Purchase advice 50 APO
dkmoore
Hi all,
I recently sold my Leica gear stupidly and I am purchasing again. I bought the M10 (for the second time) as I had a lot of issues the first go around.
My question is which option would you pick?
1. 50 APO or
2. 28 Cron (latest version) & 50 Lux (latest version)
I know the pros and cons of each but am having something similar to writers block deciding which way to go.
If I go 50 APO I can probably buy the 28 in 6-12 months.
Thanks for your help!
Welcome to stupid sellers anonymous. I am the chairman.
I've had two 50 APO's. Sold the second time to fund an M-A and don't regret (yet). I will make do with the very fine 50 cron v5 for a good while. I've never had the 50 lux ASPH but do have the 50 lux pre ASPH which I prefer and will never sell (never say never). As I'm not struck on the 50 Lux ASPH, I would get the APO from your options. It is a truly amazing lens.
As regards the 28 Cron, I decided to get the Q instead as I don't like changing lenses. Q and M10 with a 50 make perfect partners.
The 50 APO is a statement lens - it shows what it is possible to design and build. The 50 Summilux is stunningly good (excellent) in the real world and I defy anyone to be disappointed in its performance. So the question you need to ask yourself is whether you want a lens because of its theoretical performance, or two lenses which are as usable as any you could want.
Wide open the 50 lux ASPH has a distinctive rendering which I find cheesy. That's an exaggeration but it's the best word I can think of. If you want tack sharp images with backgrounds that melt into mush then it's a great lens.
All rational, reasonable, sensible and spot-on accurate...until you start agonizing whether you should have gotten the APO anyway and begin plotting its purchase.
I've owned the 50 lux three separate times. I've also owned the prior 28 Cron.
I've never owned the 50 APO. But I also enjoy using a 28.
I can probably make due using just the one lens , 50 APO for 6-12 months. I do go back and forth between 28 and 50 quite frequently.
I prefer the ergonomics of the 50 Summilux ASPH compared to the APO.... and the extra stop is a bonus. Neither lacks in IQ for my printing needs.
I’ve had the 50 Summilux ASPH and 1st version 28 Summicron ASPH for many years. I rented the APO, and decided to keep what I have, irrespective of cost.
But you love just the ‘thought’ of the APO, so GAS will likely rule...or nag after the fact.
Jeff
Edited by Jeff S
Jeff,
You hit the nail on the head perfectly. 50 Lux is better than I am skilled it just isn't about that.
I am selfishly hoping someone writes something that I haven't already thought of or read already that convinces me the APO is a must have.
That just hasn't been the case and I read this forum a ton.
Jeff,
I like your honesty. If it’s GAS you are trying to satisfy, I think you need to push the boat out and buy the LHSA black paint APO before they all get snapped up. The bog standard 50 APO no longer cuts it as far as GAS is concerned.
The thought crossed my mind. I love the look. But 10k for one lens even scares me away.
Knowing how good the lux and 28 Cron are has me leaning in that direction.
Leica gear needs to be passed down to next generations or bought and sold 10X like I stupidly do.
I would actually buy the 50 lux ASPH if the 50 APO were the same price.  I am a film shooter but the images look better to me, and I need the 1.4.
Of course I will still buy the APO someday.  GAS is addictive and I love 50's.
I have the 50APO, the 90APO and the 35 lux FLE.  I see obvious differences between the 50APO and the other lenses is when I use my monochrome. With the inevitable technical evolution I foresee an M model with higher mp count, broader DR, better high ISO capabilities, in body stabilization system...etc in the near future. With the 50APO you can be sure the the lens would be up to the upcoming technical progress of the next M itineration.
Edited by Neko
For what it's worth, I have both the 50mm Summilux ASPH, and 28mm Summicron ASPH mk1. I think they compliment each other beautifully. They render images in a similar way - modern, but classic.
https://www.instagram.com/colintempleton/
I agree, I have had 3+ copies of both those lenses over the years. They are excellent.
Maybe, and I mean maybe........4-6 years from now, but I doubt it. We are much more likely to see a 36+ mp SL before an M with high megapixel count.
FACT
*I pulled the trigger and went with a new 28 cron V2 & new 50 Summilux*
