wattsy Posted January 24, 2017 Share #1 Â Posted January 24, 2017 Advertisement (gone after registration) Has anybody bought filters for the new version of the 28mm Summaron? It is described as having an E34mm thread which is not a common size nowadays, to say the least. Heliopan still make coloured filters (largely special order) for 34mm but I'm not 100% certain whether the thread pitch is the same as the one used on the 2016 version of this lens. Fotoimpex describe the Heliopan 34mm filter as having an 0.5 pitch. Link to post Share on other sites More sharing options...
Advertisement Posted January 24, 2017 Posted January 24, 2017 Hi wattsy, Take a look here Filter size for 28mm F5.6 Summaron-M. I'm sure you'll find what you were looking for!
Ronazle Posted January 24, 2017 Share #2  Posted January 24, 2017 Watsy, You need an SOOGZ (13154) adapter which will allow use of regular 39mm filters. It is a well made tension screw based adapter that doesn't look particularly bad. There is a picture of it in the WIKI. I have used it over the years many times with my vintage 28mm Summaron. Regards, Ron 2 Link to post Share on other sites More sharing options...
wattsy Posted January 24, 2017 Author Share #3 Â Posted January 24, 2017 Watsy, You need an SOOGZ (13154) adapter which will allow use of regular 39mm filters. It is a well made tension screw based adapter that doesn't look particularly bad. There is a picture of it in the WIKI. I have used it over the years many times with my vintage 28mm Summaron. Regards, Ron Thanks Ron. Can you still get the hood on with the adapter in place? Is the SOOGZ substantively different to a step-up ring? I only really use a yellow filter so I might still order a 34mm Heliopan one - if it fits ok. Â Â Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
Ronazle Posted January 24, 2017 Share #4  Posted January 24, 2017 (edited) Watsy, I doubt it very much; the outside diameter of the adapter is 42.5mm exactly the same as a 50mm Summicron (the closest at hand lens available to me). I would expect any other WA shade for a lens w/this outer diameter to fit. Having said that, probably the WA Leitz lens that least needs a lens shade is the 28mm Summaron. The Leica Polarizer (w/shade) will fit but interferes substantially, optically speaking. Regards, Ron  P.S. Basically the adapter is the same as a step-up ring except it is a set screw/tension fit. Edited January 24, 2017 by Ronazle 1 Link to post Share on other sites More sharing options...
UliWer Posted January 24, 2017 Share #5 Â Posted January 24, 2017 I do not have the new Summaron, but just the old version; and I have a 34 mm Heliopan-Filter. Â There is no problem with the filter pitch at all, the only "issue" is that Heliopan only offers the filter in black.... The hood fits perfectly on the filter, so even this "cosmetical" problem disappears. Â Though my experiece with the old version is no guarantee that the new version is the same, it would be more than strange if they altered anything for the filter pitch. 1 Link to post Share on other sites More sharing options...
wattsy Posted January 24, 2017 Author Share #6 Â Posted January 24, 2017 Though my experiece with the old version is no guarantee that the new version is the same, it would be more than strange if they altered anything for the filter pitch. It would be strange but I seem to recall that Leica did something like that with the E43 filter thread on the 'retro' looking 50 Summilux lenses that they have released recently. I might be mistaken about this but it is this recollection that has prompted my question here. LCT usually knows about these things. :-) Link to post Share on other sites More sharing options...
UliWer Posted January 24, 2017 Share #7 Â Posted January 24, 2017 Advertisement (gone after registration) O.K - they can be unpredictable at Wetzlar. I think the only way is to ask Leica directly - if there is nobody around here who uses the new version with filter. Link to post Share on other sites More sharing options...
lct Posted January 25, 2017 Share #8 Â Posted January 25, 2017 Standard filter thread pitch is not 0.5mm anymore but 0.75mm now. Leica doesn't elaborate about this in its instructions booklet though (excerpt below). Better ask Leica to be sure as suggested. Â <<<< E34 screw-on filters can be used on the Leica Summaron-M 1:5,6/28mm. These are available from a well-stocked photographic and optical specialists. SPARE PARTS Order No. Lens front cover (Silver chrome finish): 14058 Lens back cover: 14269 Lens hood: 12474 >>>> 1 Link to post Share on other sites More sharing options...
