JeTexas Posted July 5, 2017 Share #21 Posted July 5, 2017 Advertisement (gone after registration) I've got a 1960s 90mm Elmarit and it has been fantastic for portraits. Plus they're only about $200 these days, so at that price you pretty much can't go wrong. The 135mm Hektor is also a quite moody/flattering portrait lens for under $100. Quote Link to post Share on other sites More sharing options...
Advertisement Posted July 5, 2017 Posted July 5, 2017 Hi JeTexas, Take a look here 90mm for portrait Advice. I'm sure you'll find what you were looking for!
TheDrift- Posted July 5, 2017 Share #22 Posted July 5, 2017 Well having moved into Leica and picked up the 35 cron and 50 lux together with a new camera the camera find is running a little low, so cheap defiantly is attractive right now! I think I still leaning towards a 90 f2 pre asph they seem to go from around 800-1000 UK. Might then pick up something vintage to have some fun with Quote Link to post Share on other sites More sharing options...
Guest camera man Posted July 5, 2017 Share #23 Posted July 5, 2017 The problem with the Leica Lens's in the UK is the ever increasing price rise. Late last year I purchased the 90mm APO for £2,500 GBP and now its £3,150 / £3,500 and its the same for the 50mm APO now £6,300, an ever increasing price hike!! God help us when we leave the EU. Not good for Leica shooters in the UK. Quote Link to post Share on other sites More sharing options...
pico Posted July 5, 2017 Share #24 Posted July 5, 2017 (edited) 90mm? No! 75mm, f/2.5 because you will likely want an f/stop that fits properly. 75mm is rational. Focus will be more accurate. It is less expensive than alternatives and better for your purposes. Edited July 5, 2017 by pico 1 Quote Link to post Share on other sites More sharing options...
spydrxx Posted July 6, 2017 Share #25 Posted July 6, 2017 light, infrequently used - unless sharpness is your bag, I'd go for an Elmar...nice older traditional rendering...and very inexpensive. Quote Link to post Share on other sites More sharing options...
michaelwj Posted July 6, 2017 Share #26 Posted July 6, 2017 90mm? No! 75mm, f/2.5 because you will likely want an f/stop that fits properly. 75mm is rational. Focus will be more accurate. It is less expensive than alternatives and better for your purposes. Sorry pico, but I don't follow your logic (or lack of). What do you mean by "an f/stop that fits properly"? how does f/2.5 fit properly where f/2 of f/2.8 don't? (I won't mention that there is also a 90/2.5, reducing any argument you might have had to dust) How is 75mm more "rational" than 90mm? I would say considering the OP has a 50mm already, that 75mm is irrational. Sure, focus with a shorter focal length will be easier with an RF. We can easily extend that further and eliminate the 75mm in favour of the 50mm, and then eliminate that in favour of 35mm, and you get the drift. I only use a 15mm now - much easier to focus and who cares if it's not the focal length I want right. Which 75/2.5 is less expensive (and less expensive than what)? Better for whose purposes? On the other hand, assuming your post was "tongue in cheek", a grin is colon-D, like this It makes it clear that you are only kidding... Quote Link to post Share on other sites More sharing options...
microview Posted July 6, 2017 Share #27 Posted July 6, 2017 (edited) Advertisement (gone after registration) "Which 75/2.5 is less expensive (and less expensive than what)?" cheaper than the 2.4 if you can find new copy of the superseded (hoodless) v1. It's still listed by Red Dot Cameras. Edited July 6, 2017 by microview Quote Link to post Share on other sites More sharing options...
pgk Posted July 6, 2017 Share #28 Posted July 6, 2017 I think I still leaning towards a 90 f2 pre asph they seem to go from around 800-1000 UK. I've had 2 or 3. Do check focus calibration, as these can be off which is hardly surprising given their age. For the prices you quote I'd want one that was working perfectly so its worth buying from a reputable dealer with an agreement that the lens will be adjusted if required. Quote Link to post Share on other sites More sharing options...
lct Posted July 6, 2017 Share #29 Posted July 6, 2017 (edited) My experience is limited to 75/2.5 and 90/2.4 lenses as far as Summarits are concerned but they feel very close actually. The 90/2.4 is a bit softer in borders and corners but otherwise both lenses render pretty well the same. The 75/2.5 is just smaller and may give a feeling of near perfection due to its lack of significant flaw, with a shorter focus distance for the f/2.4 version. Great companion to 35mm or 40mm lenses but i've always preferred 90's to complement 50mm lenses rightly or wrongly. Compared to Elmarit 90/2.8 v2, the Summarit 90/2.4 has a bit more edge acutance at f/2.8 so i would not use it for less than perfect skins. Summicron 90/2 v3 and Summilux 75/1.4 are my favorites for them but Elmarit 90/2.8 (v2 or softer v1) is just OK if f/2.8 is fast enough for one's needs. For those tempted by 75mm, some f/2.5 new copies can be had on e**y for less than 1000 EUR currently. They have a 0.9m minimum focus distance though which may feel frustrating if you don't use the lens on a Sony body. That of 75/2.4 is 0.7m vs 0.9m for 90/2.4 and 1m for 90/2, 90/2.5 and 90/2.8. FWIW. Edited July 6, 2017 by lct Quote Link to post Share on other sites More sharing options...
