As spring rolls around and hearts turns to flowers, I'm hoping to get back to macro with my Q.
I have to admit that I've rarely used add-on flash (my Fuji x100 has built-in), so I'm blissfully unaware of the complications.
I know that some enjoy this:
https://www.bhphotovideo.com/c/product/1030212-REG/canon_9389b002_mr_14ex_ii_macro_ring.html?sts=pi
But it's quite expensive and wondering if less expensive versions will work also, such as below. And, what exactly do I mean by "work"? Thanks so much.
https://www.bhphotovideo.com/c/product/1125848-REG/yongnuo_yn_14ex_c_ttl_led_macro_ring.html?
Maybe a LED ring light could be a good solution for you. I use one of Kaiser in Germanyon my adapted Macro lenses from Canon on the SL, a R 60. Not too heavy and has a low price and does is job very well, as long as there is no danger of reflections. But with flowers this is not the case.
With my former Canon 5 D III I used a Macro flash from Canon, which worked fine on
this camera, but sold it when I bought the SL. But it was always a bit cumbersome to
use it an to store it afterwards.
Edited by HeinzX
Thanks. I don't know what those are, but will look into it!
Check out the Macro thread. I’ve posted several messages and photos of my Q with a Canon MR-14 EX ring flash. In some situations such as flower photography its been very good. I use it in manual mode only, but that works fine.
Thanks. Does the Canon require a step-up ring?
Yes, I had to buy an adapter from the ring to 49 mm threads. I found something at B&H and modified it. I think now you can buy it directly. As I remember you need the piece that fits the ring flash then you need an adapter to that from 49 mm threads. Send me a message if you need help.
The flash works fine, but only in manual mode. You can control the power of the flash or change the aperture for correct exposure.
Edited by Infiniumguy
Here are the pics
  • 3 weeks later...
So, I have only had time to play around with this for a few hours.
Pros:
1 - has all the adapters for numerous lenses including 49mm.
2 - LED and can be used as continuous or flash (flash is much brighter).
3 - can be set to left or right side only - not sure if this works for flash.
Cons.
1 - completely manual and will take a bit of experience to work out the ranges that make sense.  The adjustment range seems small though, so it should not be too hard to sort out.
2 - macro ring lighting with a 28mm lens may not be the best approach or certainly has challenges - keeping the reflected LED pattern out of the frame requires really close and careful framing!
3 - this is certainly aimed at shooting very small things very close, so the fall off is dramatic in otherwise poorly lit settings.
4 - adapter rings are plastic, threads and all, so some care is needed when attaching.
My first go at a flash like this, so I need to do more work with it - and am anxious to put it on my 100mm Macro/2.8 Canon too where I think it will be much better suited.
I'm going to try out the Polaroid Universal LED ring - supposed to come with 49mm-77mm adapters.  Won't be as nice as the Canon, I'm sure.. Will report back soon.
Thanks so much!
Maybe something like this would work a little easier with the 28mm lens, with a step up from 49 to 52. of course, it costs a lot more.
YONGNUO YN24EX TTL Macro Ring Flash/ LED Macro Flash Speedlite with 2 PCS Flash Head and 4 PCS Adapter Rings for Canon
Loading...
    No registered users viewing this page.
  • Similar Content
    • By Goalasso
      Good Day!
      Is it possible to tell if an image was taken in Macro mode vs. not from exif data? I am using Lightroom and do not see any indication. It would be nice to be able to identify that on my images.
      Thanks in advance.
    • By PLH
      Has anybody had intermittent TTL flash issues with the R8?
       I get random firing of the SF-58, particularly with movement of the camera, and sometimes no flash on shutter release. Inside, low light, and with program mode the viewfinder shows f/5.6 @ 1/250 as it should.  Contacts are clean, wiggling the flash at the foot doesn't make it fire.  Camera, flash or the coupling of the two?
      The phenomena does not seem to occur with a SF-24D, though i have no negatives to review yet.
      R8 serial # 243xxxx.  I've had no other problems with this camera.
    • By Edwin Ho
      I am considering Leica SF24D as a replacement for the Olympus S20 (small auto flash).
      Took some shots of family Christmas gathering with the S20; a little under-exposed (subsequently adjusted in LR by increasing exposure).
      I hope to hear from those who had experience using the SF24D with an M9.
    • By stevegaskin
      I'm looking to 'play around' with some macro photography. Nothing serious at this stage so don't want to spend much.  I have a Novoflex R-SL adaptor which I use with a 50mm Summicron R I have and it works fine. Has anyone any thoughts on both the Elmarit-R f2.8 60mm and the Elmar-R f4 100mm, both of which seem to be reasonably priced on eBay. Any pitfalls to look out for and most importantly, will that work with the SL using manual and Focus Peaking?
      Many thanks
    • By Sasha
      I'm a hobby shooter and have gone through Nikon, Canon, and Sony gear, and then got into Leica M a couple of years ago.  Love my M10P and M3 and am building up a nice collection of M lenses.  I have been shooting with just natural light but would now like to experiment more with portraits and controlled lighting and external flashes.  I've been looking at the getting a couple of Godox AD200 Pros and would like to control them with a flash trigger from my M10P.  I can't find anything official about Godox/Leica compatibility on the internet, although some say that a Godox X1T or X2T Nikon version will work with Leica M and I've also read somewhere that the Olympus version is the one to go for.  Does anyone have any first hand experience or advice on this?