Ted Lemon Posted January 25, 2017 Share #9  Posted January 25, 2017 Has anybody bought filters for the new version of the 28mm Summaron? It is described as having an E34mm thread which is not a common size nowadays, to say the least. Heliopan still make coloured filters (largely special order) for 34mm but I'm not 100% certain whether the thread pitch is the same as the one used on the 2016 version of this lens. Fotoimpex describe the Heliopan 34mm filter as having an 0.5 pitch.  Hi  - I bought a UV E34mm filter online (turned out to be crap quality) but as pointed out you can't use it with lens hood so I just left it off! Link to post Share on other sites More sharing options...
wattsy Posted January 25, 2017 Author Share #10  Posted January 25, 2017 (edited) Hi  - I bought a UV E34mm filter online (turned out to be crap quality) but as pointed out you can't use it with lens hood so I just left it off!   What make was this Ted? Crap quality aside, I presume it screwed on ok? I don't mind not using the hood because the lens is very deeply set into the lens body and, with the hood on, the lens loses much of its handy small size-ness. I just need a yellow filter for those times when I want a yellow filter. Edited January 25, 2017 by wattsy Link to post Share on other sites More sharing options...
wattsy Posted January 25, 2017 Author Share #11  Posted January 25, 2017 (edited)  Standard filter thread pitch is not 0.5mm anymore but 0.75mm now. Leica doesn't elaborate about this in its instructions booklet though (excerpt below). Better ask Leica to be sure as suggested.  <<<< E34 screw-on filters can be used on the Leica Summaron-M 1:5,6/28mm. These are available from a well-stocked photographic and optical specialists. SPARE PARTS Order No. Lens front cover (Silver chrome finish): 14058 Lens back cover: 14269 Lens hood: 12474 >>>>   Thanks LCT. Yes, I checked the instruction booklet but am none the wiser. The current Heliopan 34mm is advertised by some sellers as compatible with A36 lenses which I know is an outer diameter for clamp-on accessories like the SOOGZ mentioned above but I understand many of those lenses also had an internal 34mm filter thread. That might explain why the Heliopan thread pitch is 0.5 and not 0.75. As I wrote earlier, Fotoimpex describe the Heliopan size as 34mm/0.5 but I can't find any official confirmation of that from a Heliopan source. I guess it would be useful if the new Summaron had the old thread pitch but it would be very true to form for Leica to have given it the 0.75 thread pitch without there being any filters or accessories available to screw into it.  I have emailed Leica and will wait to hear what they say. Edited January 25, 2017 by wattsy 1 Link to post Share on other sites More sharing options...
wattsy Posted January 26, 2017 Author Share #12 Â Posted January 26, 2017 Â Standard filter thread pitch is not 0.5mm anymore but 0.75mm now. Â Â I haven't heard back from Leica but looking into this a little more it seems that 0.75 is the modern standard for filters 43mm and larger. Modern standard for 39mm and 40.5mm is still 0.5 apparently. What this means for 34mm isn't entirely clear but it seems like a good bet that Leica's E34 is 0.5 and should be the same as Heliopan's 34mm A36 size. I'll likely order one anyway. As the Heliopan filter is meant for A36 lenses I'm hopeful that I should be able to fit the Summaron hood onto the filter. Link to post Share on other sites More sharing options...
lct Posted January 26, 2017 Share #13 Â Posted January 26, 2017 Hoya and Tiffen filters are referred to as "Standard thread pitch (0.75)" here: http://www.filterfind.net/34.html. FWIW. Link to post Share on other sites More sharing options...
wattsy Posted January 26, 2017 Author Share #14  Posted January 26, 2017 I've received a helpful reply from Leica.  "Thank you for your inquiry about the new 5,6/28 mm Summaron M lens. The thread pitch of this lens is 0,5 mm and the filter which needs to be used is indeed a E34 filter. The Heliopan filter will fit if it is also a E34 size. The problem is that it might be sticking out and the use of the sun shade will not be possible at the same time. Since we do not have this kind of filter here in our workshop, we can´t really try it out in order to let you know for sure." 2 Link to post Share on other sites More sharing options...
