LUF Admin Posted June 29, 2017 Share #1 Posted June 29, 2017 Advertisement (gone after registration) Leica just published the firmware update 1.7.4.0 for the Leica M10 which brings improved compatibility with all SD cards. About 40 forum members tested the update in a closed beta test. 50 different SD cards of various manufacturers were tested, especially products which caused problems in the past. The result: Zero complaints! Thus we recommend to install the firmware as soon as possible. You'll find it in the Leica website's support area: » Download Leica M10 Firmware From the official installation instructions: Improvements of SD card compatibility Effective immediately a larger choice of SD cards is compatible with the Leica M10. With the last Firmware, certain SD cards were not recognized, or the complete write speed could not be used with the camera. The Leica M10 supports SDHC/SDXC cards from 1GB up to 512 GB. We recommend to use cards with write speed 80 MB/s or higher in order not to restrict the cameras performance. In single cases it can occur that the speed, stated by the cards manufacturers, differs from the effective read or write speed in the Leica M10. Use UHS I cards instead of UHS II. The M10 is compatible with UHS II cards, but does not use the full UHS II speed. Leica performs ongoing compatibility tests of the latest cards available in the market. We ask for your understanding that due to potential changes in production batches and software of SD cards asthey are manufactured and brought to market, Leica cannot guarantee a 100% compatibility of the recommended cards. Quote Link to post Share on other sites More sharing options...
Advertisement Posted June 29, 2017 Posted June 29, 2017 Hi LUF Admin, Take a look here Leica M10 Firmware Update: Improved SD Card Reliability. I'm sure you'll find what you were looking for!
marcg Posted June 29, 2017 Share #2 Posted June 29, 2017 Thank you. It went very smoothly. The process took rather longer than I expected – so don't get impatient. Also, unless I blinked, there was no message saying that the installation had finished always complete or successful. The camera simply switched itself off without warning. Switched it back on and everything was fine. Quote Link to post Share on other sites More sharing options...
M11 for me Posted June 29, 2017 Share #3 Posted June 29, 2017 Thanks for the info. Does it make sense to install the update in cases were there are no SD-card issues at all? Quote Link to post Share on other sites More sharing options...
Per P. Posted June 29, 2017 Share #4 Posted June 29, 2017 The guidelines make it look like a very smooth process but there were two discrepancies: 1) I was not asked if I wanted to save my user profiles before installation started up (but thankfully my profiles were kept intact) 2) Same as for marcg the camera simply closed down at the end so I needed to switch it off and on to proceed - a little disconcerting with the strong warning not to switch the camera off. Once I switched the camera back on the firmware was updated, my profiles were still there and everything seems to work just fine. Touch wood. 2 Quote Link to post Share on other sites More sharing options...
digitalfx Posted June 29, 2017 Share #5 Posted June 29, 2017 Thanks for the info. Does it make sense to install the update in cases were there are no SD-card issues at all? Yes, I would recommend updating regardless. It also resolves a couple bugs and is quite stable. 2 Quote Link to post Share on other sites More sharing options...
M11 for me Posted June 29, 2017 Share #6 Posted June 29, 2017 Thx Quote Link to post Share on other sites More sharing options...
waterman1 Posted June 29, 2017 Share #7 Posted June 29, 2017 Advertisement (gone after registration) Updated the new firmware, in camera information, I see the correct firmware but it is greyout. Is this normal? Quote Link to post Share on other sites More sharing options...
Overgaard Posted June 29, 2017 Share #8 Posted June 29, 2017 It goes like this after you click YES to updating the firmware: Firmware updates uncompresses (1/2 minute), installs (3.5 minutes) and optimizes (ca. 10 seconds). The screen then says "Update Successfull" for 10 seconds and turns off the screen. I think the profiles is only asked if you actually have set up your own user profiles. 3 Quote Link to post Share on other sites More sharing options...
rsmphoto Posted June 29, 2017 Share #9 Posted June 29, 2017 Never had a firmware update issue from M9 to M240, but now at end of update.... optimization, then "system will restart now", then nothing. So manually restarted camera only to find the update didn't take. After third attempt it finally took. A bit disconcerting. Quote Link to post Share on other sites More sharing options...
