You can basically use any flash you like but you won't have TTL metering or any other functionality that requires data exchange between camera and flash unless you use a leica flash or a flash which explicitly states that it is compatible with leica (some metz flashes and some chinese ones). However, I do find this system quite interesting https://lightpixlabs.com/collections/all
I haven't tried it, but it is small enough size.
I liked the q20 flash compactness and built in receiver especially the trigger. However the guide number might be a little low, real usage might be a little challenging not talk about adding on light modifiers. Size wise, it is a perfect match for the M camera. I have two SF60s & one SF C1 which I use for my SL, even that can be challenging when I use it outdoors on HSS + light modifiers.
I have the Nikon SC-28 flash cord which fits the M10 well.  So I have a Profoto A1 for Nikon and this cord even powers that flash!  I know it's not small, but just might work for my limited needs if I can hand hold it while shooting on the street.
Edited by algrove
