Guest Posted June 25, 2018 Share #1 Posted June 25, 2018 Advertisement (gone after registration) Is it safe to put a Elmar M 50mm f2.8 collapsable inside the M10.....i.e. can I clasps the Elmar M inside the M10. The guy at the Leica store wasn't sure hence the question Neil Quote Link to post Share on other sites More sharing options...
Advertisement Posted June 25, 2018 Posted June 25, 2018 Hi Guest, Take a look here Elmar M 50mm f2.8 collapsable inside a M10. I'm sure you'll find what you were looking for!
MarkP Posted June 25, 2018 Share #2 Posted June 25, 2018 (edited) No problemo But mount it extended Edited June 25, 2018 by MarkP Quote Link to post Share on other sites More sharing options...
Guest Posted June 25, 2018 Share #3 Posted June 25, 2018 No problemo But mount it extended thanks a lot MarkNeil Quote Link to post Share on other sites More sharing options...
MarkP Posted June 25, 2018 Share #4 Posted June 25, 2018 In fact you can still mount it retracted. Quote Link to post Share on other sites More sharing options...
Luke_Miller Posted June 25, 2018 Share #5 Posted June 25, 2018 In fact you can still mount it retracted. I'm sure that is true, but I never do. My old, shaky hands would likely cause the collapsed rear element to contact something inside the body while mounting it. Quote Link to post Share on other sites More sharing options...
250swb Posted June 26, 2018 Share #6 Posted June 26, 2018 I mount it retracted, it can only do damage if you try to force the lens onto the body at some absurd angle which even with eyes closed would be hard to do. 2 Quote Link to post Share on other sites More sharing options...
Guest Posted June 26, 2018 Share #7 Posted June 26, 2018 Advertisement (gone after registration) Thanks for the feedback guys. I'm going to stick to my noctilux for a wee while just while I get used to shooting this camera then I will try my other lenses Neil Quote Link to post Share on other sites More sharing options...
jaapv Posted June 26, 2018 Share #8 Posted June 26, 2018 I mount it retracted, it can only do damage if you try to force the lens onto the body at some absurd angle which even with eyes closed would be hard to do. The objection against mounting it collapsed is not scratching the inside of the body - difficult to do and even if you managed to do so a dollop of matte black paint or even a sharpie would be an easy fix- the real danger is hitting the roller arm and knocking it out of adjustment, or hitting and damaging the exposure sensor. Collapsing it when mounted can do no harm, except from the theoretical possibility of pumping dust onto the sensor Quote Link to post Share on other sites More sharing options...
stephengv Posted June 26, 2018 Share #9 Posted June 26, 2018 Considering that it is collapsible, does it result to more dust in the Camera Sensor? Quote Link to post Share on other sites More sharing options...
jaapv Posted June 26, 2018 Share #10 Posted June 26, 2018 Theoretically it might. In real life I've never noticed it. Quote Link to post Share on other sites More sharing options...
Guest Posted June 26, 2018 Share #11 Posted June 26, 2018 Hay one more question. Does it make any difference if I shoot with the lens extended or colasoec I'm assuming it will as the PIV will change Neil Quote Link to post Share on other sites More sharing options...
jaapv Posted June 26, 2018 Share #12 Posted June 26, 2018 If that is a serious question: Rather - if you want to have a sharp image instead of vague blobs. Lock it in place too. Quote Link to post Share on other sites More sharing options...
Guest Posted June 26, 2018 Share #13 Posted June 26, 2018 If that is a serious question: Rather - if you want to have a sharp image instead of vague blobs. Lock it in place too.I really don't know......so it has to be locked open??? Quote Link to post Share on other sites More sharing options...
MarkP Posted June 26, 2018 Share #14 Posted June 26, 2018 Well do it and you’ll see. Quote Link to post Share on other sites More sharing options...
JTLeica Posted June 28, 2018 Share #15 Posted June 28, 2018 Thanks for the feedback guys. I'm going to stick to my noctilux for a wee while just while I get used to shooting this camera then I will try my other lenses Neil Thats it, ease yourself in gently to the Leica system with a Noctilux... Quote Link to post Share on other sites More sharing options...
Frase Posted June 29, 2018 Share #16 Posted June 29, 2018 Hay one more question. Does it make any difference if I shoot with the lens extended or colasoec I'm assuming it will as the PIV will change Neil No they work just as good collapsed.............. Quote Link to post Share on other sites More sharing options...
lct Posted June 29, 2018 Share #17 Posted June 29, 2018 1 Quote Link to post Share on other sites More sharing options...
earleygallery Posted June 29, 2018 Share #18 Posted June 29, 2018 You also need to remember to collapse the lens after each photo and retract it again before the next, to reset it. A bit like a pump action shotgun. Quote Link to post Share on other sites More sharing options...
Guest Posted June 29, 2018 Share #19 Posted June 29, 2018 Its in KL and i'm in Spain.....I will try it on my Hassy when I get home Quote Link to post Share on other sites More sharing options...
lct Posted June 29, 2018 Share #20 Posted June 29, 2018 You also need to remember to collapse the lens after each photo and retract it again before the next, to reset it. A bit like a pump action shotgun. James, you are kidding i guess 2 Quote Link to post Share on other sites More sharing options...
