artrek99 Posted September 10, 2017 Share #1 Posted September 10, 2017 (edited) Advertisement (gone after registration) Hello. I've recently received my M10 and noticed the mirror behind the range finder window was in a rather unusual position compared to other Ms I have seen(including the M10 on display at the Leica store). The mirror seems to have been placed offset toward the left side of the window leaving larger than usual gaps on the right side of the window. Is this normal? Should I take it back for a replacement or there's absolutely nothing to worry about? I've attached a photo which hopefully helps explain what I'm on about. Thank you kindly in advance. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited September 10, 2017 by artrek99 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/276674-m10-range-finder-window-issue/?do=findComment&comment=3355693'>More sharing options...
Advertisement Posted September 10, 2017 Posted September 10, 2017 Hi artrek99, Take a look here M10 range finder window issue?. I'm sure you'll find what you were looking for!
jaapv Posted September 10, 2017 Share #2 Posted September 10, 2017 Does the rangefinder work? Quote Link to post Share on other sites More sharing options...
artrek99 Posted September 10, 2017 Author Share #3 Posted September 10, 2017 Does the rangefinder work? Hi jaapv, seems to work so far. I've only tried it with 28mm Elm but I assume it'd be the same on any lens. Quote Link to post Share on other sites More sharing options...
jaapv Posted September 10, 2017 Share #4 Posted September 10, 2017 Elmarit I suspect? If the rangefinder works fine, I would say there is nothing to worry about. Maybe you looked through the window at different angles. Moreover, the mirror moves with the distance setting on the lens. If one camera was at infinity and the other at 1 m., one would expect to see a different position of the mirror. Quote Link to post Share on other sites More sharing options...