Overgaard Posted June 29, 2017 Share #10 Posted June 29, 2017 (edited) Updated the new firmware, in camera information, I see the correct firmware but it is greyout. Is this normal? Yes. There would only be other/more info if there is a newer firmware available on the SD card. Edited June 29, 2017 by Overgaard Quote Link to post Share on other sites More sharing options...
Per P. Posted June 29, 2017 Share #11 Posted June 29, 2017 Thorsten, your last sentence is a good guess but incorrect. I had user profiles defined and was relieved that they survived intact despite the process discrepancy. It goes like this after you click YES to updating the firmware: Firmware updates uncompresses (1/2 minute), installs (3.5 minutes) and optimizes (ca. 10 seconds). The screen then says "Update Successfull" for 10 seconds and turns off the screen. I think the profiles is only asked if you actually have set up your own user profiles. 1 Quote Link to post Share on other sites More sharing options...
roverover Posted June 29, 2017 Share #12 Posted June 29, 2017 Yes, I would recommend updating regardless. It also resolves a couple bugs and is quite stable. Curious, have any of the other "Bugs" that might have been addressed been listed anywhere for owners to see? Just curious as everything i have read about this FW update only discusses the SD card compatibility improvements, thanks. Quote Link to post Share on other sites More sharing options...
otto.f Posted June 29, 2017 Share #13 Posted June 29, 2017 (edited) Installation goes very smooth. I must say however, that the Menu guys of the M10, compared to M9, were a bit panicky in the program process. You get messages in red like: DON'T REMOVE THE BATTERY!! This is not an incident: the messages when the battery is low aren't overly ZEN either Edited June 29, 2017 by otto.f Quote Link to post Share on other sites More sharing options...
scott kirkpatrick Posted June 29, 2017 Share #14 Posted June 29, 2017 I had a similar experience: no option to save my settings (I don't have a profile defined), but it just launched into the decompression stage. About five minutes in all. I wasn't watching to see the messages as it finished. But when I switched it on, everything was as I had set it. scott Quote Link to post Share on other sites More sharing options...
Tony Cole Posted June 29, 2017 Share #15 Posted June 29, 2017 Glad to hear some others had an unnerving moment or two when installing 1.7.4.0. - Mine didn't "take" till the second try, but then all was fine........... And I am hoping that the odd glitch I had noticed with the 32gb card I'm using - such as card not being recognised until I try repeatedly to get it to be - are now going to be things of the past............. Tony Quote Link to post Share on other sites More sharing options...
Guest Posted June 29, 2017 Share #16 Posted June 29, 2017 I saw the successful message. The M10 was switched off. When I changed the SD card and switched on again. Camera information now showed (greyed out) firmware = 0.16.24.12! I was of course expecting to see 1.7.4.0 !!!! Camera seems to be working normally, my profiles are still there. Quote Link to post Share on other sites More sharing options...
digitalfx Posted June 29, 2017 Share #17 Posted June 29, 2017 Curious, have any of the other "Bugs" that might have been addressed been listed anywhere for owners to see? Just curious as everything i have read about this FW update only discusses the SD card compatibility improvements, thanks. The 4th bug listed here was fixed: https://www.l-camera-forum.com/topic/268492-m10-fw-requestsbug-reports/ discussed here: https://www.l-camera-forum.com/topic/269358-camera-crash-with-visoflex-continuous-mode/?do=findComment&comment=3212371 Quote Link to post Share on other sites More sharing options...
6bit Posted June 30, 2017 Share #18 Posted June 30, 2017 FW update went smooth as butter. I wish Sony FW updates worked the same way. Quote Link to post Share on other sites More sharing options...
Guest JMF Posted June 30, 2017 Share #19 Posted June 30, 2017 The guidelines make it look like a very smooth process but there were two discrepancies: 1) I was not asked if I wanted to save my user profiles before installation started up (but thankfully my profiles were kept intact) 2) Same as for marcg the camera simply closed down at the end so I needed to switch it off and on to proceed - a little disconcerting with the strong warning not to switch the camera off. Once I switched the camera back on the firmware was updated, my profiles were still there and everything seems to work just fine. Touch wood. +1 Quote Link to post Share on other sites More sharing options...
Magic Posted June 30, 2017 Share #20 Posted June 30, 2017 Nice, smooth and straight forward...since I didn't have any problems with my Lexar 64GB 2000x at all, I still decided to upgrade. Maybe some other (hidden) improvements are there, e.g. Video :-) 1 Quote Link to post Share on other sites More sharing options...
