Julian H
Developer recommendation for TMax400
Hi
I have no 400 speed in the freezer so decided do to try something different, TMax400. I have never used a T grain film before, only HP5, FP4 and PlusX. Is there a good staple starting point for a developer. Not particularly worried about grain, just a nice sharp easy to print/scan negative with good tonality and would appreciate some pointers. Also,does TMax benefit from a prewash?
Cheers, Julian
Edited by Julian H
Share this post
Hi Julian,
I use Tmax devolloper and films for over 20 Years now. Just follow the instructions on the bottle or package. You'll be fine. If you use prewash, if that is rinsing the film before developing it. It will make a difference but I never saw it. I just use the Tmax for the minutes prescribed on the bottle and use water instead of stop bath between developing and fixing ( no more than a minute ) It's important to keep you temperature of the developer on 20 degrees C. if you start . With 24 degrees everything just goes a little faster.
You will notice if you use the Tmax film, that it will keep a little purple after the final rinsing if this happens. Just rise some more.
Share this post
I haven't done too much with the T-grain films, but have liked the Ilford Delta films better than Kodak, using DD-X developer, which should work well for TMax also..
Share this post
Every developer works with Tmax, I only know that the result with Tmax developer and Tmax film is ideal.
Share this post
What have you available to choose from, what is your current "go to" combination ?
I have found Pyrocat HD to be a good choice with T-Max 400
/applications/core/interface/imageproxy/imageproxy.php?img=https://farm2.staticflickr.com/1454/25167305036_4615ae3ebe_c.jpg&key=0a67f4a8aaa6778b4979b31270a0421f7e024ad09b0e27f5c5bf50e854236b84">
/applications/core/interface/imageproxy/imageproxy.php?img=https://farm2.staticflickr.com/1703/25100403532_e6edbf1d16_c.jpg&key=8a334480ffd16b9ea709ab0c9b0ef56b235e808464aff349c22c9172c9e14d61">
/applications/core/interface/imageproxy/imageproxy.php?img=https://farm2.staticflickr.com/1704/24945639790_b4312951ff_c.jpg&key=4d9ecad6463404bb0609547705a741756301bb9db59d63b26f020e708ec85090">
Share this post
Hi
I realise I can process it in anything, I was hoping for a sweetspot combination consensus of opinion to get me up and running. My go to developer is Rodinal [usually used with HP5 and FP4] but fancied trying something new. After phoning around all the camera dealers I can think that might have some developer that I could have actually gone and picked up from yesterday* only one had stock, of LC29 and Ilfosol 3, I suspect neither of these are more suited to TMax than what I already have in stock**
I'll probably order DDX or TMax, or please convince me I should use something I already have in stock?
* I wanted to support a dealer if i could. Respect to Clocktower Cameras in Brighton for stocking two developers!
** I have a sealed 1L pack of XTol in the cupboard, not sure if it is any good though? And if I like the combination, I am going to be reluctant to buy more if only available in 5L packs now though. I also have 1L packs of ID11 and Perceptol.
Cheers, Julian
Share this post
Hi
Cheers, Julian
Julian, why not order a bottle of Tmax developer in the Netherlands here:
https://webshop.hetbeeldgebouw.nl/kodak-t-max-filmontwikkelaar-voor-5-ltr
or here;
http://www.fotohuisrovo.nl
They ship to the United Kindom, select " Groot Brittanië " . Try the 1 Liter bottle to make 5 liter ( so you can devellope about 160 to 320 films with it , if you read the instructions well )  and then you know how Tmax films reacts with Tmax developer. I did like the proces so much, that I never used Rodinal again. Xtol is a good developer with Tmax. If it's sealed it stays fresh for years, in powder form. But also the Tmax deveolper is great in conservation. A bottle of 4 year over date will give you just fine results. Even a bottle which is opened and closed again, letting the air out as much as you can, still gives good results after a year. ( providing you keep it cool and in the dark, which is no problem with my darkroom: It's a cellar see:
https://www.l-camera-forum.com/topic/186432-show-us-your-darkroom/?p=2113423
Edited by Paulus
Share this post
I use Rodinal (R09) at 1:50 for 12 - 12-1/2 minutes quite happily (because that’s what I have). As you already have Rodinal, maybe try it first?
