bags27
Thoughts about buying a T at this point?
I knew this going in though. I will not buy the evf because every camera I ever used I used the lcd screen. Sticking with the t and then will get sl in a few months or so no regrets at all but to me if you have the q already just buy the sl if you can afford. Also lcd screen is good enough to manual focus.
Share this post
The most obvious difference is the T's built-in flash.
The T retained the film style I selected when I imported .dng files into Lightroom using Leica's embedded profile.  The TL2 did not retain the film style on import.
The T had an unmistakable shimmer on contrasting edges that made manual focusing easy.  I did not observe this shimmer on the TL2.
The T's autofocus never missed with the 18-56, whereas my TL2 slightly missed critical  focus with this lens sometimes.  Same with the 55-135, except that the TL2 never autofocused correctly with the 55-135 wide open, and often missed at infinity distances when stopped down.
Perhaps worst for me about the TL2 was that I had 2 copies that didn't work out.  #1 was recalled by Leica after one week due to the Visoflex issue with the firmware.  The hot shoe on #2 became buggy in the middle of a long holiday, making the Visoflex not dependable.
Share this post
I have the feeling that while improving AF speed with firmware and versions Leica maybe gave up a little on AF accurancy?
Share this post
Sounds like a great idea to me. Manual focusing without the evf is a struggle, but doable. I guess your choice is whether to buy a TL AF lens. I would (I did), and having the SL, the TL2 with a couple of AF lenses is very useful - small camera to take when the SL is just the wrong thing to take.
I loved my T, but found the TL2 better - not in a fatal way. I just hated the blackout on the T. Perhaps I was too critical.
Share this post
I shoot an SL and M246 and would like a portable kit.  I'm thinking of a T with the 18-56.  I can't justify the 4x cost of a new T2 over a mint T.
First question, for those familiar with both cameras (or M10 which is the same as the SL) when does the T ISO noise strongly depart from the SL/M10? Can I get to ISO1600 with quality that exceeds, say, the M9?
Second, my lens adapters for the SL should work on the T, right? Then I can (if I get the Visoflex) use M and R lenses on the little beast?
Thanks.
Dean
Share this post
Hi  Dean,
I would think up to 1600 your T's ISO will be pretty good and comparable to the SL's. And, yes, your M adapter L will work on the T/TL.
I have an original T and a TL2.  The TL2 will give you a bit better iso, but I'd think image quality is comparable for the most part. I think you can find a used T for $500 range and a TL2 for $1300-1400.
I've used M lenses on the T/TL with very good success. The visoflex is pretty good, but does not compare with the SL's. Nonetheless I think you should be able to make due.  The below photos were shot using the Noctilux 0.95, the top one with the TL2 and the bottom with the T.
Build quality is identical. Menu system on the TL2 is a bit better organized, but one can easily live with the T's once one acclimates to the on-screen menu system.
I don't think the jpegs from either are very good, which is not the case with the CL.  If you are shooting DNG, the files of the T, TL2, and CL will all shine.
I just got back from Europe and took my TL2 and my Q.  For the first time I shot the TL2 without the visoflex and  it worked out just fine as a great point and shoot. (However, comparatively, the Q will outshine the T/TL2)
Rob
Edited by ropo54
Share this post
Visoflex, visoflex visoflex... etcetera ! Im not at all a camera pro, but I leave mine attached always, and leave it to the spare of the moment where my eye ends up when I click the button, head right over the camera, pressed up behind, or rearwards, arms stretched a little . This capability is strictly part of the DNA of the Camera, in my personal view .
Share this post
Hi  Dean,
Rob
Hello Rob,
I am in between acquiring either a Q or a CL/TL2. In what area(s) will the Q outshine the TL2 in your opinion?
Thanks!
Share this post
Hello Rob,
Thanks!
