dnease Posted July 11, 2018 Share #1 Posted July 11, 2018 Advertisement (gone after registration) Just updated to firmware 1.4, and am noticing that my EVF now fails to auto switch from the monitor on the back of the camera to the EVF when I put my eye up to the camera. I had been using the function button to switch modes with the old firmware, so not sure if this was a pre-existing fault. Any suggestions? Quote Link to post Share on other sites More sharing options...
Advertisement Posted July 11, 2018 Posted July 11, 2018 Hi dnease, Take a look here EVF fails to auto switch on TL2. I'm sure you'll find what you were looking for!
Guest VVJ Posted July 11, 2018 Share #2 Posted July 11, 2018 (edited) Can you verify that you have EVF-LCD (in the Monitor/EVF menu) set to Auto? Edited July 11, 2018 by JorisV Quote Link to post Share on other sites More sharing options...
dnease Posted July 11, 2018 Author Share #3 Posted July 11, 2018 Can you verify that you have EVF-LCD (in the Monitor/EVF menu) set to Auto? Yes. It is set to Auto. Quote Link to post Share on other sites More sharing options...
MDCT Posted July 12, 2018 Share #4 Posted July 12, 2018 I have had this same problem. I often have to reboot the camera by removing the battery for it to work again. I manually switch between the two to avoid the frustration. Quote Link to post Share on other sites More sharing options...
dnease Posted July 14, 2018 Author Share #5 Posted July 14, 2018 I have had this same problem. I often have to reboot the camera by removing the battery for it to work again. I manually switch between the two to avoid the frustration. Rebooting didn't seem to help. And I used to manually switch between the two by assigning that to the Function button, but that no longer appears to be an option available in the function menu. Quote Link to post Share on other sites More sharing options...
dnease Posted July 14, 2018 Author Share #6 Posted July 14, 2018 Thanks for the input. I decided that perhaps a good cleaning of the glass of the EVF would help, and indeed it did. Problem solved! Quote Link to post Share on other sites More sharing options...
nspur Posted July 29, 2018 Share #7 Posted July 29, 2018 Advertisement (gone after registration) Thanks for the input. I decided that perhaps a good cleaning of the glass of the EVF would help, and indeed it did. Problem solved! Rebooting and cleaning the glass didn't do it for me. Losing the ability to switch using the function button is crazy. If I can't use the EVF I won't use the camera. Quote Link to post Share on other sites More sharing options...
Ric66 Posted August 5, 2018 Share #8 Posted August 5, 2018 Rebooting and cleaning the glass didn't do it for me. Losing the ability to switch using the function button is crazy. If I can't use the EVF I won't use the camera. Hello Nspur - wondering if your issue is similar to the problem I have been experencing... see recent thread entitled "EVF fails to wake up after auto power off"? I will update that thread after I get a response from Leica Germany who are currently looking at my erratic evf. Quote Link to post Share on other sites More sharing options...
dnease Posted October 13, 2018 Author Share #9 Posted October 13, 2018 Just an update... The update to firmware version 1.5 fixed the EVF issue along with some bad oscillating behavior by my Summicron T 23. Yay! 1 Quote Link to post Share on other sites More sharing options...
