New SF60 and SC1 flash does not trigger on Leica CL
Hello everyone,
I was wondering if someone else is having a problemi with the new flash and wireless controller.
My Leica CL doesn't fire the flash. It doesn't work it TTL more neither in manual.
The SC1 has the same issue.
What is your experience with the flash?
Thanks for the help.
Loading...
    No registered users viewing this page.
  • Similar Content
    • By EricSS
      I am looking for a lightweight compact TTL flash for use with my Q2, but am trying to understand which are compatible.  I understand that the SF24D may be one option, but will  the SF20 also work? Does anyone have any experience of either in use? The flash needs to be very compact and will only be for occasional use, primarily for fill-in basis so it needs to be TTL.
    • By Rob7P
      Hi,
      with the delayed CL2 anyone tought to buy a Panasonic S5? Lens are compatible and you get IBIS and even a full frame in a comparable compact package.. More Panasonic seems a "low brand" Leica because they share more than the lens: quality of photos should be high
    • By lecycliste
      I'm already using a 35/1.4 Summilux-TL ASPH on a Leica SL2, but I'd like a much lighter load around my neck. (As I write this, I'm still recovering from being too stiff to turn my head from side to side or tilt it back without neck and shoulder pain.) I'm considering purchasing a used Leica CL and used Vario-Elmarit-TL 55-135mm f/3.5-4.5.
      - Does the CL track just human faces, or will it track animal faces too?
      - Does the CL allow you to choose the initial AF point?
      - How well does the CL track moving faces at f/4.5 - does it lose focus with a subject moving towards you erratically at 3 MPH? At 15 MPH?
      - How long is the battery life (# of shots) using just the EVF (no LCD)?
      - I know the camera lacks external ports of any kind. Is there an external power solution using a dummy battery with cable to a USB external battery?
      Thanks.
    • By wda
      I am looking for an L-Bracket, with Arca Swiss compatibility, for use with my Leica CL camera. Occasionally it will be used with tele-zoom lenses, but mostly with smaller lenses.
      There are a few threads on this subject in the forum, dealing specifically with bigger cameras, but none that I could find relevant to the CL. Googling brings up a lot of brand-specific solutions; a few claim to be universal. I would welcome any reports from members of this forum, of user experience with such a device, and recommendations. Thank you.
    • By PLH
      Has anybody had intermittent TTL flash issues with the R8?
       I get random firing of the SF-58, particularly with movement of the camera, and sometimes no flash on shutter release. Inside, low light, and with program mode the viewfinder shows f/5.6 @ 1/250 as it should.  Contacts are clean, wiggling the flash at the foot doesn't make it fire.  Camera, flash or the coupling of the two?
      The phenomena does not seem to occur with a SF-24D, though i have no negatives to review yet.
      R8 serial # 243xxxx.  I've had no other problems with this camera.
