Using more than one scanner with Silverfast 8-Installation Workflow
By
Martin B, in Film Forum
Similar Content
By gwpics
I am just working through some transparency work and scanning it on to the computer. I was particularly pleased with this one which was taken in 1999 on Kodachrome 64 using a Leica M6. Scanning was with a Plustek 8200i, and post was with LT Classic.
I think it is amazing how the work we have just put away into a filing cabinet etc. has stood the test of time, and before there is "ah, well it is Kodachrome" some Fuji Provia RDP is just as good.
Gerry
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! -
By IkarusJohn
Please excuse me if this has already been covered. I did a search and couldn't find anything on topic.
I have about 30 years of slides and negatives, 135mm and 6x6 formats. The results I'm getting from my Epson flatbed scanner and the 135mm scanner (I forget its name) are okay, but I'm wondering if I might get better results if I use my SL(601). Is this correct?
Can anyone advise if this is worth doing, what I need equipment wise (presumably some sort of holder and a uniform whit background) and if it is feasible to photograph negatives as well as slides?
Or am I wasting my time?
Cheers
John
By Sharif
Und noch einmal: Parkhaus Moselstraße
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Diesmal in 6x6. Hatte ich noch nicht versucht.
Fuji GF 670 W, 6x6, Trix 400@400 in Rodinal, Scan mit Epson Perfection 750 und Silverfast
Sharif
By schattenundlicht
Hi!
Today I received a batch of negatives which I had processed and scanned at a dedicated b/w lab. Usually I do the scanning myself, but this time I needed some quick results to check the technical validity of some vintage cameras and I had little spare time available. These scans are low res jpeg and only substitute for contacts. I am thinking of re-entering the dark abodes of home-developing, especially after reviewing the result that I want to query this forum about.
Seven rolls of TriX, TMax and HP5 from diffeent cameras (M3, IIIf, M7) came out fine, but one roll of film (TMax) from a 1934 IID shows peculiar scratches not typical of ones that I have seen or produced myself before.
Since this is the only roll of film from this newly acquired camera that I have available (it is currently away for a focusing CLA), I would be particularly interested in whether it is a problem that might be related to the camera or whether it is related to film handling pre/during/post development, which I find more likely. Since I bought the camera from a respected dealer, he should be noticed of any problems soon as possible.
The scratches start at #25 and continue until #36A, where the scratch line tapers off into the perforation. It is not a strictly parallel scratch like ones I have seen from damaged back plates or sloppy enveloping/ rolling and it is not continuous for all the way.
I will post three example images. I hope diagnosis can be made from forum resolution.
(1): #29, Inadvertent picture of my lens cap (idiot me
Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! ) (2): #32, Oyster bed, 300 million years old, today grounding a cottage, situated 600 Km from the nearest shoreline
(3): #35, Casino, Wiesbaden, Germany
Has anybody seen a scratch configuration like this before?
Thanks!
Kind regards, Mathias
EDIT: By the way, the scratches are on the emulsion side.
By Martin B
After digitizing for quite a while all my 35 mm negatives via photographing them with 1:1 macro lens, tripod, and LED light table, I decided now to get the plustek 8200i Ai scanner with SilverFast 8 software. Main reason for it was correct color calibration of color negatives. To do the color calibration manually in PS or LR is not always easy.
Posting here to hear from others who use a plustek scanner with SilverFast software. So far I am very impressed by the scanner and the software. I updated to the SilverFast 8.8 version which has a lot of options - tricky part is to figure out what is mainly needed for a good color calibration of a scan and what is more optional. I prefer to use the internal settings for films to choose from - the color calibration of the scanned color negative appears fairly correct afterwards that only minimal adjustment is needed. I also like the infrared dust scan and automatic subtraction from the photo - it works really well and leaves other image parts intact.
One thing I struggle with is the archive mode of the negative - the only option to save the file in RAW as DNG. I didn't find yet a way to get an automated color calibration after the negative was scanned with the archive mode. I would prefer to have the scan saved as DNG but would like to have it processed like it is offered for all the other image file modes as JPG, TIFF etc. Is there a way to do this easily?
What is your best / most proficient workflow using plustek scanners and this software? Did you encounter any drawbacks?
Recently Browsing 0 members
No registered users viewing this page.
