albert
Help Me Pls. Stuart, Brent, and Bill
My VLUX 114 is set on pin point focus. For two years I have pushed the button half way down for for perfect focus, then pulled the trigger.
Today, when I push the trigger half way down the camera immediately fires away.
HELP
Also, should I consider a Q?
Share this post
My wife has a V114 but I do not know much about it. Is there a setting that changed inadvertently? Can you do a factory reset? And I am not sure if I am the Bill you are referring to. I have never owned the Q but it is a very nice camera. If your V114 is not going to work for you, why not get another one? FWIW.
Share this post
The other Bill is Bill Schneider from the Pacific NW.
I've not experienced this, and assuming you're certain that it's not "pilot error," the first two things I'd try are:
  • taking out the battery and reinstalling it, and see if that makes a difference.
  • In the menu do a reset to factory settings.  That of course removes any settings you've made (date, time, time zone, language, resolution, if you use the interpolation electronic zoom, etc.) which you'll need to adjust after the reset.
Let us know what happens.
I'm moving this thread to where more VLux 114 users will be likely to see it.
Share this post
So far, no go. Thank you Stuart.
Share this post
You might want to try calling Leica in NJ to speak with them about this.  Perhaps they can shed some light on the issue. (800) 222-0118
Share this post
I'm sorry I can't offer any help. I would have suggested what Stuart already did about resetting. I'll try some different settings on mine to see if I can duplicate your experience.
Share this post
The LX100 certainly has an option (Custom menu, p.2) to switch on/off Half Press Release. The  menus will be different on the VLUX, of course, but you should find something in there, I'd have thought
Jim
Share this post
Drat! Just realised I've mixed up my DLUX and VLUX. Please ignore last post...
Jim
Share this post
Hi Al,
I've played around with mine and have just a couple of things for you to check. I'm not sure these settings need to be this way to have the focus hold when the shutter is pressed half way down, but try them and see what happens. (Photos below) You also might see if changing from Pinpoint focus to 1-Area focus to see if you have the problem with both settings.
In answer to your question about buying a Q, my recommendation would be to consider the CL with the 18-56mm lens. The image quality is superb and with the zoom lens it is far more versatile than the Q. I sold my Q right after buying the CL/18-56mm combo.
Share this post
Thanx everyone.Brent: no go, I thought you hit the jackpot but problem persists. I’ll call Leica tomorrow. I’m at the cabin and am getting some good shots despite the problem. Checking on CL now, hiding my curiosity from THE CFO.
Share this post
Well, today is Fathers Day. Maybe you could use that to your advantage.
Share this post
Hello Brent,
Sorry to be late reading this thread. I've not had any problems with my VL114. I just checked and I get focus lock with the button pressed half way.
It seems everyone has given you good advise. I think Stuart had the best idea doing a complete reset.
Share this post
Northwest Bill,
It’s me, Al from MN, with the problem. So far, no luck.
Share this post
Is the zoom control working smoothly i.e. not hesitantly? If it's not as smooth as when new, could be indicative of soiled contacts which might also affect shutter release.
https://www.l-camera-forum.com/topic/284600-d-lux-109-…-stickyhesitant-zoom-control/?p=3518809
 …  remedied with SERVISOL which when applied very sparingly does no harm
dunk
Edited by dkCambridgeshire
Share this post
    No registered users viewing this page.
