jaapv #1 Posted February 24, 2018 Advertisement (gone after registration) Canon 2.8/35 LTM (ca 1950) Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 12 david strachan, frame-it, Louis and 9 others reacted to this Quote Share this post Link to post Share on other sites
jaapv #2 Posted February 24, 2018 .Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 2 theover and sblitz reacted to this Quote Share this post Link to post Share on other sites
jaapv #3 Posted February 24, 2018 Please add your vintage lenses Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 1 ropo54 reacted to this Quote Share this post Link to post Share on other sites
ropo54 #4 Posted February 24, 2018 (edited) Leica CL w 135 f4 elmar (1961) Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Edited February 24, 2018 by ropo54 9 Boojay, Louis, Alistairm and 6 others reacted to this Quote Share this post Link to post Share on other sites
ropo54 #5 Posted February 24, 2018 135 f4 Elmar Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 7 frame-it, justru49, Boojay and 4 others reacted to this Quote Share this post Link to post Share on other sites
Louis #6 Posted February 24, 2018 (edited) Most of the shots I am posting are made with old, MF, Nikkor lenses, 28 mm, 50 mm, 85 mm, and Angenieux with Nikon mount. I have been using these excellent lenses with much satisfaction on T and on CL. Here is one with 50 mm, f/1.4 Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! And, this is how 50 mm looks on CL, via Novoflex adapter. Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Edited February 24, 2018 by Louis 8 ropo54, Boojay, brahms_4 and 5 others reacted to this Quote Share this post Link to post Share on other sites
ayewing #7 Posted February 24, 2018 Advertisement (gone after registration) This image was taken with a vintage Elmar 65mm for Visoflex. As there is an excellent EVF in the CL there is no need to use an actual Visoflex so I have replaced it with a 41mm spacer and mounted the Elmar 65mm on its companion OTZFO 16461 Universal Focusing Mount. Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Here is the CL fiited with L-adapter-M, 41mm custom spacer,OTZFO and Elmar 65mm. Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 6 mmanda, Photon42, JMF and 3 others reacted to this Quote Share this post Link to post Share on other sites
Boojay #8 Posted February 25, 2018 Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 1972 35mm Summilux 1.4 Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 5 Ozytripper, EUSe, justru49 and 2 others reacted to this Quote Share this post Link to post Share on other sites
lct #9 Posted February 25, 2018 Define vintage please. Are seventies or eighties included? vintage lct Quote Share this post Link to post Share on other sites
jaapv #10 Posted February 25, 2018 Summarit 5 cm LTM Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 5 papimuzo, LAHilltop, ropo54 and 2 others reacted to this Quote Share this post Link to post Share on other sites
tsleica #11 Posted February 25, 2018 Too bad it does not take tiny M mount lenses directly w/o adapter for smaller profile....nice work though! Quote Share this post Link to post Share on other sites
jaapv #12 Posted February 25, 2018 It wouldn’t make a difference; you are always stuck with the register distance. Quote Share this post Link to post Share on other sites
lct #13 Posted February 25, 2018 Not sure if it is a vintage lens but my Elmar-C 90/4 from 1973 is a bargain and a keeper. Its sloping cam for Leica film CL is not a problem on M bodies let alone on the digital CL which makes no use of this cam. The Elmar-C 90/4 has not the same acutance as the Macro-Elmar 90/4 but it is sharp at all apertures throughout the field and has little distortion and CA. Only con is flare when strong light sources are just outside the frame but using a good hood plus a hand or a hat if needed fixes the issue. Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 3 Louis, Boojay and Yuhau reacted to this Quote Share this post Link to post Share on other sites
helged #14 Posted February 26, 2018 CL with Pentax Super-Takumar 1.4/50mm at f2. Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Quote Share this post Link to post Share on other sites
helged #15 Posted February 26, 2018 Ditto. Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 3 JMF, MRTEE and ropo54 reacted to this Quote Share this post Link to post Share on other sites
Louis #16 Posted February 26, 2018 (edited) Just another shot with my old MF Nikkor 50 mm on CL. Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Edited February 26, 2018 by Louis 9 david strachan, EUSe, Boojay and 6 others reacted to this Quote Share this post Link to post Share on other sites
Marcial #17 Posted February 26, 2018 Cl with 35mm Summilux PreA. Smallest 1.4 rig around Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 4 Photon42, brill64, JMF and 1 other reacted to this Quote Share this post Link to post Share on other sites
lct #18 Posted February 27, 2018 Cl with 35mm Summilux PreA. Smallest 1.4 rig around +1. The Summilux 35/1.4 pre-asph is a unique lens with its glow and softness at full aperture but it can be pretty sharp at f/2.8 and on and even at f/2 in the centre of the frame. It is a flare prone lens though so better choose a hood more efficient than the nice 12504 of the pic below. Classical 12585, 12585H or 12538 hoods work fine with the CL for those who don't need filters. Making some more shade with a hand or otherwise can be necessary when strong light sources are just outside the frame though. Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 4 tommonego@gmail.com, papimuzo, Photon42 and 1 other reacted to this Quote Share this post Link to post Share on other sites
sblitz #19 Posted March 1, 2018 Leica summicron 40mm (German made, I think before it went to Minolta) -- Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 8 lct, bags27, Hoppe and 5 others reacted to this Quote Share this post Link to post Share on other sites
grahamhoey #20 Posted March 1, 2018 Can any of the old Leica screw mount lenses be adapted to fit on the CL Quote Share this post Link to post Share on other sites
