Wojtek Posted October 14, 2017 Share #1 Posted October 14, 2017 (edited) Advertisement (gone after registration) Hey, I know many of you guys tried manual lenses on TL2 (or T/TL). Have you tried focusing via LCD? Does it work? And the most important question: Is it possible to reliably focus manually for portraits with big bokeh (i.e. 75mm f/2 headshot) using only the LCD on Leica TL2? By reliably I mean it's mostly accurate and doesn't last 5 seconds or so. Do you have any experience with that? Thanks! Edit. One more probably supersilly question - is there any important difference in manually focusing the Summilux-TL and Summilux M? I mean, I can test the Summilux-TL 35mm at manual focusing. If I find it easy / hard / whatever - will my opinion be the same while manually focusing M-mount 35mm? I don't know, maybe focus peaking works better on TL lenses or there's any other reason I don't take into account Edited October 14, 2017 by Wojtek Quote Link to post Share on other sites More sharing options...
Advertisement Posted October 14, 2017 Posted October 14, 2017 Hi Wojtek, Take a look here Manual focusing without the EVF. I'm sure you'll find what you were looking for!
frame-it Posted October 14, 2017 Share #2 Posted October 14, 2017 on the T, before i bought the visoflex, i shot hundreds of pics using only the LCD..in focus at f2..just wait for the "shimmer" and shoot Hey, I know many of you guys tried manual lenses on TL2 (or T/TL). Have you tried focusing via LCD? Does it work? And the most important question: Is it possible to reliably focus manually for portraits with big bokeh (i.e. 75mm f/2 headshot) using only the LCD on Leica TL2? By reliably I mean it's mostly accurate and doesn't last 5 seconds or so. Do you have any experience with that? Thanks! Edit. One more probably supersilly question - is there any important difference in manually focusing the Summilux-TL and Summilux M? I mean, I can test the Summilux-TL 35mm at manual focusing. If I find it easy / hard / whatever - will my opinion be the same while manually focusing M-mount 35mm? I don't know, maybe focus peaking works better on TL lenses or there's any other reason I don't take into account 1 Quote Link to post Share on other sites More sharing options...
hifly Posted October 15, 2017 Share #3 Posted October 15, 2017 (edited) I have been focusing with the LCD only at F1.1 (50mm) and works fine. In some shots I miss focus but that is often the case at F1.1 anyway. The focus travel might be very different in the TL lenses compared to M lenses. Edited October 15, 2017 by hifly Quote Link to post Share on other sites More sharing options...
McGirton Posted October 20, 2017 Share #4 Posted October 20, 2017 It's possible, although of course a bit trial and error. It worked for me even without the original M Adaptor T which gives you an enlarged area for easier focussing. A little neat trick I always used was to activate the video preview (swipe left to right on the screen). The video preview is zoomed in further than the single shot one is, so you can focus way easier. You'll get a hang of it and get better with it over time. Quote Link to post Share on other sites More sharing options...
hifly Posted October 23, 2017 Share #5 Posted October 23, 2017 It's possible, although of course a bit trial and error. It worked for me even without the original M Adaptor T which gives you an enlarged area for easier focussing. A little neat trick I always used was to activate the video preview (swipe left to right on the screen). The video preview is zoomed in further than the single shot one is, so you can focus way easier. You'll get a hang of it and get better with it over time. You can assign focus aid to your left dial for a 3x and 6x view. Quote Link to post Share on other sites More sharing options...
McGirton Posted October 24, 2017 Share #6 Posted October 24, 2017 You can assign focus aid to your left dial for a 3x and 6x view. Only with the original M adapter T, which I didn't have at that time. Quote Link to post Share on other sites More sharing options...
Rick1008 Posted October 24, 2017 Share #7 Posted October 24, 2017 Advertisement (gone after registration) Hi Guys, I traded in my Sony RX1 for the Leica T. If i only use the LCD screen to manual focus, at f1.4, is it do-able? Can I still assign focus aid to the left dial, if im not using the OEM leica adaptor mount? Thanks in advance, Rick Quote Link to post Share on other sites More sharing options...
hifly Posted October 25, 2017 Share #8 Posted October 25, 2017 Hi Guys, I traded in my Sony RX1 for the Leica T. If i only use the LCD screen to manual focus, at f1.4, is it do-able? Can I still assign focus aid to the left dial, if im not using the OEM leica adaptor mount? Thanks in advance, Rick In my opinion, it is do-able even at f1.1 as I mentioned above. I have shot my kids which move all the time and with little experience in manual focusing. The LCD is pretty accurate. And I do have a third party adapter (with no electronics what so ever) and can assign focus aid to the left dial. Many talk about the so called "shimmer" which appears on the in-focus subject and you can see it. In my experience, it helps to have the image settings for high contrast and high sharpness as I think they effect what you see in the LCD as well. Later, you can edit however you wish with the RAW file. Quote Link to post Share on other sites More sharing options...
Rick1008 Posted October 25, 2017 Share #9 Posted October 25, 2017 Hifly! Thank you so much for your reply. Quote Link to post Share on other sites More sharing options...
