Huu
How do I protect photography film from Xray while traveling?
7 hours ago, jaapv said:
Rather useless. If the operator cannot see the contents properly he'll rescan until he can.
Actually, what I experience with the lead bags are different. As operators usually don’t want to rescan due to incoming traffic of bags, they ask for luggage inspection right away. At least in my cases this is what has happened. I don’t remember my bag has in and out multiple times. Also as the intensity is fixed, if he can’t see, he doesn’t have much to do afaik.
Share this post
As with the other thread on the new scanners, I remain skeptical of the warning until either there is clear evidence of damage, or a statement is issued by those who have installed the scanners.
I travel internationally many times each year, and carry exposed and unexposed film through multiple entries, exits, and transits on these trips (often 5-6 Countries). I have carried both in hand-carry and in check-in. My films range from ISO 20 to ISO 400, and I do not use lead-lined bags, or ask for hand check. I have never experienced any issue with these hundreds of films (other than of my own making).
I'm currently hearing the same noise about the new scanners as has been made about the pre-existing X-ray machines. I could certainly be wrong but, until there is evidence of damage, I would have no qualms in passing my undeveloped films through the new scanners, just as I have no qualms about passing them through the existing X-ray machines (both hand-carry and check-in). Even before I get them, the films I use have all passed through cargo X-rays on their way to me in Malaysia, having ordered them from USA and Germany.
Share this post
This is directly from Kodak:
https://imaging.kodakalaris.com/sites/uat/files/wysiwyg/pro/CIS_E30.pdf
Read the paragraph under "Protect film from x-rays", which refers to the CT (Computed Tomography) scanners which were used for checked bags but are now being used more and more for carry-on, as corroborated by the TSA:
https://www.tsa.gov/computed-tomography
However, we are all free to make our own choices, because what do they know? They only make film.
Edited by plaidshirts
Share this post
My experience with lead bags through hand luggage x-ray machines is this: the operator cannot see clearly what is inside, so the contents are taken out and hand-examined.  There is no raising of intensity, there is no re-scanning.
This has happened to me in airports in all parts of Europe.  In the US I ask for a hand-check and always get it.
i often travel with Polaroid high-iso b/w film:  ISO 3200!  Usually I put this in double lead bags.
Best part of all of this, I’ve never seen any x-ray damage.
Share this post
I was fine, up until the sarcasm at the end of your final sentence. Kodak Alaris are in a position of (a) having a lot of information, and (b) being in a position where they should take all practical steps to minimise liability.
All film that I receive has passed through multiple CT scanners before I receive it. I travel very frequently, and usually have film with me (again limited to ISO 20 - 400). All I can report is that, after having taken hundreds of rolls and sheets (135 / 120 / 4x5) through both hand-carry and check-in scans, I have never experienced a problem with fogging.
I'll stick with the first part of your final sentence, and perhaps, one day, I shall suffer for it.
Share this post
This is directly from CAA UK,
Quote
Dear Fatih
Following the response to your email earlier this week one of my colleagues has informed me that the CAA have contacted several manufacturers of the new Computed Tomography equipment that is being rolled out across many airports over the next few years. These manufacturers have indicated that the equipment, due to the higher radiation dose, is more likely to affect undeveloped film. They have indicated that will be advising airport operators of this so that appropriate communications and alternative processes can be developed. In the meantime, please do continue to alert the security officer that you are carrying undeveloped film so that the airport can advise accordingly. Note that this may vary from airport to airport depending which screening equipment they have opted to deploy.
I hope this helps.
Regards
Xxx xxx
Aviation Security Regulation Team
Civil Aviation Authority
Share this post
Kodak Alaris has also updated its prior warning against moving unprocessed film through CT hand-baggage scanners, based on some tests they did at JFK with the assistance of the TSA (thanks to The Phoblographer for highlighting this): https://www.thephoblographer.com/2020/01/27/kodak-warns-against-putting-unprocessed-films-through-ct-scanners/
Share this post
It's up to you which way you do. Anything 800 ISO and above I usually take in a carry on and ask them to check by hand to be safe as you're usually ok for around 7-8 passes however if you're concerned just say its ISO 1600 and have them hand check it all!
Share this post
Unfortunately I cannot recommend this. Look how my pan-f looked like after two scans only.
Share this post
Loading...
  • Similar Content
    • By Johnkittaboon
      I have one of leica c1 kirin beer limited edition and I want to know how many leica made this compact camera in limited?
    • By Yaakov
      Disclaimer:
      I'm starting a new topic regarding the issues found in my newly purchased Leica MP, the purpose of this is to share any ideas that could lead to a solution,
      this is not a rant about Leica lack of QC which we all know is becoming an issue.
      After receiving my camera I run a roll of Kodak TriX 400, after developing the film I found a trace of scratches, I did several test with other films which I didn't develop (in case the scratches were being caused by my development process):
      Bergger Pancro 400,
      Ilford HP5+.
      They all show the same type of scratches.
      This is an undeveloped roll, https://ibb.co/RbxynrM
      https://ibb.co/8xkfs17
      I found several threads with people claim the source of this issues was the pressure plate so I checked mine in order the find anything that could be the reason, the screws in the plate don't match the position of the marks in the film and the surface of the plate in my camera feels smooth and flat, I wondered if maybe the reason could be the bridge that has the connection for the light meter but after more inspection it was obvious that the plate keeps the very flat and it does not touch that area.
      I did another test in which I rub some film on the surface of the plate, to my surprise the film was very scratched, I did the same against the plate in my 1958 M2 and it didn't do a single one.
      I also did a couple of prints to verify the scratches appear and unfortunately the scratches are visible even on a middle size print.