DickieT Posted January 27, 2017 Share #15 Â Posted January 27, 2017 I have the old Summaron and use Leica A36 clamp on filters. The SOOBK hood then attaches to the filter. You can find plenty mint condition A36 filters on Ebay, from UVa to yellow, orange and red. They come in silver and black finish Link to post Share on other sites More sharing options...
wattsy Posted February 23, 2017 Author Share #16 Â Posted February 23, 2017 (edited) I have recently received the Heliopan E34 yellow filter referenced above (SH-PMC multicoated version supplied by Lumiere in Germany) and I can confirm that it fits the filter thread of the new 28 Summaron perfectly. Â I can also confirm Leica's suspicion that the lens hood cannot be fitted with the filter in place. I had wondered if the outer diameter of the filter ring would match the front of the lens (in which case the hood, being a compression fit, would likely be ok) but the filter is 1-2mm narrower in outside diameter and the hood fitting is therefore far too loose to stay attached. I guess a small rubber band around the filter ring may be the answer but, thinking about this, I'm not entirely sure it's such a good idea to fit the hood to the filter. Attached to the filter, the hood is effectively thrust forward and positioned about 6mm proud of it's normal position, and I wonder if that is likely to cause a vignetting problem? Edited February 23, 2017 by wattsy Link to post Share on other sites More sharing options...
Ronazle Posted February 23, 2017 Share #17 Â Posted February 23, 2017 (edited) Watsy, easy test to determine: shoot an ordinary sheet of paper up very close (focus doesn't matter) both with and without the hood on the rubber band; the answer will be clear and accurate. Regards, Ron Edited February 23, 2017 by Ronazle Link to post Share on other sites More sharing options...
wattsy Posted February 23, 2017 Author Share #18  Posted February 23, 2017 Watsy, easy test to determine: shoot an ordinary sheet of paper up very close (focus doesn't matter) both with and without the hood on the rubber band; the answer will be clear and accurate. Regards, Ron   Yes, I'll probably run a few tests at some point. Link to post Share on other sites More sharing options...
Ted Lemon Posted February 23, 2017 Share #19  Posted February 23, 2017 I have recently received the Heliopan E34 yellow filter referenced above (SH-PMC multicoated version supplied by Lumiere in Germany) and I can confirm that it fits the filter thread of the new 28 Summaron perfectly.  I can also confirm Leica's suspicion that the lens hood cannot be fitted with the filter in place. I had wondered if the outer diameter of the filter ring would match the front of the lens (in which case the hood, being a compression fit, would likely be ok) but the filter is 1-2mm narrower in outside diameter and the hood fitting is therefore far too loose to stay attached. I guess a small rubber band around the filter ring may be the answer but, thinking about this, I'm not entirely sure it's such a good idea to fit the hood to the filter. Attached to the filter, the hood is effectively thrust forward and positioned about 6mm proud of it's normal position, and I wonder if that is likely to cause a vignetting problem?  Me too on buying the filter for using the lens on my M246. I have succumbed and ordered a Thorsten lens hood that accommodates the filter. I am due to get it soon will post a picture of it when on the camera.... Link to post Share on other sites More sharing options...
stevesurf Posted February 24, 2017 Share #20 Â Posted February 24, 2017 Evidently some of these Heliopan E34 filters are either discontinued or special order availability; here is one source for the yellow version; UV is out of stock. Â Link to post Share on other sites More sharing options...
