Jared
Shutter speed limitation—why?
I just noticed in doing some tripod work that the electronic shutter has a maximum length of 1s. Why? Why cut it off at a different value from the mechanical shutter? Anyone know?
Share this post
How different is that from EFC (electronic first curtain)? I use EFC on tripod all the time for slow shutterspeed (often more than a sec) for Nex6.
Share this post
Fully electronic shutter where both the start and stop for any given exposure is controlled on the chip
Vs
The start of the exposure is determined by the chip, but the stop is done by the shutter blocking the light.
Both have the potential to reduce camera motion from the shutter itself—so called shutter shock. A fully electronic shutter has the added advantage of being completely silent, and the added disadvantage of rolling shutter and potential banding under artificial light. This is because an electronic shutter typically takes 1/30s to cycle through all the rows on the chip, while a first curtain shutter can stop the exposure in perhaps 1/200th of a second (depending on the shutter).
Share this post
Can CL use EFC? If yes, then I won't worry too much about time limit in full electronic shutter.
There is no EFC on CL. If you need silent shutter then you must use the full electronic shutter.
Edited by SrMi
Share this post
Then 1sec limitation (if conformed) is a problem for tripod work, isn't it. With EFC, you can get away with lighter tripod for long exposure.
Share this post
You can use mechanical shutter for longer exposures. I have not noticed camera blur caused by the mechanical shutter.
Share this post
The SL had a much faster limit on the electronic shutter until the latest firmware, when was also brought up to 1s.
I don't know why a slower speed is not available but I suspect it's Leica's perception of heat generation, sensor noise etc, and how to keep them under control.
Share this post
The 1 sec limitation for the electronic shutter (ES) is a constraint that Leica has put on the ES. It's the same on the SL. Leica is conservative regarding to the ES, as well as noise reduction (NR) for long exposures (always on). So at present, ES is limited to 1 sec and long exposures have NR. Both might be changed in FW updates - or at least on newer versions of the CL and SL.
Share this post
Maybe it won't be a problem. With M240 I have noticed blur at shutter speed around 1/5 sec if I use a travel type carbon tripod. The blur disappears in longer (multi second) exposure. My theory is that for longer (multi second) exposures, the camera settles soon after shutter opening and then has no effect on blur (since shutter stays longer). Of course a sturdier tripod minimizes this effect.
It maybe that CL doesn't have this issue and is probably fine for multi second exposures but I certainly would have preferred EFC. I am on the fence for CL and these small things don't help. On Nex6 I can use a long lens on a much flimsy tripod without vibration.
Share this post
Conservative in what way? What are they protecting against? Heat buildup will be the same with electronic vs. mechanical shutter, thus image degradation from thermal noise will be the same. What problem or potential problem is addressed by this limitation? I understand the required dark subtraction. Don’t like it, but I understand it. But I can’t think of any reason to allow the mechanical shutter to go longer than the electronic shutter.
Share this post
I did some indoor test shots with my 'flimsiest' tripod (Sirui T1205X) with 55-135mm @ 135mm, switching between electronic and mechanical shutter at 1 sec and 1/25 sec. Did not notice any difference, e.g., camera blur. If there is no difference at 1 sec, I assume there would no difference at longer exposures neither. Unless others observe different behavior, it seems "shutter shock" is not an issue on CL and EFC would not solve any issue.
Share this post
If true that theee is nonshutter shock, great. I haven’t tested with all my lenses yet, so not sure. I still haven’t read any explanation on why the limitation, though... It was clearly a conscious choice. Same limitation in the SL. Why do that?
Share this post
On the SL, the electronic shutter's longest speed gets shorter as the ISO is increased.  Is that also done on the CL?  Set it to 6400 and the effect should be obvious.
Share this post
I'm sure Leica have logical and deeply Germanic reasons for limiting electronic shutter range, limiting exposure times and mandatory noise reduction..... amongst other decisions that seem at odds with other manufacturers.
The real problem is they never actually explain what the logic is ...... so for the uninitiated it seems just idiosyncratic and daft.
Edited by thighslapper
Share this post
While I don't necessarily agree with the Tuetonic reasoning for:
  • Applying mandatory aperture reduction at close focus
  • Applying mandatory noise reduction when exposures exceed a certain length
  • Limiting maximum exposure duration at various ISO's
They all make sense to me.  All are decisions based upon what Leica considers acceptable image quality.  They have shown that they have minimum standards and will not allow certain photographic choices if those choices would result in Leica's standards not being met.  Again, I may not agree but I can certainly understand.
I have struggled with this one, though.  What could be the reasoning?  Why put a cutoff at 1s?
I think I have finally come up with an explanation, though...  If the exposure is more than 1s, then Leica would want to apply--the Teutonic brain would NEED to apply--long exposure noise reduction.  But one can't take a multi-second dark frame without a shutter actuation.  And electronic shutters are supposed to be silent shutters.  The camera wouldn't be silent with a multi-second electronic shutter.  The actual exposure would be silent, but the following dark-frame would not be.  The dark frame would require the shutter to be closed.  So what to do?  1s exposure cutoff.  No dark frame required. Problem solved.  Phew.  My brain can settle down now.  I have been successfully thwarted from lowering the overall Leica image quality standard by having either: (1) a long exposure that didn't receive long exposure noise reduction; or (2) an electronic shutter that made a noise.  What a disaster those two would have been!  Thank goodness Leica has again saved me from the error of my ways.
Edited by Jared
Share this post
I am not sure I understand why you would need to use ES rather than mechanical shutter for long exposures. What am I missing?
Share this post
Loading...
    No registered users viewing this page.