      This is the print, the scratches appear in the top and the bottom https://ibb.co/VpKsdfb
    • By Anigrapher
      Hallo werte Leica-Forumsteilnehmer,
      vor gut einem Jahr hatte ich mich wegen eines Belichtungsproblems meiner R4 hier im Leica-Forum bereits zu Wort gemeldet (und weiss nun endlich auch, dass der kleine Elektromagnet, der die Springblende im rechten Moment stoppen soll, defekt ist. Alle bisherigen Reparaturangebote überstiegen aber bei weitem den Wert der Kamera, so dass ich mir als "vorläufigen" Ersatz für mein R-System eine zweite R5 zugelegt habe, die auch glücklicherweise tadellos funktioniert...).
      Ich möchte Heute aber ein anderes Thema ansprechen, welches mir schon seit einiger Zeit sprichwörtlich "unter den Fingernägeln brennt": Findet ihr auch, dass innerhalb von nur gut ein bis zwei Jahren das Preisniveau der Analogfotografie exorbitant gestiegen ist???
      Klar, dass das fast schon unterirdische Preisniveau für alte Kameras, Filme, Entwickler & Entwicklungslabore von vor gut zehn Jahren längst Geschichte ist, nie mehr wiederkehren wird und sicherlich auch dem Fortbestand der filmbasierten Fotografie nicht unbedingt förderlich war. Nischeninteressen können durchaus kostspielig sein, und dazu gehört klassisches Fotografieren auf Film ja inzwischen eindeutig. Aber was jetzt gerade abgeht - ganz ohne Corona-Krise - ist nun wirklich teils schon absurd! Da werden etwa für uralte, abgelaufene 135er-Diafilme wie Agfa Precisa oder Kodak Elitechrome teilweise reinste Wucherpreise verlangt. Hier mal ein Beispiel aus dem bekannten Online-Auktionskaufhaus:  https://www.ebay.de/itm/Fur-Sammler-1x-Agfa-Agfaphoto-Precisa-CT-100-36-Diafilm-Ablaufdatum-2014-12/223921237768?hash=item3422beef08:g:-OAAAOSwvRJeTrdi Aha, für Sammler also - ernsthaft?! Es gibt wirklich schon Leute, die jetzt unbedingt noch mal einen erst vor kurzem ausgelisteten Drogeriemarkt-Diafilm verknipsen wollen und bereit sind, derartige Wucherpreise zu berappen??? Bei den gebrauchten Kameras sieht es nicht besser aus. Auch hier meint wohl mittlerweile jeder windige, Opas Keller ausräumende Erbschaftler irgendeiner banalen Durchschnitts-Spiegelreflex, er habe das große Los gezogen und müsste hinsichtlich des aufgerufenen Verkaufspreises nun einen auf Fachhändler machen. Kam mir jedenfalls so vor, als ich unlängst eine Kamera für eine fotografierende Freundin aussuchen durfte, die nicht allzu teuer sein und einen PK-Anschluss haben sollte. Also mal bei Ebay-Kleinanzeigen nach alten Ricohs umgesehen, weil diese entsprechend eigener Erfahrung einfach, gut und robust sind. Doch dann kam tatsächlich nur sowas hier bei rum: https://www.ebay-kleinanzeigen.de/s-anzeige/ricoh-xr-10-mit-zubehoer/1332175555-245-4619 Die gleiche Kamera - ich würde sie als ganz gut ausgestattetes Einsteigergerät bezeichnen - habe ich noch mit einem deutlich besseren 50er-P-Rikenon vor drei Jahren für sage und schreibe 15 Euro bei einem Fachhändler (!) als Wühltischfund erworben. Sie funktioniert übrigens ganz ausgezeichnet, was ich von den genannten Privatangeboten eher nicht erwarten würde... Ich bin wohl nicht der Einzige, dem dieses aktuelle Wucherpreisniveau auf dem Gebrauchtmarkt aufgefallen ist, auch der von mir sehr geschätzte Foto-Youtuber Steffen Schüngel hat dies unlängst thematisiert: https://www.youtube.com/watch?v=YN1hXQmbaNA
      Was meint ihr, findet ihr auch, dass die derzeit stark steigende Preisspirale im Endeffekt zu einer weiteren Abnahme an Filmfotografie-Interessierten - inzwischen soll das "Jammertal" ja schon durchschritten sein und wieder mehr auf Film fotografiert werden - und damit irgendwann zu einem selbst für den geneigten Leica-Nutzer kaum noch bezahlbaren Vergnügen werden könnte? Die verschiedenen Meinungen hierzu würden mich mal interessieren.
      Grüße an alle Leica-Fans,
      Anigrapher
    • By gwpics
      Life is pretty quiet photographically for me at the moment, mostly due to really bad weather with heavy rain which makes street photography almost impossible. This means I am continuing my journey through my archives, and this I had forgotten. It shows a typical English pastime - playing bowls. The white clothes are the standard dress for everyone, and afternoon tea is almost compulsory. English tradition at its best.
      Leica M3 + 50mm Summicron f2. Ilford 400 Delta. 1997.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By ashley12234
      Hello everyone!
      I'm new to the leica film cameras but I came up a rather very nice iiif in great condition which comes with a summarit 50mm f1.5 going for about $550. This sounded like a pretty good deal to me, however, upon closer inspection the lens seemed to have a lot of haze (not sure about fungus) as when I performed the light test there were specks everywhere. It seemed to be internal and in the second glass?? Not sure how to fix it or if I even can, also the focus ring was pretty stiff (but that isn't a deal breaker or anything). Like I said, the body of the camera was in very good condition however the lens is my biggest concern. As most of you are owners/experts and such please help me out and let me know if this is a good deal or not.
      Thanks, Ashley
    No registered users viewing this page.
Important Information
