Guest Posted May 8, 2018 Share #1 Posted May 8, 2018 Advertisement (gone after registration) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! (mono1+nokton50/1.5) lambda. Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! (mono1+nokton50/1.5) lambda. ' data-webShareUrl='https://www.l-camera-forum.com/topic/284395-augenblick/?do=findComment&comment=3514788'>More sharing options...
Advertisement Posted May 8, 2018 Posted May 8, 2018 Hi Guest, Take a look here augenblick..... I'm sure you'll find what you were looking for!
kalokeri Posted May 8, 2018 Share #2 Posted May 8, 2018 (edited) Weltklasse, der Titel. Dauerte etwas, bis bei mir der Groschen fiel, . Nachtrag: Bild an sich ist auch klasse (sorry, zunächst vergessen zu erwähnen). Edited May 8, 2018 by kalokeri Quote Link to post Share on other sites More sharing options...
kunzhobel Posted May 8, 2018 Share #3 Posted May 8, 2018 Hammer! Quote Link to post Share on other sites More sharing options...
Guest 10511 Posted May 8, 2018 Share #4 Posted May 8, 2018 GROSSES KINO! Quote Link to post Share on other sites More sharing options...
thowi Posted May 8, 2018 Share #5 Posted May 8, 2018 Hallo, raffinierte Gestaltung, wunderbare Ausarbeitung. Schöner Moment und danke fürs zeigen. Gruß Thomas Quote Link to post Share on other sites More sharing options...
sinope73 Posted May 8, 2018 Share #6 Posted May 8, 2018 Wie thowi. Gruß sinope 1 Quote Link to post Share on other sites More sharing options...
XOONS Posted May 8, 2018 Share #7 Posted May 8, 2018 Advertisement (gone after registration) Ein gutes Bild. Quote Link to post Share on other sites More sharing options...
Guest Posted May 8, 2018 Share #8 Posted May 8, 2018 Analog Quote Link to post Share on other sites More sharing options...
Guest Posted May 8, 2018 Share #9 Posted May 8, 2018 Analog nö! Quote Link to post Share on other sites More sharing options...
Guest Posted May 8, 2018 Share #10 Posted May 8, 2018 Was heißt hier nö? Quote Link to post Share on other sites More sharing options...
thowi Posted May 8, 2018 Share #11 Posted May 8, 2018 (edited) Hallo, Analog bei Lambda wohl eher nicht. Wie schon an anderer Stelle geschrieben gibt durchaus hervorragendes digitales schwarzweiß. Ebenso wie es Abzüge aus der Dunkelkammer, die für die Tonne sind. Und wenn es einer kann, der bekommt so etwas hier hin. Außerdem steht's unterm Bild. Gruß Thomas Edited May 8, 2018 by thowi Quote Link to post Share on other sites More sharing options...
Guest Posted May 8, 2018 Share #12 Posted May 8, 2018 Analog Die Bemerkung ist mir unverständlich. Daß das Bild digital aufgenommen ist, sieht man deutlich links bei der Lampe, es steht auch unter dem Bild und ist in den exifdaten gespeichert. Soll nur gesagt sein, daß die rechte Bildhälfte analog wirkt? xyz. Quote Link to post Share on other sites More sharing options...
Guest Posted May 8, 2018 Share #13 Posted May 8, 2018 Leute, Ihr seid sprachtechnisch doch SONST immer so jugendlich drauf. Das sollte schlicht ein Kompliment sein. http://jugendsprache.deacademic.com/81/analog Quote Link to post Share on other sites More sharing options...
0-Typ Posted May 8, 2018 Share #14 Posted May 8, 2018 Leute, Ihr seid sprachtechnisch doch SONST immer so jugendlich drauf. Das sollte schlicht ein Kompliment sein. Dann hättest Du etwas in dieser Richtung äußern müssen: "Voll analog, Alda!" 1 Quote Link to post Share on other sites More sharing options...
Guest CCcolor Posted May 8, 2018 Share #15 Posted May 8, 2018 ... schöner Augenblick ! Quote Link to post Share on other sites More sharing options...
Guest Posted May 8, 2018 Share #16 Posted May 8, 2018 Weltklasse, der Titel. Dauerte etwas, bis bei mir der Groschen fiel, . Nachtrag: Bild an sich ist auch klasse (sorry, zunächst vergessen zu erwähnen). danke auch für den nachtrag. Hammer! merci GROSSES KINO! das freut mich! Hallo, raffinierte Gestaltung, wunderbare Ausarbeitung. Schöner Moment und danke fürs zeigen. Gruß Thomas danke für deinen Kommentar Wie thowi. Gruß sinope Ein gutes Bild. thx! Quote Link to post Share on other sites More sharing options...
kalokeri Posted May 8, 2018 Share #17 Posted May 8, 2018 Dann hättest Du etwas in dieser Richtung äußern müssen: "Voll analog, Alda!" Du hast "Hamma, Digga!" vergessen. In Gänze also: "Hamma, Digga! Voll analog, Alda!" ergänzt ggf. um weitere Jubelausdrücke wie "krass", "fett" oder so. 2 Quote Link to post Share on other sites More sharing options...
Guest Lux Posted May 8, 2018 Share #18 Posted May 8, 2018 Ja, sehr schöner Augenblick, feine Komposition und feine Töne... Gruß Lux Quote Link to post Share on other sites More sharing options...
Guest Posted May 8, 2018 Share #19 Posted May 8, 2018 Leute, Ihr seid sprachtechnisch doch SONST immer so jugendlich drauf. Das sollte schlicht ein Kompliment sein. http://jugendsprache.deacademic.com/81/analog yo alda... ich feier dich! Dann hättest Du etwas in dieser Richtung äußern müssen: "Voll analog, Alda!" yep. ... schöner Augenblick ! vielen dank! Du hast "Hamma, Digga!" vergessen. In Gänze also: "Hamma, Digga! Voll analog, Alda!" ergänzt ggf. um weitere Jubelausdrücke wie "krass", "fett" oder so. Ja, sehr schöner Augenblick, feine Komposition und feine Töne... Gruß Lux danke!!!!! danke auch für die clicks lambda Quote Link to post Share on other sites More sharing options...
Guest Posted May 8, 2018 Share #20 Posted May 8, 2018 (edited) ..... Daß das Bild digital aufgenommen ist, sieht man deutlich links bei der Lampe, es steht auch unter dem Bild und ist in den exifdaten gespeichert. Soll nur gesagt sein, daß die rechte Bildhälfte analog wirkt? xyz. wow ...ist das so??? liegt wahrscheinlich an der modernen energiesparbirne lambda. Edited May 8, 2018 by Guest Quote Link to post Share on other sites More sharing options...
