rent
Leica Q Firmware 2.1 Wishlist
I hope that they remove the default when using the 2 or 12 second delay. I would like to see the updated firmware allow you to continue in delay mode if you so wish!
Albert
Share this post
The one change that would make the most difference to the way I use my Q is to be able to switch Focus modes more easily.
At the moment, moving from single point AF to Face Detection or Touch focus is far too cumbersome for real life (which changes rapidly). I have to use three of my four profile options just to be able to switch around AF modes. What a waste.
Ideally, make this one of the options on the button at the top right (can't remember what it's called, but it defaults to Crop modes), or at least make it an FN button option.
Share this post
I share you view on this feature. I would like it to replace the Video button.
Share this post
Albert
Yes, this chore frustrates me as well.
Share this post
Wish : become compatible with the faster USB 3.1 standard. That would probably be a first in the camera world, and a very reasonable answer to those dreaming of a (super slow) wifi RAW transfer...
Share this post
Individually nameable profiles.  After all, the alpha-numerics are in there already for the wi-fi.
seconded. And, that these be saved somewhere, maybe on the card, so that after a reset one can retrieve them...
Edited by Herve5
Share this post
Just guess, since M10 may use the same CMOS as Q/SL, the new f/w for Q might be released after the new M10 released, with some optimizations on CMOS & Maestro II as M10.
Share this post
It is quite easy to forget which settings have been allocated to which User Profile. It would be very helpful if the title "User Profile" could be edited with a personal title so it would have more meaning to the owner
+1
Share this post
I really love that idea and it's solution with using the video button.
Share this post
My Wish List:
1. Firmware Update to allow touch focus (+shutter release if required) when using the EVF.
2. Firmware update mapping focus modes to FN buttons as we cannot change the focus mode without going into menu and sub menu. A particular problem when going from touch focus on the LCD to 1 point the on EVF - see also 1 above.
3. 4K Video PLEASE - that I understand from posts elsewhere several months ago that this was to be implemented once the overheating problem had been solved - surely this must have been solved by now.
All of these "wishes" have been implemented by Panasonic on their cameras and Panasonic handles Leica Q electronics and are not exotic. They are basic functions that (in the case of 1 & 2) enhance the minimalist ethos as they lead to less button pushes allowing more concentration on composition an more chance of capturing the 'decisive moment".
Eric8255
Share this post
Manual Video, Manual Video, Manual Video!
Can't think of a reason not to allow it with a setting in the Video-menu? Please Leica, pretty please!
Share this post
1. Remove video option from set button (we have a red record button already!). I end up in video record all the time for some reason but I want to shoot stills!!!
2. Allow to assign any function to FN button. Current options are too limited.
3. Name custom profiles
Share this post
My firmware wish list?
(1) A 2 to 12 second timer that doesn't turn off and have to be reset each time you turn the Q's main switch off and back on
(2) Alternate frame line perspective, like square 1:1
(3) More black & white shooting options, such as with red, yellow or orange filters
Share this post
Loading...
    No registered users viewing this page.
Important Information
