60091 Posted July 31, 2018 Share #3 Posted July 31, 2018 I used to have a wrench that grabbed from the interior of the filter. Something like that might work 1 Quote Link to post Share on other sites More sharing options...
schattenundlicht Posted July 31, 2018 Author Share #4 Posted July 31, 2018 (edited) I used to have a wrench that grabbed from the interior of the filter. Something like that might workI have tried so far to remove the filter with grippy fine mechanics gloves and with a tightly sized rubber lens ring wrench from Japanese Camera Tools, which usually work wonders. I do not want to cause further damage, as both lens and camera were mint/ near mint before the drop and were functionally better than new after the recent CLA. Maybe I will send it to CS, although this propably will be $$$... Better than a shattered lens/ camera, though Edited July 31, 2018 by schattenundlicht Quote Link to post Share on other sites More sharing options...
Ko.Fe. Posted July 31, 2018 Share #5 Posted July 31, 2018 I dropped my M4-2 with CV 35 2.5 lens on it. On concrete. Some marks on the lens filter, but no lens damage. Filter was usable after it. Unfortunately, all of the impact applied on RF prism... It was reglued, but framelines ain't perfect. 1 Quote Link to post Share on other sites More sharing options...
pico Posted July 31, 2018 Share #6 Posted July 31, 2018 Sometimes it is better to crack the filter, remove the glass and leverage the filter ring to one side then pull it out with needle-nose pliers. Place duct tape over the filter glass and use a small punch at the edge of the glass to crack it. Removing the dents from the lens edge is something I've not done successfully even with the correct tool. Good luck to you! 5 Quote Link to post Share on other sites More sharing options...
Reini Posted July 31, 2018 Share #7 Posted July 31, 2018 (edited) Advertisement (gone after registration) It's better to send the lens to a technician if you do not believe it yourself. I would glue (Edit: The filter so that no glass parts fall on the lens when it breaks.) with a foil, if you slip off and its breaks.Then just bend the thread of the filter. So the dent to the outside.Only then can you turn it. It would also be the possibility to cut with a mini tool (diamond sliding).Similar to Pico's suggestion. Edited July 31, 2018 by Reini 1 Quote Link to post Share on other sites More sharing options...
Kwesi Posted July 31, 2018 Share #8 Posted July 31, 2018 Why not just leave it. Especially if its not intruding in your picture. Surely it has earned its place on the lens! Quote Link to post Share on other sites More sharing options...
Reini Posted July 31, 2018 Share #9 Posted July 31, 2018 That's no fun .... to look so bad damage 1 Quote Link to post Share on other sites More sharing options...
schattenundlicht Posted July 31, 2018 Author Share #10 Posted July 31, 2018 Although, as an interventional cardiologist, I am no slouch with regard to general dexterity, I am a humble beginner at DIY camera work. With a less pristine specimen, I would try the excellent suggestions above, but this one I might rather be inclined to give into the hands of a professional. Quote Link to post Share on other sites More sharing options...
Reini Posted July 31, 2018 Share #11 Posted July 31, 2018 And as a cardiologist, you certainly do not want to see your ECG in this experiment. 1 Quote Link to post Share on other sites More sharing options...
Jean-Michel Posted August 1, 2018 Share #12 Posted August 1, 2018 Try to simply put a large rubber band around the filter and see if that gives enough grip to unscrew the filter, maybe even use a slip-joint plier to help. Quote Link to post Share on other sites More sharing options...
RayD28 Posted August 1, 2018 Share #13 Posted August 1, 2018 Mathias, please let us know how they remove the filter ring. Pico's suggestion makes sense and I bet the technician does something similar if not the same. One good thing is the ring bent inward and away from the threads so you have a place to start pulling away from the threads. Once you have a enough daylight between the filter ring and lens thread you could file a break in the ring. I hope it all turns out ok. Ray 1 Quote Link to post Share on other sites More sharing options...
Kwesi Posted August 1, 2018 Share #14 Posted August 1, 2018 Although, as an interventional cardiologist, I am no slouch with regard to general dexterity, I am a humble beginner at DIY camera work. With a less pristine specimen, I would try the excellent suggestions above, but this one I might rather be inclined to give into the hands of a professional. i think thats a good idea. Curious as to when was the last time you took the filter off this lens. Binding may not have anything to do with the fall. Hard to tell from your photo. Quote Link to post Share on other sites More sharing options...
Kwesi Posted August 1, 2018 Share #15 Posted August 1, 2018 Hey! Just saw you are 2 hrs from Wetzlar, take it over there and i sure they can take care of it while you wait. sounds pretty minor. Quote Link to post Share on other sites More sharing options...
schattenundlicht Posted August 1, 2018 Author Share #16 Posted August 1, 2018 Try to simply put a large rubber band around the filter and see if that gives enough grip to unscrew the filter, maybe even use a slip-joint plier to help. I tried already with rubberized mechanics gloves and with the Japanese rubber lens ring tools, to no avail... Quote Link to post Share on other sites More sharing options...
Reini Posted August 1, 2018 Share #17 Posted August 1, 2018 If you do not bend the filter beforehand, you destroy the lens thread while turning it. 1 Quote Link to post Share on other sites More sharing options...
MarkP Posted August 1, 2018 Share #18 Posted August 1, 2018 (edited) Have you tried pressing the lens, filter down, onto a grippy rubber surface and rotating the lens to loosen the filter? Although taking it to Leica is a better idea. They can also check there's been no element decentering which may affect image quality. Edited August 1, 2018 by MarkP 1 Quote Link to post Share on other sites More sharing options...
Ccoppola82 Posted August 1, 2018 Share #19 Posted August 1, 2018 I had this happen on a canon 35L onto a concrete floor. My heart sank. I very carefully placed broke the glass and used needle nose pliers to slowly turn the filter. I also mounted a shop vac close to it to catch any fine glass dust that might come off. Luckily in my case it worked. I think if it was a cron, I'd send it to Youxin or DAG to get it off. 1 Quote Link to post Share on other sites More sharing options...
250swb Posted August 1, 2018 Share #20 Posted August 1, 2018 (edited) You need gentle but significant leverage to remove it. Hacksaw two deep cuts into the filter ring opposite each other, then using the back edge of a stout table knife (don't use the carving knife, just in case you slip) or similar metal bar to span across both cuts use it as a very wide screwdriver. It is a really simple DIY job. Edited August 1, 2018 by 250swb 1 Quote Link to post Share on other sites More sharing options...
