Guest Posted February 3, 2017 Share #41 Posted February 3, 2017 Advertisement (gone after registration) What is the thing that stands out to you on the M10 then? My first thought was about being able to set all the important settings before even the camera is on, having visualised an image first, along with the light conditions etc. Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 3, 2017 Posted February 3, 2017 Hi Guest, Take a look here Leica M10 and Hasselblad X1D. I'm sure you'll find what you were looking for!
CYBORA Posted October 27, 2017 Share #42 Posted October 27, 2017 Is there any M-Mount adapter available for X1D ? Quote Link to post Share on other sites More sharing options...
rent Posted October 27, 2017 Share #43 Posted October 27, 2017 I'm not exactly sure you mean to use M lenses on the X1D, or vice versa. But I doubt they would be compatible in either direction for: 1) M lenses do not project large enough image circle to cover the 44x33mm sized sensor of the X1D. 2) XCD lenses are drive by wire that require signaling from the camera body. Any adapter to mount the XCD lenses would need to implement the same signaling, which is probably difficult, or proprietary to Hasselblad, or both. Alex Is there any M-Mount adapter available for X1D ? 1 Quote Link to post Share on other sites More sharing options...
paulsydaus Posted November 3, 2017 Share #44 Posted November 3, 2017 How do you find the output from both the M10 and X1D? Any comparisons? You may well have made the best decision possible for your needs. The world's changing again! None of them are poor cameras, unless they don't work or you can't afford them... Sent from my iPhone using Tapatalk Quote Link to post Share on other sites More sharing options...
CYBORA Posted November 3, 2017 Share #45 Posted November 3, 2017 Is there any M-Mount adapter available for X1D ? A note for my own question, Kipon has introduced a new adapter for using M lenses on X1D http://www.kipon.com/en/articledetail.asp?id=115 Quote Link to post Share on other sites More sharing options...
jaapv Posted November 3, 2017 Share #46 Posted November 3, 2017 Quite a few of them will vignette heavily. Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted November 3, 2017 Share #47 Posted November 3, 2017 (edited) Advertisement (gone after registration) Quite a few of them will vignette heavily. By sure... the image circle is over 11mm larger in diameter...+26,6%... strange device... apart for taking 24x36 images on 30MP around... Edited November 3, 2017 by luigi bertolotti Quote Link to post Share on other sites More sharing options...
rent Posted November 3, 2017 Share #48 Posted November 3, 2017 Indeed! I stand corrected of my previous comment. A user has posted some photos with this adapter, the vignetting looks much better than expected: http://www.hasselbladdigitalforum.com/index.php?topic=5313.0 Alex A note for my own question, Kipon has introduced a new adapter for using M lenses on X1D http://www.kipon.com/en/articledetail.asp?id=115 Quote Link to post Share on other sites More sharing options...
Simon Posted November 4, 2017 Share #49 Posted November 4, 2017 I can’t see the pic in that thread. Do you have to log in? Quote Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted November 4, 2017 Share #50 Posted November 4, 2017 Yep. You need to log in. It's a single picture shot with the X1D and a 1957 summicron. I think the corners are too dark for general use. You'll need to crop or frame with a darker background. But some lenses will cover the image circle. Personaly I'm not getting one but I've ordered the Canon EF adaptor. Now that'll be interesting..... Gordon Quote Link to post Share on other sites More sharing options...
Simon Posted November 5, 2017 Share #51 Posted November 5, 2017 I’m not going to join their forum just to see a pic but if the owner is a member here I’d like to see it. Quote Link to post Share on other sites More sharing options...
rent Posted November 5, 2017 Share #52 Posted November 5, 2017 Do we have info on the image circle sizes of M-lenses? Sounds like some are larger than others? I was quite surprised to see how little vignette there was with the '57 cron. ... But some lenses will cover the image circle... Quote Link to post Share on other sites More sharing options...
Ronazle Posted August 10, 2018 Share #53 Posted August 10, 2018 After looking at some posted results it would seem that a number of Leica RF and Viso lenses would provide a more than satisfactory image. Given the possible use of some Leica lenses for smaller frame MF perhaps its time for manufacturers to post lens test results for a larger radius or make them available on request? Regards, Ron Quote Link to post Share on other sites More sharing options...