Share this post
Hi
I can get TMax or DDX quite easily here thanks. I was mistaken I thought that with the newer films a lot of recommendations would be for newer tech developers to match but it seems far from conclusive. I am going to give XTol and Rodinal a bash first since I have them and see how I get on. Hoping the first roll tomorrow so fingers crossed!
Julian
Share this post
Hi
Julian
Maybe this will help also? http://www.imx.nl/photo/Film/styled-41/
Share this post
Just to reiterate that many developers work, I’ve used both D-76 and HC-110 dilution B, which is what I use now.
Share this post
Paulus, thanks for the link.
Regrettably I didn't finish my roll at the weekend so I'll try next weekend. Looking forward to seeing the results on this "new to me" film. although my M4-2 is now playing up on slow speeds so needs a service.
I think Ill mix up the Xtol first, just for fun though.
I wish I never sold my LS5000 scanner now!
Thanks, Julian
Share this post
I first tried TMax 100 in Rodinal, but was not impressed compared to PanF in Rodinal. I since switched to the Delta T-grain films in DD-X which gave nice results. Perhaps more experimenting with a Rodinal would have been fine. I still use Rodinal for PanF, which is what I use most.
Share this post
Tom, what dilution did you use the Rodinal? Perhaps you should have experimented a bit more like you say.
Sorry for the delay replying to this thread. I finished my first roll last weekend and started another straight away so wanted to get the second one out and process both together. I have mixed up my 1L pack of XTol and have a few queries.
Firstly and most importantly a very small "pinch" of the yellow powder did not dissolve in the water, no matter how much I stirred [water was about 25degC]. I have strained it out but wonder if that will have an effect on the correct make up of the developer? I suspect not but would appreciate if anyone else has had the problem?
Assuming the above is okay, I would appreciate a recommendation of what dilution for TMax?
Finally, hoping that this works well, does anyone part mix the currently available 5L packs of developer up, say in 2 halves?
Cheers, Julian
Share this post
I'm with EoinC, dilutions great enough to allow at least 12 minutes development. Rodinal and D76 1:1
Share this post
Hi
I referred to the massive dev chart. I did Xtol 1+1 for 10mins at 21degrees and have a lovely set of perfectly exposed films! Now I need to get them scanned...
One note, being so used to using Rodinal it is so easy to get the temperature right with 1+19/29 etc. With 1+1 it is a PITA. I will have to start thinking ahead and make myself a temperature controlled bath.
Cheers, Julian
Edited by Julian H
Share this post
Loading...
  • Similar Content
    • By Keith (M)
      Spanish seaside Casa. Leica MP, 50mm Summit-M ASPH, HP5Plus, Rodinal.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By Keith (M)
      MP, 35mm Summaron f2.8, HP5Plus.
    • By gwpics
      Taken with Leica M4-P and 35mm Summarit f2.5 using Ilford HP5+ film. This is from the first film I have home-processed in16 years and I processed it in Tetenal Paranol S (the rebranded Rodinal formula). I managed to control the resulting grain using LR Classic, bit I won't use the dev again. I bought a 'starter kit' and it was included in that but I have Ilford DD-X on order for the next film. I should have remembered Rodinal from many years ago.
      Gerry
    • By Sharif
      Und noch einmal: Parkhaus Moselstraße
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!  Diesmal in 6x6. Hatte ich noch nicht versucht.
      Fuji GF 670 W, 6x6, Trix 400@400 in Rodinal, Scan mit Epson Perfection 750 und Silverfast
      Sharif
    • By lynnb
      friendly cafe staff, Sydney 2016.
      IIIf Summitar 5cm f/2 LTM Agfa APX100 in Rodinal
    No registered users viewing this page.
Important Information