Photon42 Posted July 6, 2017 Share #30 Posted July 6, 2017 Having the 90 AA and the earlier Summarit, the latter sees far more usage. Shade not needed normally in my experience. This https://www.l-camera-forum.com/topic/268528-m10-the-image-thread/?view=findpost&p=3274971 was done with the Summarit. It is barely longer than the Summilux 50, without the hood. This makes it a wonderful companion. 1 Quote Link to post Share on other sites More sharing options...
oldwino Posted July 6, 2017 Share #31 Posted July 6, 2017 Find a nice Elmar 90/4 3-element. Light, sharp as you need stopped down, unique rendering. 1 Quote Link to post Share on other sites More sharing options...
Ko.Fe. Posted July 6, 2017 Share #32 Posted July 6, 2017 I have Elmarit-M collapsible 90 f4, which nobody wanted for well under 200$. It is true Leica lens and works great not only for film but on digital M. On M8 On M-E, both at F4: Quote Link to post Share on other sites More sharing options...
rodoleica Posted July 6, 2017 Share #33 Posted July 6, 2017 I've got a 1960s 90mm Elmarit and it has been fantastic for portraits. Plus they're only about $200 these days, so at that price you pretty much can't go wrong. The 135mm Hektor is also a quite moody/flattering portrait lens for under $100. Indeed and the Hector 135 gives a nice rather poetic picture, it has its own character for flowers and nature taken at mid-distance. Quote Link to post Share on other sites More sharing options...
lct Posted July 6, 2017 Share #34 Posted July 6, 2017 I have Elmarit-M collapsible 90 f4, which nobody wanted for well under 200$. It is true Leica lens and works great not only for film but on digital M. [...] +1. Got my beaten one for half less in the eighties. Bit soft at f/4 with a lot of flare but plenty sharp above and it works quite well on my M240 and Sony A7s mod. @ Newbies Beware not to collapse the lens too deeply (or at all) in the camera though. There is a warning about this in all digital M's instructions manuals IIRC. Quote Link to post Share on other sites More sharing options...
colint544 Posted July 7, 2017 Share #35 Posted July 7, 2017 I thought someone might have made the case for the 90mm Tele-Elmarit "fat" version 1. I have a 1969 copy, and I find it to be superb. It's very sharp indeed, although at full aperture, there's a fair bit of the fabled "glow" around the edges of the frame. But that's quite nice for portraits. The 90mm Tele-Elmarit "fat" version 1 is tiny - around the same size and weight as the 50mm Summilux ASPH. It's extremely well made. It's also ridiculously cheap. And you can get it in either silver chrome, or black. I got mine off eBay back in 2011. Because it was so cheap, I felt I wasn't taking much of a risk. But I really like it. I attach a photo I took using it with an M9, in Glasgow. Here is Ken Rockwell's slightly tongue-in cheek review - http://www.kenrockwell.com/leica/90mm-f28-fat.htm Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 9 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/274106-90mm-for-portrait-advice/?do=findComment&comment=3310304'>More sharing options...
Simon Posted July 8, 2017 Share #36 Posted July 8, 2017 Love that shot Colin! 1 Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted July 8, 2017 Share #37 Posted July 8, 2017 I thought someone might have made the case for the 90mm Tele-Elmarit "fat" version 1. I have a 1969 copy, and I find it to be superb. It's very sharp indeed, although at full aperture, there's a fair bit of the fabled "glow" around the edges of the frame. But that's quite nice for portraits. The 90mm Tele-Elmarit "fat" version 1 is tiny - around the same size and weight as the 50mm Summilux ASPH. It's extremely well made. It's also ridiculously cheap. And you can get it in either silver chrome, or black. It was surely me the made the case... is a little gem I have always loved in >25 years of usage... Agree an all your comments but... recently is not so "Ridicously cheap" indeed... fine items lean often around 1KEuro ... but is good value for money, anyway. 2 Quote Link to post Share on other sites More sharing options...
colint544 Posted July 8, 2017 Share #38 Posted July 8, 2017 It was surely me the made the case... is a little gem I have always loved in >25 years of usage...Agree an all your comments but... recently is not so "Ridicously cheap" indeed... fine items lean often around 1KEuro ... but is good value for money, anyway. I do apologise - you absolutely did! I think I must skimmed over that. It is such a great little lens. So compact, that's what did It for me. Quote Link to post Share on other sites More sharing options...
Beena22 Posted July 9, 2017 Share #39 Posted July 9, 2017 The Elmar-C is a an affordable gem in my opinion. Can be picked up for peanuts and renders lovely. It's also really compact. It's one of my favourite lenses. Here are a couple shot on an A7 5 Quote Link to post Share on other sites More sharing options...
mp58 Posted July 10, 2017 Share #40 Posted July 10, 2017 I once owned the 90/2 Asph, but for me, it was almost too sharp, and it was too big to lug around, so I sold it. I am quite happy with my v1 90/2.8, my 90/2.8 Fat TE, and my 90/4 Elmar-C. I use the TE and Elmar-C the most, given their small size and (for me) excellent IQ. Quote Link to post Share on other sites More sharing options...
