The Leica Forum uses cookies. Read the privacy statement for more info. To remove this message, please click the button to the right:    OK, understood.
Focus technique, Diopters and Magnifiers
  • Please log in to reply
3 replies to this topic
#1 jaapv
  • Moderators
  • 50,246 posts
  • LocationBehind a Red Dot
  • City / Ort:Hellevoetsluis
Posted 10 March 2017 - 08:37
Advertisement (Gone after free registration)
I come from an autofocus camera background. What is the best way to get good focus on an M camera?
The M is a rangefinder camera, the central patch in the viewfinder is your focusing tool.
It is important to look through the viewfinder in the optical axis. Looking into the camera skewed will result in inaccurate focus.
The first thing to do is to ascertain that you can see the rangefinder patch properly. A correct match between the rangefinder and your eye is even more important than it is using an SLR.
Leica sells corrective diopter lenses. Determining which one you need - if any- can be done by going to your optician and holding his try-out lenses between your eye and the viewfinder. The one that allows you to see the rangefinder patch and framelines sharply is the correct one. Order the nearest value from Leica. In a pinch you can use over-the-counter reading glasses for this test. If your eyes need special corrections, you can use your spectacles, provided you can see clearly at 2 meters distance ( the virtual distance of the rangefinder patch). Note that the background will be at background distance,so your eye should ideally be able to accommodate over the distance differential. However, there is some tolerance here.
Note that the -0.5 diopter value that is built into the viewfinder is there for this reason. For an ideal eye it compensates for the virtual distance of framelines and focus patch @ 2 m.
It is possible to calculate the diopter value, but that should be left to an expert.
If there is astigmatism present the diopter value can only be corrected for one camera position. However Walter Leica provides an intelligent solution:
For special cases there are viewfinder magnifiers. (for the time being they are only available in the old diopter size and must be used with the diopter adapter on the M10) They can help, especially with longer and fast lenses and they can give confidence, but they can also be not very useful; they cannot correct errors in the focusing mechanism or your eye, in fact they magnify them.
Also, one loses contrast and brightness.
Leica offers a 1.25x one and a 1.4x. These need diopter correction like the camera, but often of a different value than the camera viewfinder.
There are also third-party magnifiers, sold by Japan Exposures, that include a variable diopter correction. 1.15x and 1.35x. For patent reasons they cannot be sold in the USA and Germany for use on a Leica camera, but they can be purchased for use on for instance a rifle scope.
Basically, for an experienced user, magnifiers are not needed and will only lower contrast and brightness, but many users do like and use them.
Once the viewfinder is corrected optimally, there are three methods of focusing, in ascending order of difficulty aka training.
1. The broken line method. Look for a vertical line in the image and bring it together in the rangefinder patch to be continuous.
2. The coincidence method. Look for a pattern in the image and bring it together to coincide. This may lead to errors with repeating patterns.
3. The contrast method. Once you have focus by method 1. or 2. a small adjustment will cause the rangefinder patch to "jump" into optimum contrast. At that point you have the most precise focussing adjustment.
Side remarks:
If you try focusing on a subject emitting polarized light like a reflection it may happen that the polarizing effect of the prism system in the rangefinder will blot out the contrast in the rangefinder patch, making focusing difficult. In that case rotate the camera 90 degrees to focus.
  • hlockwood, SPB2, digitalfx and 3 others said thank you
Posts in blue bold font are made as a moderator
Leica user since 1976
If you're not right... turn left.
#2 LouK
    Neuer Benutzer
  • Members
  • PipPip
  • 24 posts
  • City / Ort:Los Angeles
Posted 26 May 2017 - 07:06
This question applies to all M cameras.
I recently had cataract surgery and my distance eyesight is now 20-20. However, close up for reading I need a +1.75 or + 2.0 diopter reading glasses.
For my M240 and M10, I put on a +0.5 diopter for lenses 50mm and wider. This makes sense to me as I understand the camera’s viewfinder is -0.5 diopter. No problem as this works well!
When I use my 75 or 90 mm lens I put on the Leica 1.25 magnifier. However, to see clearly I needed a +1.5 diopter correction.
Does the magnifier have a -1.0 diopter correction or is the image so much closer that I need an adjustment similar to my reading glasses?
  • leohong said thank you to this
#3 jaapv
  • Moderators
  • 50,246 posts
Posted 26 May 2017 - 07:28
The -0,5 diopter correction is there for a reason.
It facilitates the accommodation of the eye between 2 m - the virtual distance of the framelines - and the distance of the subject (the other part of the image in the viewfinder, which is anything between 1m and infinity.
For somebody with ideal vision it should not be "corrected", as it is the ideal value for easy focusing.
However, after cataract surgery, your eye cannot accommodate any more, so you cannot focus  on the subject and the rangefinder patch at the same time, or find the correct distance to focus your eye on. The magnifier only magnifies this effect and will not help you focus better, in fact it will make things worse, as you found out.
Your reading glasses  will focus to 30 cm, so they are far too strong to use on the 2 m distant rangefinder patch.
If you want to find the correct diopter strength for your eyes, visit the optician and use his tryout glasses to determine the correct diopter strength. The correct value can be calculated by an expert (but even then be slightly off) and trial and error is by far the most practical and surefire method.
It is completely normal in practice to need different diopters on the magnifier and the ocular .
I think that in your case using the EVF for longer focal lengths is the best solution, but finding the correct diopters might just work.
  • LouK said thank you to this
#4 riswanc
    Erfahrener Benutzer
  • Members
  • 167 posts
Posted 29 May 2017 - 03:49
I have sent email to walter leica, but i think it takes some time for him to respond
Sent from my iPhone using Tapatalk
0 user(s) are reading this topic