Hi Frans Kemper,
The Q has very fast autofocus, is full frame, has a built-in viewfinder, and has a wonderfully mated 28mm 1.7 lens. In low light conditions the full frame and 1.7 lens makes the Q exceptional.  The colors and IQ are as just superb.
The CL/T lines have the flexibility of different lenses. And, yes, you can add a fast lens to get a measure of equivalence, but still it is not full frame. You can get superb results (see my photos above taken with the noctilux) , but it is still tough to beat the Q.
If you are comfortable with a single focal length of 28mm, I would choose the Q.
Good luck . . . No bad choices.
Rob
Edited by ropo54
Share this post
The Leica CL has the same processor and sensor as the Leica TL2 , No ?
As far as I know yes.
It seems incomprehensible to me that there is (or can be) any difference in output but the CL enthusiasts/ reviewers are vocal in their praise for the CL and quick to criticise the TL2. Same goes for autofocus.
From all the empirical evidence I can find the 'active ingredients' are the same. Obviously they live in different housings but otherwise they are the same camera.
Share this post
Loading...
  • Similar Content
    • By wingedb11
      Don‘t know how others fell. But just saw that there is a new Firmware for the CL but nothing for the TL2 and this since a while. Communications turn primarily around CL. Is the T-series dead?
    • By plasticman
      Mike Johnston at TheOnlinePhotographer blog has been musing about the perfect 'simple' digital camera again, and I can't help thinking that a Leica T(L/2) fits his description perfectly - if only he (and his readers) knew it.
      He acknowledges that Leica is the only camera company embracing photographic simplicity, but the spectre of Leica prices keeps coming back - both in the blog posts and the comments - and the only cameras they seem to acknowledge are the M-series.
      To me, the menu system in the Leica T is the most intuitive and minimal interface that's possible in an advanced digital camera - especially the way that each user can choose their own subset of visible menu items: I have only 4 items in that menu, and regularly only use one of them (the metering type).
      Nowadays the T can be bought for less than a Fuji XE3. You can even pair it with an adapter for non-Leica manual lenses (ie: Olympus OM). Couldn't be simpler or cheaper.
      Incidentally, one of the points being missed in a lot of the comments on TOP's site is the scenario where the user changes a setting on a camera unintentionally. A lot of the commenters say it's easy to just ignore menus and settings they don't understand. But this was one of the problems I persistently had with my X100 - I'd pick it up after a long hiatus and somehow an exposure or other setting had been inadvertently changed, and it would first take me a while to notice, and then usually a long time to fix (hunting through tens of menus). And I'm an app developer, so used to device complexity.
      The T has solved all those problems perfectly.
    • By Carothersbs
      https://www.bhphotovideo.com/c/product/1450274-REG/7artisans_photoelectric_a505b_55mm_f1_4_lens_for.html
      anyone get a chance to play around with one of these yet?
    • By Carothersbs
      Hello I currently have a Leica TL2 using a adaptor for a M mount lens .
       I want to get a auto focus lens that will work with the TL2,  I just don’t want to spend 1,500.00+  At the moment.
       Do I have any options ?
    • By plasticman
      Because the Leica T M-adapter is an order item in Stockholm, I can’t try one before buying. I like the T, but not being certain of focus in low-light situations is occasionally irritating. And the Novoflex doesn’t have focus-zoom assistance.
      If you have the Leica M-adapter, how do you use it? Is it possible to zoom in, check focus, then zoom out again to compose your image? How’s the zoomed image? Sharp and detailed, or noisy and blurred?
      What options are available for the dials in manual mode? Right now, the left-hand dial is wasted on f-stop (which is disabled with M-lenses attached, of course). Does the Leica adapter free the dial for something useful?
      In general, is it much more useful than the third-party adapters? Does the camera-system adapt to it intelligently, or is it a missed opportunity?
      PS: I saw Jono Slack’s review of the T, where he dismisses the adapter as less than useful. I wonder if firmware updates or other factors have given anyone another perspective?
    No registered users viewing this page.
Important Information
